Components
Jump to navigationJump to searchError creating thumbnail: Unable to save thumbnail to destination ADC Template
Base ADC component with no graphical interface. |
Error creating thumbnail: Unable to save thumbnail to destination Encoder Rotary
Encoder component implements a rotary encoder connected to two pins |
Error creating thumbnail: Unable to save thumbnail to destination Touch Pads
This board provides five touch areas for use with capacitive sensing. |
Error creating thumbnail: Unable to save thumbnail to destination Keypad (Generic)
Generic component to create a raster scanned custom keypad or button matrix. |
Error creating thumbnail: Unable to save thumbnail to destination Switch Array Template
A base component for creating an evenly spaced array of switches. |
Error creating thumbnail: Unable to save thumbnail to destination Switch Template
Base single pin switch with no graphical interface |
Error creating thumbnail: Unable to save thumbnail to destination Buzzer
Drives a simple fixed frequency buzzer in hardware and simulates the sound of a buzzer in simulation. |
Error creating thumbnail: Unable to save thumbnail to destination DAC Output
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. |
Error creating thumbnail: Unable to save thumbnail to destination PWM
Pulse Width Modulation, a versitile way of generating a digital pulse using mark / space modulation. |
Error creating thumbnail: Unable to save thumbnail to destination Piezo Sounder
Drives a simple variable frequency piezo sounder in hardware and simulates the sound in simulation. |
Error creating thumbnail: Unable to save thumbnail to destination Speech
Speech component allowing Phoneme based speech for use on an embedded platform. |
Error creating thumbnail: Unable to save thumbnail to destination LED (Generic, RGB)
An LED with red, green and blue elements that can be mixed together to produce |
Error creating thumbnail: Unable to save thumbnail to destination LED Array Template
Create an evenly spaced array of LED indicators. |
Error creating thumbnail: Unable to save thumbnail to destination LED Charlieplex
Create an evenly spaced array of LED indicators using a reduced amount of I/O pins. |
Error creating thumbnail: Unable to save thumbnail to destination LED Cube
LED Cube component for driving 3D arrays of LEDs. |
Error creating thumbnail: Unable to save thumbnail to destination LED Matrix
LED Matrix component designed to work using a HT16K33 LED driver IC. |
Error creating thumbnail: Unable to save thumbnail to destination LED Matrix (Parallel)
LED Matrix component designed to work using multiple data pins and a single clock pin. |
Error creating thumbnail: Unable to save thumbnail to destination LED Matrix (Serial)
LED Matrix component designed to work using a single data and clock pin. |
Error creating thumbnail: Unable to save thumbnail to destination LED MultiColour Bi (5mm, PCB)
An industry standard 5mm diameter bi-colour LED. |
Error creating thumbnail: Unable to save thumbnail to destination LED MultiColour Tri (5mm, PCB)
An industry standard 5mm diameter tri-colour LED. |
Error creating thumbnail: Unable to save thumbnail to destination LED Template
Base for creating LEDs and other on/off visual indicators. |
Error creating thumbnail: Unable to save thumbnail to destination NeoPixel LED APA102C
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. |
Error creating thumbnail: Unable to save thumbnail to destination NeoPixel LED WS2801
Error creating thumbnail: Unable to save thumbnail to destination NeoPixel LED WS2811 WS2812 APA106
Error creating thumbnail: Unable to save thumbnail to destination RGB Xmas Tree
Component complete with macros and simultion to drive the MatrixTSL RGB Xmas Tree decoration. |
Error creating thumbnail: Unable to save thumbnail to destination LCD (Adafruit, OLED)
Adafruit OLED LCD display |
Error creating thumbnail: Unable to save thumbnail to destination LCD (Generic)
Generic configurable alphanumeric LCD display component based on the standard |
Error creating thumbnail: Unable to save thumbnail to destination LCD 4x20 (Adafruit, OLED)
Adafruit OLED LCD display 4 x 20 characters |
Error creating thumbnail: Unable to save thumbnail to destination Bitmap Drawer FAT
A component to simplify the process of drawing bitmap images to a graphical display. |
Error creating thumbnail: Unable to save thumbnail to destination Bitmap Drawer ROM
Error creating thumbnail: Unable to save thumbnail to destination GLCD Base
