Recent Changes - Search:
<^< Decisions | Course index | Left or Right? >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions ##
Set up the Equipment ## Left or Right? ## Set up the Flowchart ## Single Bit Input ## Set up the Decisions ## Set up the Delays ## Set up the Left Output ## Set up the Right Output ## Adding the Switches ## Adding the LED array ## Final Flowchart ## Simulation * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
<^< Decisions | Course Index | Left or Right? >^>(:nl:)
The diagram below shows you the E-blocks equipment you will need for this section:
Multiprogrammer Hardware settings:Setting:
PICmicro Device16F1937
Power supply13.5V
SW1 (Fast/Slow)N/A
SW2 (RC/XT)XT
XTAL19 660 800 Hz
PORTASwitch Board
PORTBLED Board
PORTCN/A
PORTDN/A
PORTEN/A
LVP Selection JumperI/O PORT
J12-14 (ICD2-USB)USB
J29 (PSU-USB)PSU(:nl:)(:table style="clear:both":)
Page last modified on February 03, 2012, at 11:25 AM
