Components
Revision as of 10:40, 9 May 2018 by BenR (talk | contribs)
Wireless
Error creating thumbnail: Unable to save thumbnail to destination
Bluetooth (EB024, Generic AT)
Low level routines for controlling a standard AT Bluetooth interface.
Bluetooth (HC05 HC06)
Low level routines for controlling or interacting with a HC05 or HC06 Bluetooth module.
Bluetooth v2 (EB024, Generic AT)
GPS (EB056, Generic NMEA)
Component designed to process incoming NMEA style GPS data and convert into meaningful
GSM (EB066, Generic AT)
Low level routines for controlling a standard AT GSM / GPRS interface
IrDA (EB012, MCP1250, MCP2120)
Low level routines for controlling a standard IrDA interface.
RC5 (EB060, Generic 36KHz)
Low level routines for controlling a standard RC5 IR interface.
RF 2.4GHz
A simple RF communications module based on the 2.
RF ISM (EB063, MRF49XA)
A simple RF-ISM communications module based on the Microchip Alpha MRF49XA device.
RFID (EB052, RWD_MICODE)
Low level routines for controlling a RF Solutions RFID interface
RFID (MFRC522)
Functions designed to work with the MFRC522 contactless reader IC.
SRF (WirelessThings)
The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module.
WLAN (EB069, ESP8266)
Wireless LAN component designed to work with the ESP8266 module.
WLAN (EB069, WIZ610wi)
Wireless LAN component designed to work with the WIZ610wi module from Wiznet.
Zigbee (EB051, XBEE)
Zigbee component designed to work with the XBEE range of modules from Digi.
EBM Modules
Accel Mag 6_Axis
EBM015 Combined 6-Axis Accelerometer and Magnetometer sensors
Colour Sensor
This board provides the ability to detect colours using the TCS3200 sensor.
Digital Temperature
A digital temperature sensor based around the LM75B chip.
Dual Potentiometer _ Trimmer
This board provides two rotary potentiometers.
GLCD (EBM001)
Graphical display component designed to work with the EBM001 modules and EB084 E-blocks.
Gyroscope
Interface to the L3G4200D three axis digital gyroscope.
Hall Effect
The board has a Hall Effect sensor (SL353) that gives a digital output in the presence of a magnetic field (in the region
Humidity
Humidity and temperature sensor using an SHT21 IC connected via I2C - as used by the
Infrared
The Infrared sensor board contains both an IR transmitter and receiver.
PIR
This board provides a PIR sensor which is read as a digital input.
Potentiometer
This board consists of a standard shaft rotary potentiometer that provides a linear voltage
Rotary Encoder
Provides a rotary encoder with dual digital outputs that provide rotation and direction information.
Thermistor
A generic thermistor component that can be used to simulate and create code for any
Thermocouple TypeK
A component matchin the Matrix EBM008 thermocouple board.
Touch Pads
This board provides two touch areas for use with capacitive sensing.
Touch Slider
This board provides two touch slide areas for use with capacitive sensing.
Ultrasonic
This board has both an ultrasonic transmitter and receiver.
Modelling Components
Clone Matrix
Takes a single object and produces a three dimensional array of evenly spaced clones.
Inputs: Analog
ADC Template
Base ADC component with no graphical interface.
Comms: USB
USB HID
Component to create and communicate using a standard HID type USB class.
USB MIDI
Component to create and communicate using a standard MIDI connection.
USB Serial
Component to create and communicate using a standard CDC type COM port.
USB Slave
Component to create and communicate using a generic USB communications profile.
Displays: Segment
7Segment (Quad)
14mm seven segment display.
7Segment (Single)
Seven segment display modelled after a standard 14mm high unit.
Starburst Display
Starburst 14 or 16 segment display modelled after a standard 14mm high unit.
Inputs: Keypads
Keypad (Generic)
Generic component to create a raster scanned custom keypad or button matrix.
Inputs: General
Encoder Rotary
Encoder component implements a rotary encoder connected to two pins
Touch Pads
This board provides five touch areas for use with capacitive sensing.
DSP
Control
Allows for several types of control operations to be performed on a buffer.
DSP System
DSP System main buffer manager responsible for allocating memory, taking care of buffer indexes ...
Delay
Allows an adjustable delay to be inserted into the DSP system
Fast Fourier Transform (FFT)
Provides a way of converting a buffer full of time domain data into frequency domain data.