Base graphical LCD with simulation only interface to allow graphics to be drawn in simulation. |
Error creating thumbnail: Unable to save thumbnail to destination GLCD Graph Creator
A component to simplify the process of drawing graphs and charts using a graphical LCD. |
Error creating thumbnail: Unable to save thumbnail to destination GLCD Textfield
A component to simplify the process of drawing text to a graphical display. |
Error creating thumbnail: Unable to save thumbnail to destination Touch Screen (XPT2046)
Low level routines for controlling or interacting with the XPT2046 touch screen controller IC found |
Error creating thumbnail: Unable to save thumbnail to destination 7Segment (Quad)
14mm seven segment display. |
Error creating thumbnail: Unable to save thumbnail to destination 7Segment (Single)
Seven segment display modelled after a standard 14mm high unit. |
Error creating thumbnail: Unable to save thumbnail to destination Starburst Display
Starburst 14 or 16 segment display modelled after a standard 14mm high unit. |
Error creating thumbnail: Unable to save thumbnail to destination Accel Gyro 6_Axis
MPU-6050 Combined 6-Axis Accelerometer and Gyroscope sensors. |
Error creating thumbnail: Unable to save thumbnail to destination Accel Gyro Mag 9_Axis
MPU9250 Combined 9-Axis Accelerometer, Gyroscope and Magnetometer sensors |
Error creating thumbnail: Unable to save thumbnail to destination Accel Mag 6_Axis
LSM303DLHC Combined 6-Axis Accelerometer and Magnetometer sensors |
LSM303D Combined 6-Axis Accelerometer and Magnetometer sensors |
Error creating thumbnail: Unable to save thumbnail to destination Accelerometer 3_Axis
LIS3LV02DQ Accelerometer sensor with options for I2C or SPI communications. |
Error creating thumbnail: Unable to save thumbnail to destination Barometer
A small PCB surface mount barometric pressure sensor with a I2C bus interface. |
Error creating thumbnail: Unable to save thumbnail to destination Collision Detector Template
Polls a chosen panel object to see if it has collided with another object. |
Error creating thumbnail: Unable to save thumbnail to destination Colour Sensor
This board provides the ability to detect colours using the TCS3200 sensor. |
Error creating thumbnail: Unable to save thumbnail to destination Gyroscope 3_Axis
Interface to the L3G4200D three axis digital gyroscope. |
Error creating thumbnail: Unable to save thumbnail to destination Gyroscope 3_Axis I2C (L3GD20)
Interface to the L3GD20 three axis digital gyroscope. |
Error creating thumbnail: Unable to save thumbnail to destination Gyroscope 3_Axis SPI (L3GD20)
Allows access to a three axis digital gyroscope via an SPI interface. |
Error creating thumbnail: Unable to save thumbnail to destination Hall Effect Analog
Simple analogue hall effect triggered by the proximity of another object. |
Error creating thumbnail: Unable to save thumbnail to destination Hall Effect Digital
Simple digital hall effect on off switch triggered by the proximity of another object. |
Error creating thumbnail: Unable to save thumbnail to destination Humidity
Humidity and temperature sensor using an SHT21 IC connected via I2C. |
Error creating thumbnail: Unable to save thumbnail to destination Infrared Array AMG88xx
An 8x8 (64) Pixel infrared sensor array allowing basic none contact temperature detection. |
Error creating thumbnail: Unable to save thumbnail to destination Photo Reflector
Uses InfraRed light to detect if an external object is near to the sensor. |
Error creating thumbnail: Unable to save thumbnail to destination Photo Transistor
Error creating thumbnail: Unable to save thumbnail to destination Proximity Analog Template
Polls a chosen panel object to test it's distance from this component. |
Error creating thumbnail: Unable to save thumbnail to destination Proximity Switch Template
Error creating thumbnail: Unable to save thumbnail to destination Reed Switch
Simple on off switch triggered by the proximity of another object. |
Error creating thumbnail: Unable to save thumbnail to destination Temp Humidity (DHT11 )
The DHT11 temperature and humidity sensor is a popular sensor allowing the ambient |
Error creating thumbnail: Unable to save thumbnail to destination Temp Humidity (DHT22 )
The DHT22 temperature and humidity sensor is a popular sensor allowing the ambient |
Error creating thumbnail: Unable to save thumbnail to destination Temperature
A digital temperature sensor based around the NXP LM75B chip. |
