Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display ## Set up the Equipment ## LCD Displays ## Adding the LCD component ## Writing Messages ## Other LCD Functions ## A More Useful Counter * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login LCD Displays<^< Set up the Equipment | Course Index | Adding the LCD component >^>(:nl:) Flowcode comes with a number of components that add commonly used systems to Flowcode, such as the LCD display, a 7-segment display, or analogue inputs. In this section we will look at the first one of these - the LCD display. The LCD display is the basic text display that you see on a lot of electronics equipment, from calculators to mobile phones. You can display text or numbers on one or more rows of the display. ![]() For most PICmicro programming languages the LCD is often one of the last things you learn as it is quite complicated to get working. However, in Flowcode you don't need to know what goes on under the hood, and the LCD is simple to use. The LCD display we will be looking at here is the one used on the EB005 LCD display. The LCD display is a two row, sixteen character display. (:nl:)(:table style="clear:both":)
Page last modified on August 26, 2011, at 03:51 PM
