Recent Changes - Search:
<^< Primary Batteries | Course index | Mains Power Supply Units >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source ## Choosing a Power Source ## Batteries ## Primary Batteries ##
Rechargeable Batteries ## Mains Power Supply Units * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
<^< Primary Batteries | Course Index | Mains Power Supply Units >^>(:nl:)
Lead-acid batteries Nickel-cadmium batteries
A review:
Battery type Advantages Disadvantages
Lead-acid 'Gel-cell' Highest current driving capacity Damaged if left discharged for long periods
Can be left 'on-charge' Heavy and bulky
High charge capacity
Nickel-cadmium 'Ni-Cad' Can be recharged up to 3000 times Prone to 'memory effect'*
Widely available Not suitable for very low current applications
Higher energy density than lead-acid
Nickel-metal hydride 'NiMH' Can be recharged ~400 times Need a 'NiMH'-specific battery charger
High current driving capacity Loses charge quickly when not in use
Higher energy density than 'Ni-Cad's
Less prone to 'memory effect'*
Quick recharge time
Lithium-ion 'Li-ion' High energy density Very expensive
Hold charge for months Need a 'Li-ion'-specific battery charger
No 'memory effect'*
Light weight
*Memory effect - Can be damaged by repeated charging when not fully discharged.
Summary:
* In most cases, nickel-cadmium batteries will be the choice * Beware the memory effect! If you cannot rely on discharging your batteries each time, before you recharge them, consider using Lithium-ion batteries * For short periods of very high current demand, use lead-acid batteries, unless the weight is a problem.
Battery Do's & Don'ts (to maximize performance)
Do's:
* Properly "condition" the battery when it is new (i.e. fully charge/discharge for first 3 cycles) * Keep the battery and the contact terminals clean * Avoid exposing the battery to extreme heat and cold * If possible, avoid letting your battery sit dormant for long periods of time * Charge and re-condition a battery after an extended idle period
Don't s:
* Drop the battery * Short-circuit the battery * Incinerate a battery. Dispose of it properly - it may contain toxic chemicals
(:nl:)(:table style="clear:both":)
Page last modified on January 30, 2012, at 03:16 PM