Error creating thumbnail: Unable to save thumbnail to destination Thermistor Template
Base component for creating thermistors. |
Error creating thumbnail: Unable to save thumbnail to destination Accel Gyro 6_Axis LSM6DS3
Error creating thumbnail: Unable to save thumbnail to destination Barometer BMP280
Barometric pressure sensor with a I2C bus interface. |
Error creating thumbnail: Unable to save thumbnail to destination Chainable RGB LED v2.0
Grove-Chainable RGB LED V2. |
Error creating thumbnail: Unable to save thumbnail to destination Grove Water Sensor
The water sensor uses a 1M ohm pull-up resistor. |
Error creating thumbnail: Unable to save thumbnail to destination I2C Color Sensor
Based on the color sensor TCS34725FN with digital output I2C. |
Error creating thumbnail: Unable to save thumbnail to destination Infrared Reflective Sensor (101020174)
Error creating thumbnail: Unable to save thumbnail to destination LED Bar v2.0
LED Bar is comprised of a 10 segment LED gauge bar and an MY9221 LED controlling chip. |
Error creating thumbnail: Unable to save thumbnail to destination PIR Motion BISS0001
PIR motion sensor component for digital output sensors. |
Error creating thumbnail: Unable to save thumbnail to destination Relay
The Relay is a digital normally open switch capable of switching much higher voltages and curren... |
Error creating thumbnail: Unable to save thumbnail to destination Sound Sensor
The Sound sensor module is a simple microphone. |
Error creating thumbnail: Unable to save thumbnail to destination Temp Humidity DHT22
Error creating thumbnail: Unable to save thumbnail to destination Temperature Sensor
Temperature Sensor uses a thermistor to measure ambient temperature. |
Error creating thumbnail: Unable to save thumbnail to destination Ultrasonic Ranger
The ultrasonic sensor is a non-contact distance measurement module. |
Error creating thumbnail: Unable to save thumbnail to destination Combo Board
A simulated version of the EB083 Combo board including LEDs, Switches, LCD, 7-Segs |
Graphical display component designed to work with the EB057 modules and EB058 E-blocks. |
Preset keypad based around the 3 * 4 unit, as used by the Matrix EB014 E-block |
LCD based on the unit used in the Matrix EB005 E-block |
An LED matrix made up of standard PCB mount 5mm LEDs. |
Error creating thumbnail: Unable to save thumbnail to destination SPI Master
Low level routines for controlling or interacting with an SPI interface. |
An array of up to eight momentary push switches, each connected to a single pin of the specified port. |
Error creating thumbnail: Unable to save thumbnail to destination TCPIP
TCP/IP component designed to work with the WIZ3100 range of modules from Wiznet. |
TCP/IP component designed to work with the WIZ810MJ module from Wiznet, |
Error creating thumbnail: Unable to save thumbnail to destination Webserver
Webserver component designed to work with the NM7010A module from Wiznet, |
Webserver component designed to work with the WIZ810MJ module from Wiznet, |
A component to drive the BL0114 Combo board including LEDs, Switches, LCD, 7-Segs |
Graphical display component designed to work with the ST7567 type monochrome displays. |
Error creating thumbnail: Unable to save thumbnail to destination IO Expander
Provides 16 digital input/output pins arranged into two 8-bit E-block 2 ports using a SPI bus connection. |
LCD component to drive the E-blocks 2 BL0169 LCD board. |
LED component to drive the E-blocks 2 BL0167 LED board. |
Error creating thumbnail: Unable to save thumbnail to destination Servo Motor
Servo motor component to drive the E-blocks 2 BL0162 Servo Motors board. |
EBM015 Combined 6-Axis Accelerometer and Magnetometer sensors |
Error creating thumbnail: Unable to save thumbnail to destination Digital Temperature
A digital temperature sensor based around the LM75B chip. |
Error creating thumbnail: Unable to save thumbnail to destination Dual Potentiometer _ Trimmer
This board provides two rotary potentiometers. |
Error creating thumbnail: Unable to save thumbnail to destination GLCD (EBM001)
Graphical display component designed to work with the EBM001 modules and EB084 E-blocks. |
The board has a Hall Effect sensor (SL353) that gives a digital output in the presence of a magnetic field (in the region |
Humidity and temperature sensor using an SHT21 IC connected via I2C - as used by the |
The Infrared sensor board contains both an IR transmitter and receiver. |
