Components
Revision as of 14:50, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Inputs
Inputs: Analog
Error creating thumbnail: Unable to save thumbnail to destination
ADC Template
Base ADC component with no graphical interface.
Inputs: General
Encoder Rotary
Encoder component implements a rotary encoder connected to two pins
Touch Pads (EB088)
This board provides five touch areas for use with capacitive sensing.
Inputs: Keypads
Keypad (Generic)
Generic component to create a raster scanned custom keypad or button matrix.
Inputs: Switches
Switch Array Template
A base component for creating an evenly spaced array of switches.
Switch Template
Base single pin switch with no graphical interface
Outputs
Outputs: General
Buzzer
Drives a simple fixed frequency buzzer in hardware and simulates the sound of a buzzer in simulation.
DAC Output
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips.
PWM
Pulse Width Modulation, a versitile way of generating a digital pulse using mark / space modulation.
Piezo Sounder
Drives a simple variable frequency piezo sounder in hardware and simulates the sound in simulation.
Speech
Speech component allowing Phoneme based speech for use on an embedded platform.
Outputs: LEDs
LED (Generic, RGB)
An LED with red, green and blue elements that can be mixed together to produce
LED Array Template
Create an evenly spaced array of LED indicators.
LED Charlieplex
Create an evenly spaced array of LED indicators using a reduced amount of I/O pins.
LED Cube
LED Cube component for driving 3D arrays of LEDs.
LED Matrix (HT16K33)
LED Matrix component designed to work using a HT16K33 LED driver IC.
LED Matrix (Parallel)
LED Matrix component designed to work using multiple data pins and a single clock pin.
LED Matrix (Serial)
LED Matrix component designed to work using a single data and clock pin.
LED MultiColour Bi (5mm, PCB)
An industry standard 5mm diameter bi-colour LED.
LED MultiColour Tri (5mm, PCB)
An industry standard 5mm diameter tri-colour LED.
LED Template
Base for creating LEDs and other on/off visual indicators.
NeoPixel LED APA102C
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream.
NeoPixel LED WS2801
NeoPixel LED WS2811 WS2812 APA106
RGB Xmas Tree
Component complete with macros and simultion to drive the MatrixTSL RGB Xmas Tree decoration.
Displays
Displays: Alphanumeric
LCD (Adafruit, OLED)
Adafruit OLED LCD display
LCD (Generic)
Generic configurable alphanumeric LCD display component based on the standard
LCD 4x20 (Adafruit, OLED)
Adafruit OLED LCD display 4 x 20 characters
Displays: Graphical
Bitmap Drawer FAT
A component to simplify the process of drawing bitmap images to a graphical display.
Bitmap Drawer ROM
GLCD Base
Base graphical LCD with simulation only interface to allow graphics to be drawn in simulation.
GLCD Graph Creator
A component to simplify the process of drawing graphs and charts using a graphical LCD.
GLCD Textfield
A component to simplify the process of drawing text to a graphical display.
Touch Screen (XPT2046)
Low level routines for controlling or interacting with the XPT2046 touch screen controller IC found
Displays: Segment
7Segment (Quad)
14mm seven segment display.
7Segment (Single)
Seven segment display modelled after a standard 14mm high unit.
Starburst Display
Starburst 14 or 16 segment display modelled after a standard 14mm high unit.
Sensors
Sensors
Accel Gyro 6_Axis (MPU-6050)
MPU-6050 Combined 6-Axis Accelerometer and Gyroscope sensors.
Accel Gyro Mag 9_Axis (MPU9250)
MPU9250 Combined 9-Axis Accelerometer, Gyroscope and Magnetometer sensors
Accel Mag 6_Axis (LSM303D)
LSM303D Combined 6-Axis Accelerometer and Magnetometer sensors
Accel Mag 6_Axis (LSM303DLHC)
LSM303DLHC Combined 6-Axis Accelerometer and Magnetometer sensors
Accelerometer 3_Axis (LIS3LV02DQ)
LIS3LV02DQ Accelerometer sensor with options for I2C or SPI communications.
Barometer (BME280)
A small PCB surface mount barometric pressure sensor with a I2C bus interface.
Barometer (MS5637)
Collision Detector Template
Polls a chosen panel object to see if it has collided with another object.
Colour Sensor (TCS3200)
This board provides the ability to detect colours using the TCS3200 sensor.
Gyroscope 3_Axis (L3G4200D)
Interface to the L3G4200D three axis digital gyroscope.
Gyroscope 3_Axis I2C (L3GD20)
Interface to the L3GD20 three axis digital gyroscope.
