Recent Changes - Search:
<^< Set up the Right Output | Course index | Adding the LED array >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions ## Set up the Equipment ## Left or Right? ## Set up the Flowchart ## Single Bit Input ## Set up the Decisions ## Set up the Delays ## Set up the Left Output ## Set up the Right Output ##
Adding the Switches ## Adding the LED array ## Final Flowchart ## Simulation * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Adding the Switches
<^< Set up the Right Output | Course Index | Adding the LED array >^>(:nl:)
You will use two push switches, one to operate the left indicator, the other the right indicator.
# Click once on the Inputs and select 'Push Round Panel' . Drag it into a suitable spot on the panel.
# Add another button using the same method, or copy (Ctrl+C) and paste (Ctrl+V) the existing button to duplicate it.
# Click on the left button and click 'Connection' under the 'Connections' section in the Properties pane and select Port A and Pin 0 from the drop-down menus.
# Click on the right button and connect it to Port A and Pin 1 using the same method.(:nl:)(:table style="clear:both":)
Page last modified on June 14, 2013, at 11:27 AM