This board provides a PIR sensor which is read as a digital input. |
Error creating thumbnail: Unable to save thumbnail to destination Potentiometer
This board consists of a standard shaft rotary potentiometer that provides a linear voltage |
Error creating thumbnail: Unable to save thumbnail to destination Rotary Encoder
Provides a rotary encoder with dual digital outputs that provide rotation and direction information. |
A generic thermistor component that can be used to simulate and create code for any |
Error creating thumbnail: Unable to save thumbnail to destination Thermocouple TypeK
A component matchin the Matrix EBM008 thermocouple board. |
This board provides two touch areas for use with capacitive sensing. |
Error creating thumbnail: Unable to save thumbnail to destination Touch Slider
This board provides two touch slide areas for use with capacitive sensing. |
This board has both an ultrasonic transmitter and receiver. |
Error creating thumbnail: Unable to save thumbnail to destination CAN (Internal, MCP2515)
Low level routines for controling the CAN interface either using an external MCP2515 IC and a SPI bus connection |
Error creating thumbnail: Unable to save thumbnail to destination FTDI (FTD2XX)
Simulation only interface to allow communications with a FTDI USB 232 IC connected to the system. |
Error creating thumbnail: Unable to save thumbnail to destination I2C Master
Generic Two Wire I2C Communications Interface |
Error creating thumbnail: Unable to save thumbnail to destination I2C Slave
Error creating thumbnail: Unable to save thumbnail to destination One Wire
Low level routines for controlling or interacting with a standard one wire interface. |
Error creating thumbnail: Unable to save thumbnail to destination UART (RS232)
Low level routines for controlling or interacting with a standard asyncronous serial interface. |
Error creating thumbnail: Unable to save thumbnail to destination Base 64
Component to allow base 64 encoding and decoding. |
Error creating thumbnail: Unable to save thumbnail to destination Network Communications
A component designed to simplify the process of TCP/IP communications. |
Error creating thumbnail: Unable to save thumbnail to destination TCP Template
Base TCP/IP component with simulation only interface to allow TCP/IP style network communications in simulation. |
A set of routines used to control a ENC28J60 TCP/IP Module. |
TCP/IP sockets component for use with Raspberry Pi. |
Error creating thumbnail: Unable to save thumbnail to destination Webserver (NM7010A)
Error creating thumbnail: Unable to save thumbnail to destination DALI Master
A serial based communications protocol designed for controlling lighting, specifically digitally |
Error creating thumbnail: Unable to save thumbnail to destination DALI Slave
Error creating thumbnail: Unable to save thumbnail to destination DMX_512 Master
A serial based communications protocol designed for controlling theatrical equipment such |
Error creating thumbnail: Unable to save thumbnail to destination DMX_512 Slave
Provides 16 digital input/output pins arranged into two 8-bit ports using a I2C bus connection. |
Provides 16 digital input/output pins arranged into two 8-bit ports using a SPI bus connection. |
Error creating thumbnail: Unable to save thumbnail to destination MIDI
Low level routines for controlling or interacting with a standard MIDI interface. |
Error creating thumbnail: Unable to save thumbnail to destination MULTIUART
Uses a high speed SPI connection to enable up to four buffered external UARTs via the MULTIUART modules. |
Error creating thumbnail: Unable to save thumbnail to destination Modbus Master
Modbus component for talking to Modbus compatible hardware via RS232 or RS485. |
Error creating thumbnail: Unable to save thumbnail to destination Modbus Slave
Modbus component for creating Modbus compatible slave hardware via RS232 or RS485. |
Error creating thumbnail: Unable to save thumbnail to destination Visi (4DSystems)
A way of interacting with the VISI interface designed by 4D systems. |
Error creating thumbnail: Unable to save thumbnail to destination USB HID
Component to create and communicate using a standard HID type USB class. |
Error creating thumbnail: Unable to save thumbnail to destination USB MIDI
Component to create and communicate using a standard MIDI connection. |
Error creating thumbnail: Unable to save thumbnail to destination USB Serial
Component to create and communicate using a standard CDC type COM port. |
