Recent Changes - Search:
<^< Set up the Equipment | Course index | Set up the Flowchart >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions ## Set up the Equipment ##
Left or Right? ## Set up the Flowchart ## Single Bit Input ## Set up the Decisions ## Set up the Delays ## Set up the Left Output ## Set up the Right Output ## Adding the Switches ## Adding the LED array ## Final Flowchart ## Simulation * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Left or Right?
<^< Set up the Equipment | Course Index | Set up the Flowchart >^>(:nl:)
More and more PICmicro microcontrollers are finding their way into cars - engine management, anti-lock brakes, cruise-control, air conditioning etc. This task is more modest, We are going to program a PICmicro chip to control the car indicators ('blinkers' if you are in the USA).
Ideally when we press one switch, the left indicator will flash on and off. Pressing the other switch will flash the right indicator.
(:nl:)(:table style="clear:both":)
Page last modified on April 30, 2013, at 12:02 PM