Gyroscope 3_Axis SPI (L3GD20)
Allows access to a three axis digital gyroscope via an SPI interface.
Hall Effect Analog
Simple analogue hall effect triggered by the proximity of another object.
Hall Effect Digital
Simple digital hall effect on off switch triggered by the proximity of another object.
Humidity (SHT21)
Humidity and temperature sensor using an SHT21 IC connected via I2C.
Infrared Array AMG88xx
An 8x8 (64) Pixel infrared sensor array allowing basic none contact temperature detection.
Photo Reflector
Uses InfraRed light to detect if an external object is near to the sensor.
Photo Transistor
Proximity Analog Template
Polls a chosen panel object to test it's distance from this component.
Proximity Switch Template
Reed Switch
Simple on off switch triggered by the proximity of another object.
Temp Humidity (DHT11 )
The DHT11 temperature and humidity sensor is a popular sensor allowing the ambient
Temp Humidity (DHT22 )
The DHT22 temperature and humidity sensor is a popular sensor allowing the ambient
Temperature (LM75B)
A digital temperature sensor based around the NXP LM75B chip.
Thermistor
A generic thermistor component that can be used to simulate and create code for any
Thermistor Template
Base component for creating thermistors.
Grove
Accel Gyro 6_Axis LSM6DS3 (105020012)
Barometer BMP280 (101020192)
Barometric pressure sensor with a I2C bus interface.
Chainable RGB LED v2.0 (104020048)
Grove-Chainable RGB LED V2.
Grove Water Sensor (101020018)
The water sensor uses a 1M ohm pull-up resistor.
I2C Color Sensor (101020341)
Based on the color sensor TCS34725FN with digital output I2C.
Infrared Reflective Sensor (101020174) (101020174)
LED Bar v2.0 (104020006)
LED Bar is comprised of a 10 segment LED gauge bar and an MY9221 LED controlling chip.
PIR Motion BISS0001 (101020020)
PIR motion sensor component for digital output sensors.
Relay (103020005)
The Relay is a digital normally open switch capable of switching much higher voltages and curren...
Sound Sensor (101020023)
The Sound sensor module is a simple microphone.
Temp Humidity DHT22 (101020019)
Temperature Sensor (101020015)
Temperature Sensor uses a thermistor to measure ambient temperature.
Ultrasonic Ranger (101020010)
The ultrasonic sensor is a non-contact distance measurement module.
E-blocks
E-blocks 1
Accelerometer (EB068)
Combo Board (EB083)
A simulated version of the EB083 Combo board including LEDs, Switches, LCD, 7-Segs
GLCD (EB057 / EB058)
Graphical display component designed to work with the EB057 modules and EB058 E-blocks.
Keypad (EB014)
Preset keypad based around the 3 * 4 unit, as used by the Matrix EB014 E-block
LCD (EB005)
LCD based on the unit used in the Matrix EB005 E-block
LED (EB004)
An LED matrix made up of standard PCB mount 5mm LEDs.
SPI Master (EB013)
Low level routines for controlling or interacting with an SPI interface.
Switch (EB007)
An array of up to eight momentary push switches, each connected to a single pin of the specified port.
TCPIP (EB023 v1)
TCP/IP component designed to work with the WIZ3100 range of modules from Wiznet.
TCPIP (EB023 v2)
TCP/IP component designed to work with the WIZ810MJ module from Wiznet,
Webserver (EB023 v1)
Webserver component designed to work with the NM7010A module from Wiznet,
Webserver (EB023 v2)
Webserver component designed to work with the WIZ810MJ module from Wiznet,
E-blocks 2
Combo (BL0114)
A component to drive the BL0114 Combo board including LEDs, Switches, LCD, 7-Segs
GLCD (BL0139)
Graphical display component designed to work with the ST7567 type monochrome displays.
IO Expander (BL0155)
Provides 16 digital input/output pins arranged into two 8-bit E-block 2 ports using a SPI bus connection.
LCD (BL0169)
LCD component to drive the E-blocks 2 BL0169 LCD board.
LED (BL0167)
LED component to drive the E-blocks 2 BL0167 LED board.
Servo Motor (BL0162)
Servo motor component to drive the E-blocks 2 BL0162 Servo Motors board.
EBM Modules
Accel Mag 6_Axis (EBM015)
EBM015 Combined 6-Axis Accelerometer and Magnetometer sensors
Colour Sensor (EBM018)
Digital Temperature (EBM004)
A digital temperature sensor based around the LM75B chip.
