Recent Changes - Search:
<^< Binary Numbers | Course index | Outputting Numbers >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs ## Set up the Equipment ## Set up the Flowchart ## Adding LED's ## High Speed Simulation ## Slowing it Down ## New Output ## Binary Numbers ##
Converting Numbers ## Outputting Numbers ## A Short Test ## Working in Hex ## Downloading the Program * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Converting Numbers
<^< Binary Numbers | Course Index | Outputting Numbers >^>(:nl:)
Let's pull some results out of the table given earlier:
Decimal numberSame number in binary
11
210
4100
81000
Each time the binary '1' moves one place to the left, it doubles in value in decimal. We can use this idea to convert from one system to the other.
Binary number Decimal value
16 8 4 2 1
1 1
1 0 2
1 0 0 4
1 0 0 0 8
so
1 1 1 7
1 0 0 1 9
1 0 1 0 0 20
1 1 1 1 1 31
Did you spot the method?
In any binary number, the bit at the left-hand end has the highest value. This is known as the Most Significant Bit, (MSB). The one at the right-hand end is worth least, and is the Least Significant Bit, (LSB). For example:
MSB LSB
1 0 0 1 0 1 1 1
(:nl:)(:table style="clear:both":)
Page last modified on August 22, 2011, at 02:24 PM
