Recent Changes - Search:
<^< Set up the Flowchart | Course index | High Speed Simulation >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs ## Set up the Equipment ## Set up the Flowchart ##
Adding LED's ## High Speed Simulation ## Slowing it Down ## New Output ## Binary Numbers ## Converting Numbers ## Outputting Numbers ## A Short Test ## Working in Hex ## Downloading the Program * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Adding LEDs
<^< Set up the Flowchart | Course Index | High Speed Simulation >^>(:nl:)
# Click the 'Outputs' button in the Components toolbar and select the 'LED Array' component. It looks like this:
->Click or drag on the menu item to add a set of LED's on the System Panel.
->Click once on the component in the panel to select it and the properties pane will display component properties like this:
# On the 'Properties Panel' go to the 'Simulation' section and change the 'Count' property to '8' by typing in the box next to the property name.
# On the Properties Panel go to the 'Connections' section and change the 'Port' to 'PORTB' this also shows which port and bit is connected to the PICmicro chip.
# You can change the colour of the LED's by changing the 'Color' property under the 'LED appearence' section in the Properties Panel, make sure the 'Same Color' property is set to 'Yes' to change the whole LED Array or change the colour of each individual LED element separately.
(:nl:)(:table style="clear:both":)
Page last modified on July 22, 2013, at 08:46 AM