Dual Potentiometer _ Trimmer (EBM006)
This board provides two rotary potentiometers.
GLCD (EBM001)
Graphical display component designed to work with the EBM001 modules and EB084 E-blocks.
Gyroscope (EBM009)
Hall Effect (EBM011)
The board has a Hall Effect sensor (SL353) that gives a digital output in the presence of a magnetic field (in the region
Humidity (EBM016)
Humidity and temperature sensor using an SHT21 IC connected via I2C - as used by the
Infrared (EBM020)
The Infrared sensor board contains both an IR transmitter and receiver.
PIR (EBM012)
This board provides a PIR sensor which is read as a digital input.
Potentiometer (EBM002)
This board consists of a standard shaft rotary potentiometer that provides a linear voltage
Rotary Encoder (EBM007)
Provides a rotary encoder with dual digital outputs that provide rotation and direction information.
Thermistor (EBM003)
Thermocouple TypeK (EBM008)
A component matchin the Matrix EBM008 thermocouple board.
Touch Pads (EBM013)
This board provides two touch areas for use with capacitive sensing.
Touch Slider (EBM014)
This board provides two touch slide areas for use with capacitive sensing.
Ultrasonic (EBM019)
This board has both an ultrasonic transmitter and receiver.
Comms
Comms: Interface
CAN (Internal, MCP2515)
Low level routines for controling the CAN interface either using an external MCP2515 IC and a SPI bus connection
FTDI (FTD2XX)
Simulation only interface to allow communications with a FTDI USB 232 IC connected to the system.
I2C Master
I2C Slave
One Wire
Low level routines for controlling or interacting with a standard one wire interface.
SPI Master
UART (RS232)
Low level routines for controlling or interacting with a standard asyncronous serial interface.
Comms: Networking
Base 64
Component to allow base 64 encoding and decoding.
Network Communications
A component designed to simplify the process of TCP/IP communications.
TCP Template
Base TCP/IP component with simulation only interface to allow TCP/IP style network communications in simulation.
TCPIP (ENC28J60)
A set of routines used to control a ENC28J60 TCP/IP Module.
TCPIP (NM7010A)
TCPIP (Raspberry Pi)
TCP/IP sockets component for use with Raspberry Pi.
TCPIP (WIZ810MJ)
Webserver (NM7010A) (NM7010A)
Webserver (WIZ810MJ)
Comms: System
DALI Master
A serial based communications protocol designed for controlling lighting, specifically digitally
DALI Slave
DMX_512 Master
A serial based communications protocol designed for controlling theatrical equipment such
DMX_512 Slave
IO Expander (MCP23017)
Provides 16 digital input/output pins arranged into two 8-bit ports using a I2C bus connection.
IO Expander (MCP23S17)
Provides 16 digital input/output pins arranged into two 8-bit ports using a SPI bus connection.
MIDI
Low level routines for controlling or interacting with a standard MIDI interface.
Modbus Master
Modbus component for talking to Modbus compatible hardware via RS232 or RS485.
Modbus Slave
Modbus component for creating Modbus compatible slave hardware via RS232 or RS485.
Visi (4DSystems)
A way of interacting with the VISI interface designed by 4D systems.
Comms: USB
USB HID
Component to create and communicate using a standard HID type USB class.
USB MIDI
Component to create and communicate using a standard MIDI connection.
USB Serial
Component to create and communicate using a standard CDC type COM port.
USB Slave
Component to create and communicate using a generic USB communications profile.
Injectors
Data Injector Template
A base data injector used as a placeholder in components which reference the data injector interface.
Wireless
Bluetooth (EB024, Generic AT)
Low level routines for controlling a standard AT Bluetooth interface.
Bluetooth (HC05 HC06)
Low level routines for controlling or interacting with a HC05 or HC06 Bluetooth module.
Bluetooth v2 (EB024, Generic AT)
GPS (EB056, Generic NMEA)
Component designed to process incoming NMEA style GPS data and convert into meaningful
GSM (EB066, Generic AT)
Low level routines for controlling a standard AT GSM / GPRS interface
IrDA (EB012, MCP1250, MCP2120)
Low level routines for controlling a standard IrDA interface.
RC5 (EB060, Generic 36KHz)
Low level routines for controlling a standard RC5 IR interface.
RF 2.4GHz (nRF24L01)
A simple RF communications module based on the 2.
RF ISM (EB063, MRF49XA)
A simple RF-ISM communications module based on the Microchip Alpha MRF49XA device.