Error creating thumbnail: Unable to save thumbnail to destination USB Slave
Component to create and communicate using a generic USB communications profile. |
Error creating thumbnail: Unable to save thumbnail to destination Data Injector Template
A base data injector used as a placeholder in components which reference the data injector interface. |
Error creating thumbnail: Unable to save thumbnail to destination Bluetooth (EB024, Generic AT)
Low level routines for controlling a standard AT Bluetooth interface. |
Error creating thumbnail: Unable to save thumbnail to destination Bluetooth (HC05 HC06)
Low level routines for controlling or interacting with a HC05 or HC06 Bluetooth module. |
Error creating thumbnail: Unable to save thumbnail to destination Bluetooth v2 (EB024, Generic AT)
Error creating thumbnail: Unable to save thumbnail to destination GPS (EB056, Generic NMEA)
Component designed to process incoming NMEA style GPS data and convert into meaningful |
Error creating thumbnail: Unable to save thumbnail to destination GSM (EB066, Generic AT)
Low level routines for controlling a standard AT GSM / GPRS interface |
Error creating thumbnail: Unable to save thumbnail to destination IrDA (EB012, MCP1250, MCP2120)
Low level routines for controlling a standard IrDA interface. |
Error creating thumbnail: Unable to save thumbnail to destination RC5 (EB060, Generic 36KHz)
Low level routines for controlling a standard RC5 IR interface. |
Error creating thumbnail: Unable to save thumbnail to destination RF 2.4GHz
A simple RF communications module based on the 2. |
Error creating thumbnail: Unable to save thumbnail to destination RF ISM (EB063, MRF49XA)
A simple RF-ISM communications module based on the Microchip Alpha MRF49XA device. |
Error creating thumbnail: Unable to save thumbnail to destination RFID (EB052, RWD_MICODE)
Low level routines for controlling a RF Solutions RFID interface |
Error creating thumbnail: Unable to save thumbnail to destination RFID (MFRC522)
Functions designed to work with the MFRC522 contactless reader IC. |
Error creating thumbnail: Unable to save thumbnail to destination SRF (WirelessThings)
The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module. |
Error creating thumbnail: Unable to save thumbnail to destination WLAN (EB069, ESP8266)
Wireless LAN component designed to work with the ESP8266 module. |
Error creating thumbnail: Unable to save thumbnail to destination WLAN (EB069, WIZ610wi)
Wireless LAN component designed to work with the WIZ610wi module from Wiznet. |
Error creating thumbnail: Unable to save thumbnail to destination Zigbee (EB051, XBEE)
Zigbee component designed to work with the XBEE range of modules from Digi. |
Error creating thumbnail: Unable to save thumbnail to destination Auto Version Identifier
Basic component designed to provide the program with the date and time of the build. |
Error creating thumbnail: Unable to save thumbnail to destination Circular Buffer
Circular buffer component allowing easy and efficient first in first out (FIFO) style data byte storage. |
Error creating thumbnail: Unable to save thumbnail to destination EEPROM
A means of reading data from and writing data to the EEPROM memory onboard the microcontroller. |
Error creating thumbnail: Unable to save thumbnail to destination Embed File
A component to simplify the process of embedding files into ROM. |
Error creating thumbnail: Unable to save thumbnail to destination FAT (SD, SDHC)
FAT component allowing access to read and write files on a SD, SDHC or MMC card. |
Error creating thumbnail: Unable to save thumbnail to destination Lookup tables
A lookup-table component allowing an easy way to place arrays of static data into ROM memory. |
Error creating thumbnail: Unable to save thumbnail to destination RTC (MCP7940N)
Serial (I2C) Real Time Clock component for MCP7940N device. |
Error creating thumbnail: Unable to save thumbnail to destination Real Time Clock (RTC)
A Real Time Clock component allowing things like clocks and timers to easily be created. |
Error creating thumbnail: Unable to save thumbnail to destination Serial EEPROM (24C16)
Serial (I2C) EEPROM component for 24C01 to 24C16 |
Error creating thumbnail: Unable to save thumbnail to destination Serial EEPROM (24C32)
Serial (I2C) EEPROM component for 24C32 |
Error creating thumbnail: Unable to save thumbnail to destination String Translator
A simple component to allow multiple language support by substituting different strings depending |
