Recent Changes - Search:
<^< Understanding the Patch System | Course index | Using ZIF Sockets >^>
E-Blocks * Introduction to E-blocks * Using E-blocks ## About E-blocks ## E-blocks Projects ## How E-blocks Connect to Each Other ## Physical Properties of E-blocks ## Using a Backplane ## Protecting E-blocks Circuitry ## Using Covers ## Adding Power to E-blocks ## Understanding the Patch System ##
Sharing a Port ## Using ZIF Sockets * E-blocks Boards
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Sharing A Port
<^< Understanding the Patch System | Course Index | Using ZIF Sockets >^>(:nl:)
There are times when you need to split a port into several sections, or where signals on a port need to be shared between two or more downstream E-blocks boards. In this case you need to use a splitter cable . As an example of this: supposing that you wanted to develop a system that used two external analogue sensors. The Sensor board only has the capability for one external analogue sensor, so you need to use a splitter cable and the patch system to make the appropriate connections. The resulting system would look something like this:
The splitter cable allows you to connect one upstream port to two downstream ports using IDC (Insulation Displacement Connector) connectors and ribbon cable. You can see that the analogue sensor input on the top board is the default connection: bit 3. On the lower board the link blocks are moved to the "patch" position and a small wire is used to connect the second analogue sensor to bit 2. The resulting system allows you to connect one analogue sensor to bit 3 and the other to bit 2 on the upstream board. (:nl:)(:table style="clear:both":)
Page last modified on February 03, 2012, at 11:16 AM
