Recent Changes - Search:
<^< Set up the Flowchart | Course index | Set up the Inputs >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers ## Set up the Equipment ## A Binary Adder ## Set up the Flowchart ##
Create the Variables ## Set up the Inputs ## Set up the Calculation ## Set up the Output ## Adding the LED array ## Adding the Switches ## Slow Simulation * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
<^< Set up the Flowchart | Course Index | Set up the Inputs >^>(:nl:)
# Click View on the menu bar, and then ensure 'Project Explorer' is checked (View > Project Explorer). Then click on the 'Globals' button at the top of the Project Explorer panel:
# We are going to create three variables, called input1, input2 and sum. The first two will store the numbers that we feed in from the switches. The variable 'sum' will store the result of adding together the two numbers stored in 'input1' and 'input2'.
# Hover over 'Variables' in the Project Explorer panel then click on the that appears, then click 'Add new'. You now see the 'Create a New Variable' dialogue box as can be see below. Type in the name "input1", and then click on the OK button. You can leave the variable type as 'Byte'. Create the variables, "input2" and "sum" in the same way.
(:nl:)(:table style="clear:both":)
Page last modified on May 03, 2013, at 07:51 AM