Error creating thumbnail: Unable to save thumbnail to destination Timer
Allows you to measure the passage of time via the use of a hardware timer peripheral. |
Error creating thumbnail: Unable to save thumbnail to destination 3D Printer
A simulation only version of a very basic 3D printer such as a standard RepRap. |
Error creating thumbnail: Unable to save thumbnail to destination AllCode Robot Arm
Matrix 5-axis Robot Arm with Gripper. |
Error creating thumbnail: Unable to save thumbnail to destination Formula AllCode
A component to allow all the features of the Formula AllCode robot to be investigated. |
Error creating thumbnail: Unable to save thumbnail to destination Formula AllCode API
A simulation only component to allow the Formula AllCode robot to be controlled via it's |
Error creating thumbnail: Unable to save thumbnail to destination Formula Flowcode
A component to allow all the features of the Formula Flowcode robot to be investigated. |
Error creating thumbnail: Unable to save thumbnail to destination Motor Template
Base component for constructing continuous motion - e. |
Error creating thumbnail: Unable to save thumbnail to destination Servo Controller
Can control up to eight standard PWM driven servo's. |
Error creating thumbnail: Unable to save thumbnail to destination Servo Motor Template
Base component for creating custom servo motor simulations. |
Error creating thumbnail: Unable to save thumbnail to destination Solenoid Template
Base component for constructing solenoids. |
Error creating thumbnail: Unable to save thumbnail to destination Stepper Motor Template
Enables the creation of a stepper motor component by specifying objects for its appearance. |
Error creating thumbnail: Unable to save thumbnail to destination MIAC (Arduino_Compatible)
MIAC - Matrix Industrial Automotive Controller (Arduino-Compatible) |
Error creating thumbnail: Unable to save thumbnail to destination MIAC (PIC)
MIAC - Matrix Industrial Automotive Controller |
Error creating thumbnail: Unable to save thumbnail to destination MIAC (dsPIC)
MIAC - Matrix Industrial Automotive Controller (dsPIC) |
Error creating thumbnail: Unable to save thumbnail to destination MIAC (PIC) CAN Slave
MIAC Slave for MIAC System. |
Error creating thumbnail: Unable to save thumbnail to destination MIAC Advanced
Advanced Addon for MIAC System |
Error creating thumbnail: Unable to save thumbnail to destination MIAC Basic
Basic Addon expansion module for MIAC System |
Error creating thumbnail: Unable to save thumbnail to destination MIAC Bluetooth
Bluetooth Addon for MIAC System |
Error creating thumbnail: Unable to save thumbnail to destination MIAC GPS
GPS Addon expansion module for MIAC System |
Error creating thumbnail: Unable to save thumbnail to destination MIAC GSM
GSM Addon for MIAC System. |
Error creating thumbnail: Unable to save thumbnail to destination MIAC Industrial
MIAC Industrial Addon component for MIAC System. |
Error creating thumbnail: Unable to save thumbnail to destination MIAC Serial
Serial Addon expansion module for MIAC System |
Error creating thumbnail: Unable to save thumbnail to destination MIAC Zigbee Coordinator
MIAC Zigbee Coordinator Addon component for MIAC System. |
Error creating thumbnail: Unable to save thumbnail to destination MIAC Zigbee Router
MIAC Zigbee Router Addon component for MIAC System. |
Error creating thumbnail: Unable to save thumbnail to destination MIAC (PIC) USB Slave
Allows Matrix's MIAC PLC to be used as a PC peripheral controlled by Flowcode via a USB |
Error creating thumbnail: Unable to save thumbnail to destination MIAC AllCode
MIAC AllCode. |
Error creating thumbnail: Unable to save thumbnail to destination Control
Allows for several types of control operations to be performed on a buffer. |
Error creating thumbnail: Unable to save thumbnail to destination DSP System
DSP System main buffer manager responsible for allocating memory, taking care of buffer indexes ... |
Error creating thumbnail: Unable to save thumbnail to destination Delay
Allows an adjustable delay to be inserted into the DSP system |
Error creating thumbnail: Unable to save thumbnail to destination Fast Fourier Transform (FFT)
Provides a way of converting a buffer full of time domain data into frequency domain data. |
Error creating thumbnail: Unable to save thumbnail to destination Filter
Filter component to allow basic filtering to be performed |
Error creating thumbnail: Unable to save thumbnail to destination Frequency Generator