RFID (EB052, RWD_MICODE)
Low level routines for controlling a RF Solutions RFID interface
RFID (MFRC522)
Functions designed to work with the MFRC522 contactless reader IC.
SRF (WirelessThings) (SRF)
The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module.
WLAN (EB069, ESP8266) (ESP8266)
Wireless LAN component designed to work with the ESP8266 module.
WLAN (EB069, WIZ610wi)
Wireless LAN component designed to work with the WIZ610wi module from Wiznet.
Zigbee (EB051, XBEE) (XBEE)
Zigbee component designed to work with the XBEE range of modules from Digi.
Storage
Auto Version Identifier
Basic component designed to provide the program with the date and time of the build.
Circular Buffer
Circular buffer component allowing easy and efficient first in first out (FIFO) style data byte storage.
EEPROM
A means of reading data from and writing data to the EEPROM memory onboard the microcontroller.
Embed File
A component to simplify the process of embedding files into ROM.
FAT (SD, SDHC)
FAT component allowing access to read and write files on a SD, SDHC or MMC card.
Lookup tables
A lookup-table component allowing an easy way to place arrays of static data into ROM memory.
RTC (MCP7940N)
Serial (I2C) Real Time Clock component for MCP7940N device.
Real Time Clock (RTC)
A Real Time Clock component allowing things like clocks and timers to easily be created.
Serial EEPROM (24C16)
Serial (I2C) EEPROM component for 24C01 to 24C16
Serial EEPROM (24C32)
Serial (I2C) EEPROM component for 24C32
String Translator
A simple component to allow multiple language support by substituting different strings depending
Timer
Allows you to measure the passage of time via the use of a hardware timer peripheral.
Mechatronics
3D Printer
A simulation only version of a very basic 3D printer such as a standard RepRap.
AllCode Robot Arm
Matrix 5-axis Robot Arm with Gripper.
Formula AllCode (RB4420)
A component to allow all the features of the Formula AllCode robot to be investigated.
Formula AllCode API
A simulation only component to allow the Formula AllCode robot to be controlled via it's
Formula Flowcode
A component to allow all the features of the Formula Flowcode robot to be investigated.
Motor Template
Base component for constructing continuous motion - e.
Servo Controller
Can control up to eight standard PWM driven servo's.
Servo Motor Template
Base component for creating custom servo motor simulations.
Solenoid Template
Base component for constructing solenoids.
Stepper Motor Template
Enables the creation of a stepper motor component by specifying objects for its appearance.
MIAC
MIAC Module
MIAC (Arduino_Compatible) (MIAC (Arduino-Compatible))
MIAC - Matrix Industrial Automotive Controller (Arduino-Compatible)
MIAC (PIC)
MIAC (dsPIC) (MIAC (dsPIC))
MIAC - Matrix Industrial Automotive Controller (dsPIC)
MIAC: Addon Modules
MIAC (PIC) CAN Slave
MIAC Slave for MIAC System.
MIAC Advanced
Advanced Addon for MIAC System
MIAC Basic
Basic Addon expansion module for MIAC System
MIAC Bluetooth
Bluetooth Addon for MIAC System
MIAC GPS
GPS Addon expansion module for MIAC System
MIAC GSM
GSM Addon for MIAC System.
MIAC Industrial
MIAC Industrial Addon component for MIAC System.
MIAC Serial
Serial Addon expansion module for MIAC System
MIAC Zigbee Coordinator
MIAC Zigbee Coordinator Addon component for MIAC System.
MIAC Zigbee Router
MIAC Zigbee Router Addon component for MIAC System.
MIAC: PC Peripheral
MIAC (PIC) USB Slave
Allows Matrix's MIAC PLC to be used as a PC peripheral controlled by Flowcode via a USB
MIAC AllCode
MIAC AllCode.
DSP
Control
Allows for several types of control operations to be performed on a buffer.
DSP System
DSP System main buffer manager responsible for allocating memory, taking care of buffer indexes ...
Delay
Allows an adjustable delay to be inserted into the DSP system
Fast Fourier Transform (FFT)
Provides a way of converting a buffer full of time domain data into frequency domain data.
Filter
Filter component to allow basic filtering to be performed
Frequency Generator
A frequency generator component designed to plug into the DSP system component and allow several...
Input
Allows the values from a buffer to be assigned.
Level
Allows for detection and collection of peaks, troughs and averages.
Output
Allows the values from a buffer to be read.
Scale
Allows the values in a single buffer to be scaled uniformly.
Sum
Component to combine together two DSP buffers into one an index at a time.
Animation
Animator
Basic animation and physics simulation for a single object.