Filter
Filter component to allow basic filtering to be performed
Frequency Generator
A frequency generator component designed to plug into the DSP system component and allow several...
Input
Allows the values from a buffer to be assigned.
Level
Allows for detection and collection of peaks, troughs and averages.
Output
Allows the values from a buffer to be read.
Scale
Allows the values in a single buffer to be scaled uniformly.
Sum
Component to combine together two DSP buffers into one an index at a time.
Comms
Data Injector Template
A base data injector used as a placeholder in components which reference the data injector interface.
2D Shapes
Ellipse
A basic ellipse primitive shape.
A basic text label.
Line
A basic line primitive shape.
Rectangle
A basic rectangle primitive shape.
Rounded rectangle
A basic rounded rectangle primitive shape.
Textbox
A basic textbox.
3D Shapes
Bowl
A basic bowl primitive shape.
Cone
A basic cone primitive shape.
Cuboid
A basic cuboid primitive shape.
Cylinder
A basic cylinder primitive shape.
Diamond
A basic diamond primitive shape.
Hemisphere
A basic hemisphere primitive shape.
Honeycomb
A basic honeycomb primitive shape.
Prism
A basic prism primitive shape.
Pyramid
A basic pyramid primitive shape.
Sphere
A basic sphere primitive shape.
Tube
A basic tube primitive shape.
Comms: System
DALI Master
A serial based communications protocol designed for controlling lighting, specifically digitally
DALI Slave
DMX_512 Master
A serial based communications protocol designed for controlling theatrical equipment such
DMX_512 Slave
IO Expander
Provides 16 digital input/output pins arranged into two 8-bit ports using a I2C bus connection.
IO Expander
Provides 16 digital input/output pins arranged into two 8-bit ports using a SPI bus connection.
MIDI
Low level routines for controlling or interacting with a standard MIDI interface.
MULTIUART
Uses a high speed SPI connection to enable up to four buffered external UARTs via the MULTIUART modules.
Modbus Master
Modbus component for talking to Modbus compatible hardware via RS232 or RS485.
Modbus Slave
Modbus component for creating Modbus compatible slave hardware via RS232 or RS485.
Visi (4DSystems)
A way of interacting with the VISI interface designed by 4D systems.
Comms: Interface
CAN (Internal, MCP2515)
Low level routines for controling the CAN interface either using an external MCP2515 IC and a SPI bus connection
FTDI (FTD2XX)
Simulation only interface to allow communications with a FTDI USB 232 IC connected to the system.
I2C Master
I2C Slave
One Wire
Low level routines for controlling or interacting with a standard one wire interface.
SPI Master
Low level routines for controlling or interacting with an SPI interface.
UART (RS232)
Low level routines for controlling or interacting with a standard asyncronous serial interface.
Inputs: Switches
Switch Array Template
A base component for creating an evenly spaced array of switches.
Switch Template
Base single pin switch with no graphical interface
MIAC: PC Peripheral
MIAC (PIC) USB Slave
Allows Matrix's MIAC PLC to be used as a PC peripheral controlled by Flowcode via a USB
MIAC AllCode
MIAC AllCode.
MIAC: Addon Modules
MIAC (PIC) CAN Slave
MIAC Slave for MIAC System.
MIAC Advanced
Advanced Addon for MIAC System
MIAC Basic
Basic Addon expansion module for MIAC System
MIAC Bluetooth
Bluetooth Addon for MIAC System
MIAC GPS
GPS Addon expansion module for MIAC System
MIAC GSM
GSM Addon for MIAC System.
MIAC Industrial
MIAC Industrial Addon component for MIAC System.
MIAC Serial
Serial Addon expansion module for MIAC System
MIAC Zigbee Coordinator
MIAC Zigbee Coordinator Addon component for MIAC System.
MIAC Zigbee Router
MIAC Zigbee Router Addon component for MIAC System.
Comms: Networking
Base 64
Component to allow base 64 encoding and decoding.
Network Communications
A component designed to simplify the process of TCP/IP communications.
TCP Template
Base TCP/IP component with simulation only interface to allow TCP/IP style network communications in simulation.
TCPIP
A set of routines used to control a ENC28J60 TCP/IP Module.
TCPIP
TCP/IP component designed to work with the WIZ3100 range of modules from Wiznet.