A frequency generator component designed to plug into the DSP system component and allow several... |
Error creating thumbnail: Unable to save thumbnail to destination Input
Allows the values from a buffer to be assigned. |
Error creating thumbnail: Unable to save thumbnail to destination Level
Allows for detection and collection of peaks, troughs and averages. |
Error creating thumbnail: Unable to save thumbnail to destination Output
Allows the values from a buffer to be read. |
Error creating thumbnail: Unable to save thumbnail to destination Scale
Allows the values in a single buffer to be scaled uniformly. |
Error creating thumbnail: Unable to save thumbnail to destination Sum
Component to combine together two DSP buffers into one an index at a time. |
Error creating thumbnail: Unable to save thumbnail to destination Animator
Basic animation and physics simulation for a single object. |
Error creating thumbnail: Unable to save thumbnail to destination Motion Helper
Helper for building components which require simulation of constant motion. |
Error creating thumbnail: Unable to save thumbnail to destination Formula Flowcode Racetrack
A simple race course for the Formula Flowcode buggy. |
Error creating thumbnail: Unable to save thumbnail to destination Maze Generator
Creates a simulation only randomised maze out of standard micromouse maze walls and pillars. |
Error creating thumbnail: Unable to save thumbnail to destination Meter Square
Square analogue panel meter. |
Error creating thumbnail: Unable to save thumbnail to destination Simulation External Input
A simulation only component designed to allow a single digital pin to be toggled at a set frequency. |
Error creating thumbnail: Unable to save thumbnail to destination Simulation LED
A simple LED suitable for simulation that does not require a pin connection |
Error creating thumbnail: Unable to save thumbnail to destination Simulation Switch Template
A base for building switches that do not download to chip. |
Error creating thumbnail: Unable to save thumbnail to destination Time Stamp
A simple simulation component to collect the current system timestamp as a string. |
Error creating thumbnail: Unable to save thumbnail to destination Airplane Landing Gear
A simulation of an Airplane Landing Gear containing, switches, locking mechanisms and retracting landing gear. |
Error creating thumbnail: Unable to save thumbnail to destination CNC Machine
A CNC Machine that allows for simulation movement in the X, Y, Z directions and also providing access to the Drill. |
Error creating thumbnail: Unable to save thumbnail to destination Car Seat
An electric car seat chassis with a series of motors and sensors. |
Error creating thumbnail: Unable to save thumbnail to destination Pedestrian Crossing
A set of pedestrian crossing lights complete with manual light control, a simple state machine and an |
Error creating thumbnail: Unable to save thumbnail to destination Sheep Pen
A simple sheep pen simulation with two gates and two sensors. |
Error creating thumbnail: Unable to save thumbnail to destination Traffic Light 1_Way
A set of one way traffic lights complete with manual light control, a simple state machine and an |
Error creating thumbnail: Unable to save thumbnail to destination Traffic Light 2_Way
A set of two way traffic lights complete with manual light control, a simple state machine and an |
Error creating thumbnail: Unable to save thumbnail to destination K8055D
Support for the Velleman K8055 USB input/output board. |
Error creating thumbnail: Unable to save thumbnail to destination PicoScope
A set of functions designed for interacting with a 2000 series Pico scope via simulation. |
Error creating thumbnail: Unable to save thumbnail to destination TTI TG5011 Signal Generator
TTi TG5011 50 MHz Signal Generator |
Error creating thumbnail: Unable to save thumbnail to destination TTi Power Supply _ PL155_P
TTi PL155-P Power Supply Unit Component. |
Error creating thumbnail: Unable to save thumbnail to destination COM Port
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial. |
Error creating thumbnail: Unable to save thumbnail to destination Console Debugger
Component to allow printing debug messages to the Raspberry Pi Console. |
Error creating thumbnail: Unable to save thumbnail to destination Device Helper
A purely cosmetic component for viewing the details specific to your current selected target microcontroller. |
