Recent Changes - Search:
<^< Other LCD Functions | Course index | Binary Numbers >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display ## Set up the Equipment ## LCD Displays ## Adding the LCD component ## Writing Messages ## Other LCD Functions ##
A More Useful Counter * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
<^< Other LCD Functions | Course Index | Binary Numbers >^>(:nl:)
# Expand your program by dragging a Loop icon below the 'PrintString' Component Macro.
# Change the text in the 'PrintString' Component Macro to "Hundredths:" (with quotation marks).
# Drag a Calculation icon into the Loop. Set up a variable called "Count" as an 'Int' type. Double-click on the Calculation icon. In the 'Calculations:' text box type "Count = Count + 1". This will add 1 to the value of variable count every time the icon is executed.
# Next drag another Component Macro into the Loop. Double-click the Component Macro and find 'Cursor' under the 'LCD' macros and enter '0,1' in the parameters. This will position the cursor on the first character of the second line.
# Next drag another Component Macro onto the workspace and do the same but select 'PrintNumber' instead and enter "Count" as the parameters.
# Next drag a Delay icon into the program and set the delay to 10ms or a hundredth of a second.
# Go over the program and click on each icon entering comments on what each icon does. This seems like a lot of effort, but if you can discipline yourself to entering comments you will save time in the long run as your programs will be easier to read.
# Run the program. You have now made a counter that will count (approximately) the time elapsed in hundredths of seconds.
(:nl:)(:table style="clear:both":)
Page last modified on May 07, 2013, at 01:36 PM