TCPIP
TCP/IP component designed to work with the WIZ810MJ module from Wiznet,
TCPIP
TCP/IP sockets component for use with Raspberry Pi.
Webserver
Webserver component designed to work with the WIZ810MJ module from Wiznet,
Webserver (NM7010A)
Webserver component designed to work with the NM7010A module from Wiznet,
Displays: Graphical
Bitmap Drawer FAT
A component to simplify the process of drawing bitmap images to a graphical display.
Bitmap Drawer ROM
GLCD Base
Base graphical LCD with simulation only interface to allow graphics to be drawn in simulation.
GLCD Graph Creator
A component to simplify the process of drawing graphs and charts using a graphical LCD.
GLCD Textfield
A component to simplify the process of drawing text to a graphical display.
Touch Screen (XPT2046)
Low level routines for controlling or interacting with the XPT2046 touch screen controller IC found
Outputs: LEDs
LED (Generic, RGB)
An LED with red, green and blue elements that can be mixed together to produce
LED Array Template
Create an evenly spaced array of LED indicators.
LED Charlieplex
Create an evenly spaced array of LED indicators using a reduced amount of I/O pins.
LED Cube
LED Cube component for driving 3D arrays of LEDs.
LED Matrix
LED Matrix component designed to work using a HT16K33 LED driver IC.
LED Matrix (Parallel)
LED Matrix component designed to work using multiple data pins and a single clock pin.
LED Matrix (Serial)
LED Matrix component designed to work using a single data and clock pin.
LED MultiColour Bi (5mm, PCB)
An industry standard 5mm diameter bi-colour LED.
LED MultiColour Tri (5mm, PCB)
An industry standard 5mm diameter tri-colour LED.
LED Template
Base for creating LEDs and other on/off visual indicators.
NeoPixel LED APA102C
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream.
NeoPixel LED WS2801
NeoPixel LED WS2811 WS2812 APA106
RGB Xmas Tree
Component complete with macros and simultion to drive the MatrixTSL RGB Xmas Tree decoration.
Mechatronics
3D Printer
A simulation only version of a very basic 3D printer such as a standard RepRap.
AllCode Robot Arm
Matrix 5-axis Robot Arm with Gripper.
Formula AllCode
A component to allow all the features of the Formula AllCode robot to be investigated.
Formula AllCode API
A simulation only component to allow the Formula AllCode robot to be controlled via it's
Formula Flowcode
A component to allow all the features of the Formula Flowcode robot to be investigated.
Motor Template
Base component for constructing continuous motion - e.
Servo Controller
Can control up to eight standard PWM driven servo's.
Servo Motor Template
Base component for creating custom servo motor simulations.
Solenoid Template
Base component for constructing solenoids.
Stepper Motor Template
Enables the creation of a stepper motor component by specifying objects for its appearance.
E-blocks 2
Combo
A component to drive the BL0114 Combo board including LEDs, Switches, LCD, 7-Segs
GLCD
Graphical display component designed to work with the ST7567 type monochrome displays.
IO Expander
Provides 16 digital input/output pins arranged into two 8-bit E-block 2 ports using a SPI bus connection.
LCD
LCD component to drive the E-blocks 2 BL0169 LCD board.
LED
LED component to drive the E-blocks 2 BL0167 LED board.
Servo Motor
Servo motor component to drive the E-blocks 2 BL0162 Servo Motors board.
Animation
Animator
Basic animation and physics simulation for a single object.
Motion Helper
Helper for building components which require simulation of constant motion.
E-blocks 1
Accelerometer
LIS3LV02DQ Accelerometer sensor with options for I2C or SPI communications.
Combo Board
A simulated version of the EB083 Combo board including LEDs, Switches, LCD, 7-Segs
GLCD
Graphical display component designed to work with the EB057 modules and EB058 E-blocks.
Keypad
Preset keypad based around the 3 * 4 unit, as used by the Matrix EB014 E-block
LCD
LCD based on the unit used in the Matrix EB005 E-block
LED
An LED matrix made up of standard PCB mount 5mm LEDs.
SPI Master
Switch
An array of up to eight momentary push switches, each connected to a single pin of the specified port.
TCPIP
TCPIP
Webserver
Webserver
Matrix Tools
COM Port
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial.
Console Debugger
Component to allow printing debug messages to the Raspberry Pi Console.