Error creating thumbnail: Unable to save thumbnail to destination E_block Helper
A purely cosmetic component to help simplify E-block connections without having to keep referring to the datasheets. |
Error creating thumbnail: Unable to save thumbnail to destination FCD helper
A helper control to query the current FCD file |
Error creating thumbnail: Unable to save thumbnail to destination IntOsc Helper
A component to help configure the speed of the internal oscillator. |
Error creating thumbnail: Unable to save thumbnail to destination Scope monitor
A component to allow data from analogue and digital pins to be displayed on the scope window. |
Error creating thumbnail: Unable to save thumbnail to destination Serial Monitor
Allows data from a COM port to be piped through to the console window for easy program status and debugging. |
Error creating thumbnail: Unable to save thumbnail to destination Clone Matrix
Takes a single object and produces a three dimensional array of evenly spaced clones. |
CAL - Code Abstraction Layer |
Error creating thumbnail: Unable to save thumbnail to destination Ellipse
A basic ellipse primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Label
A basic text label. |
Error creating thumbnail: Unable to save thumbnail to destination Line
A basic line primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Rectangle
A basic rectangle primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Rounded rectangle
A basic rounded rectangle primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Textbox
A basic textbox. |
Error creating thumbnail: Unable to save thumbnail to destination Bowl
A basic bowl primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Cone
A basic cone primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Cuboid
A basic cuboid primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Cylinder
A basic cylinder primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Diamond
A basic diamond primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Hemisphere
A basic hemisphere primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Honeycomb
A basic honeycomb primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Prism
A basic prism primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Pyramid
A basic pyramid primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Sphere
A basic sphere primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Tube
A basic tube primitive shape. |
Error creating thumbnail: Unable to save thumbnail to destination Bezel Radiused
A purely cosmetic component for creating smoothly radiused bezel or frame to fit around |
Error creating thumbnail: Unable to save thumbnail to destination Component Label
Add a label to a component by including this component as a sub-component. |
Error creating thumbnail: Unable to save thumbnail to destination Component Labels
Automatically generates labels for all panel objects and components in a given context. |
Error creating thumbnail: Unable to save thumbnail to destination Dashboard Text
A simulation only text box that can be used to display text and numbers. |
Error creating thumbnail: Unable to save thumbnail to destination Marking control
A control to draw markings on any component |
Error creating thumbnail: Unable to save thumbnail to destination Panel Console Viewer
An easy way to display the data from up to four console windows on the panel. |
Error creating thumbnail: Unable to save thumbnail to destination RxTx Flasher
Simple indicator panel intended as a sub-component of communications components. |
Error creating thumbnail: Unable to save thumbnail to destination Scale Arc Template
A base component for drawing circular dials. |
Error creating thumbnail: Unable to save thumbnail to destination Scale Linear Template
A base component for drawing scales on horizontal or vertical strips. |
Error creating thumbnail: Unable to save thumbnail to destination Slider control
A simple graphical interface for a vertical meter or slider control. |
Error creating thumbnail: Unable to save thumbnail to destination Target Chip
A cosmetic only representation of the target microcontoller device showing the default package type complete with pins. |
Error creating thumbnail: Unable to save thumbnail to destination Wood Fence
A simple wooden fence used to create simple walls and pens for simulations. |
Error creating thumbnail: Unable to save thumbnail to destination Wood Gate
A simple gate that can be opened and closed via simulation macros. |