Motion Helper
Helper for building components which require simulation of constant motion.
Formula Flowcode Racetrack (HP458)
A simple race course for the Formula Flowcode buggy.
Maze Generator (HP458)
Creates a simulation only randomised maze out of standard micromouse maze walls and pillars.
Meter Square
Square analogue panel meter.
Simulation External Input
A simulation only component designed to allow a single digital pin to be toggled at a set frequency.
Simulation LED 3mm
A single LED 3mm for sim only
Simulation LED SMD
A simple LED suitable for simulation that does not require a pin connection
Simulation Switch Template
A base for building switches that do not download to chip.
Time Stamp
A simple simulation component to collect the current system timestamp as a string.
Scenarios
Airplane Landing Gear
A simulation of an Airplane Landing Gear containing, switches, locking mechanisms and retracting landing gear.
CNC Machine
A CNC Machine that allows for simulation movement in the X, Y, Z directions and also providing access to the Drill.
Car Seat
An electric car seat chassis with a series of motors and sensors.
Pedestrian Crossing
A set of pedestrian crossing lights complete with manual light control, a simple state machine and an
Sheep Pen
A simple sheep pen simulation with two gates and two sensors.
Traffic Light 1_Way
A set of one way traffic lights complete with manual light control, a simple state machine and an
Traffic Light 2_Way
A set of two way traffic lights complete with manual light control, a simple state machine and an
Tools
3rd Party Equipment/Tools
K8055D
Support for the Velleman K8055 USB input/output board.
PicoScope (PS2000)
A set of functions designed for interacting with a 2000 series Pico scope via simulation.
TTI TG5011 Signal Generator (TG5011)
TTi TG5011 50 MHz Signal Generator
TTi Power Supply _ PL155_P (TTi PL155-P PSU)
TTi PL155-P Power Supply Unit Component.
Matrix Tools
COM Port
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial.
Console Debugger (Raspberry Pi)
Component to allow printing debug messages to the Raspberry Pi Console.
Device Helper
A purely cosmetic component for viewing the details specific to your current selected target microcontroller.
E_block Helper
A purely cosmetic component to help simplify E-block connections without having to keep referring to the datasheets.
FCD helper
A helper control to query the current FCD file
IntOsc Helper
A component to help configure the speed of the internal oscillator.
Scope monitor
A component to allow data from analogue and digital pins to be displayed on the scope window.
Serial Monitor
Allows data from a COM port to be piped through to the console window for easy program status and debugging.
Modelling Components
Clone Matrix
Takes a single object and produces a three dimensional array of evenly spaced clones.
Peripheral CAL
ADC (CAL)
CAL - Code Abstraction Layer
CAN (CAL)
EEPROM (CAL)
I2C (CAL)
PWM (CAL)
SPI (CAL)
UART (CAL)
Shapes
2D Shapes
Ellipse
A basic ellipse primitive shape.
A basic text label.
Line
A basic line primitive shape.
Rectangle
A basic rectangle primitive shape.
Rounded rectangle
A basic rounded rectangle primitive shape.
Textbox
A basic textbox.
3D Shapes
Bowl
A basic bowl primitive shape.
Cone
A basic cone primitive shape.
Cuboid
A basic cuboid primitive shape.
Cylinder
A basic cylinder primitive shape.
Diamond
A basic diamond primitive shape.
Hemisphere
A basic hemisphere primitive shape.
Honeycomb
A basic honeycomb primitive shape.
Prism
A basic prism primitive shape.
Pyramid
A basic pyramid primitive shape.
Sphere
A basic sphere primitive shape.
Tube
A basic tube primitive shape.
Advanced Shapes
Bezel Radiused
A purely cosmetic component for creating smoothly radiused bezel or frame to fit around
Component Label
Add a label to a component by including this component as a sub-component.
Component Labels
Automatically generates labels for all panel objects and components in a given context.
Dashboard Text
A simulation only text box that can be used to display text and numbers.
Marking control
A control to draw markings on any component
Panel Console Viewer
An easy way to display the data from up to four console windows on the panel.
RxTx Flasher
Simple indicator panel intended as a sub-component of communications components.
Scale Arc Template
A base component for drawing circular dials.
Scale Linear Template
A base component for drawing scales on horizontal or vertical strips.
Slider control
A simple graphical interface for a vertical meter or slider control.
Target Chip
A cosmetic only representation of the target microcontoller device showing the default package type complete with pins.
Wood Fence
A simple wooden fence used to create simple walls and pens for simulations.
Wood Gate
A simple gate that can be opened and closed via simulation macros.