Device Helper
A purely cosmetic component for viewing the details specific to your current selected target microcontroller.
E_block Helper
A purely cosmetic component to help simplify E-block connections without having to keep referring to the datasheets.
FCD helper
A helper control to query the current FCD file
IntOsc Helper
A component to help configure the speed of the internal oscillator.
Scope monitor
A component to allow data from analogue and digital pins to be displayed on the scope window.
Serial Monitor
Allows data from a COM port to be piped through to the console window for easy program status and debugging.
Sensors
Accel Gyro 6_Axis
MPU-6050 Combined 6-Axis Accelerometer and Gyroscope sensors.
Accel Gyro Mag 9_Axis
MPU9250 Combined 9-Axis Accelerometer, Gyroscope and Magnetometer sensors
Accel Mag 6_Axis
LSM303DLHC Combined 6-Axis Accelerometer and Magnetometer sensors
Accel Mag 6_Axis
LSM303D Combined 6-Axis Accelerometer and Magnetometer sensors
Accelerometer 3_Axis
Barometer
A small PCB surface mount barometric pressure sensor with a I2C bus interface.
Barometer
Collision Detector Template
Polls a chosen panel object to see if it has collided with another object.
Colour Sensor
Gyroscope 3_Axis
Gyroscope 3_Axis I2C (L3GD20)
Interface to the L3GD20 three axis digital gyroscope.
Gyroscope 3_Axis SPI (L3GD20)
Allows access to a three axis digital gyroscope via an SPI interface.
Hall Effect Analog
Simple analogue hall effect triggered by the proximity of another object.
Hall Effect Digital
Simple digital hall effect on off switch triggered by the proximity of another object.
Humidity
Humidity and temperature sensor using an SHT21 IC connected via I2C.
Infrared Array AMG88xx
An 8x8 (64) Pixel infrared sensor array allowing basic none contact temperature detection.
Photo Reflector
Uses InfraRed light to detect if an external object is near to the sensor.
Photo Transistor
Proximity Analog Template
Polls a chosen panel object to test it's distance from this component.
Proximity Switch Template
Reed Switch
Simple on off switch triggered by the proximity of another object.
Temp Humidity (DHT11 )
The DHT11 temperature and humidity sensor is a popular sensor allowing the ambient
Temp Humidity (DHT22 )
The DHT22 temperature and humidity sensor is a popular sensor allowing the ambient
Temperature
A digital temperature sensor based around the NXP LM75B chip.
Thermistor Template
Base component for creating thermistors.
MIAC Module
MIAC (Arduino_Compatible)
MIAC - Matrix Industrial Automotive Controller (Arduino-Compatible)
MIAC (PIC)
MIAC (dsPIC)
MIAC - Matrix Industrial Automotive Controller (dsPIC)
Storage
Auto Version Identifier
Basic component designed to provide the program with the date and time of the build.
Circular Buffer
Circular buffer component allowing easy and efficient first in first out (FIFO) style data byte storage.
EEPROM
A means of reading data from and writing data to the EEPROM memory onboard the microcontroller.
Embed File
A component to simplify the process of embedding files into ROM.
FAT (SD, SDHC)
FAT component allowing access to read and write files on a SD, SDHC or MMC card.
Lookup tables
A lookup-table component allowing an easy way to place arrays of static data into ROM memory.
RTC (MCP7940N)
Serial (I2C) Real Time Clock component for MCP7940N device.
Real Time Clock (RTC)
A Real Time Clock component allowing things like clocks and timers to easily be created.
Serial EEPROM (24C16)
Serial (I2C) EEPROM component for 24C01 to 24C16
Serial EEPROM (24C32)
Serial (I2C) EEPROM component for 24C32
String Translator
A simple component to allow multiple language support by substituting different strings depending
Timer
Allows you to measure the passage of time via the use of a hardware timer peripheral.
Misc
Basic IO Shield PCB
Curiosity PCB
Heelight Sensor
Heelight Sensor is a smart voice sensor that can recognize up tp 500 digital voice commands.
LCD control
An LCD control pane supporting up to 64 x 64 units
Microchip 44 Pin PCB
Microchip Low Pin PCB
Xpress PCB
Displays: Alphanumeric
LCD (Adafruit, OLED)
Adafruit OLED LCD display
LCD (Generic)
Generic configurable alphanumeric LCD display component based on the standard
LCD 4x20 (Adafruit, OLED)
Adafruit OLED LCD display 4 x 20 characters
Scenarios
Airplane Landing Gear
A simulation of an Airplane Landing Gear containing, switches, locking mechanisms and retracting landing gear.
CNC Machine
A CNC Machine that allows for simulation movement in the X, Y, Z directions and also providing access to the Drill.
Car Seat
An electric car seat chassis with a series of motors and sensors.
Pedestrian Crossing
A set of pedestrian crossing lights complete with manual light control, a simple state machine and an
Sheep Pen
A simple sheep pen simulation with two gates and two sensors.
Traffic Light 1_Way
A set of one way traffic lights complete with manual light control, a simple state machine and an
Traffic Light 2_Way
A set of two way traffic lights complete with manual light control, a simple state machine and an
Peripheral CAL
ADC
CAL - Code Abstraction Layer
CAN
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips.
EEPROM
I2C
PWM
SPI
UART
3rd Party Equipment/Tools
K8055D
Support for the Velleman K8055 USB input/output board.
PicoScope
A set of functions designed for interacting with a 2000 series Pico scope via simulation.
TTI TG5011 Signal Generator
TTi TG5011 50 MHz Signal Generator
TTi Power Supply _ PL155_P
TTi PL155-P Power Supply Unit Component.
Grove
Accel Gyro 6_Axis LSM6DS3
Barometer BMP280
Barometric pressure sensor with a I2C bus interface.
Chainable RGB LED v2.0
Grove-Chainable RGB LED V2.
Grove Water Sensor
The water sensor uses a 1M ohm pull-up resistor.
I2C Color Sensor
Based on the color sensor TCS34725FN with digital output I2C.
Infrared Reflective Sensor (101020174)
LED Bar v2.0
LED Bar is comprised of a 10 segment LED gauge bar and an MY9221 LED controlling chip.
PIR Motion BISS0001
PIR motion sensor component for digital output sensors.
Relay
The Relay is a digital normally open switch capable of switching much higher voltages and curren...
Sound Sensor
The Sound sensor module is a simple microphone.
Temp Humidity DHT22
Temperature Sensor
Temperature Sensor uses a thermistor to measure ambient temperature.
Ultrasonic Ranger
The ultrasonic sensor is a non-contact distance measurement module.
Formula Flowcode Racetrack
A simple race course for the Formula Flowcode buggy.
Maze Generator
Creates a simulation only randomised maze out of standard micromouse maze walls and pillars.
Meter Square
Square analogue panel meter.
Simulation External Input
A simulation only component designed to allow a single digital pin to be toggled at a set frequency.
Simulation LED
A simple LED suitable for simulation that does not require a pin connection
Simulation Switch Template
A base for building switches that do not download to chip.
Time Stamp
A simple simulation component to collect the current system timestamp as a string.
Outputs: General
Buzzer
Drives a simple fixed frequency buzzer in hardware and simulates the sound of a buzzer in simulation.
DAC Output
PWM
Pulse Width Modulation, a versitile way of generating a digital pulse using mark / space modulation.
Piezo Sounder
Drives a simple variable frequency piezo sounder in hardware and simulates the sound in simulation.
Speech
Speech component allowing Phoneme based speech for use on an embedded platform.
Helpers
Button helper
A button overlay that allows any object to behave like a button
Advanced Shapes
Bezel Radiused
A purely cosmetic component for creating smoothly radiused bezel or frame to fit around
Component Label
Add a label to a component by including this component as a sub-component.
Component Labels
Automatically generates labels for all panel objects and components in a given context.
Dashboard Text
A simulation only text box that can be used to display text and numbers.
Marking control
A control to draw markings on any component
Panel Console Viewer
An easy way to display the data from up to four console windows on the panel.
RxTx Flasher
Simple indicator panel intended as a sub-component of communications components.
Scale Arc Template
A base component for drawing circular dials.
Scale Linear Template
A base component for drawing scales on horizontal or vertical strips.
Slider control
A simple graphical interface for a vertical meter or slider control.
Target Chip
A cosmetic only representation of the target microcontoller device showing the default package type complete with pins.
Wood Fence
A simple wooden fence used to create simple walls and pens for simulations.
Wood Gate
A simple gate that can be opened and closed via simulation macros.
