Recent Changes - Search:
<^< Slowing it Down | Course index | Binary Numbers >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs ## Set up the Equipment ## Set up the Flowchart ## Adding LED's ## High Speed Simulation ## Slowing it Down ##
New Output ## Binary Numbers ## Converting Numbers ## Outputting Numbers ## A Short Test ## Working in Hex ## Downloading the Program * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
New Output
<^< Slowing it Down | Course Index | Binary Numbers >^>(:nl:)
# Right-click on the Output box, and choose 'Properties' or double-click the Output box to open up the Properties dialogue box again. Click once on the 'Variable or value' box. Change the number from 1 to 2. Click on OK to close the box.
# Run the simulation by clicking on the Run icon:
# Notice that the LED array has changed.
# Repeat step 1 putting different numbers in the 'Variable or value' box. Notice the effect on the LED array.
# What number do you have to output to make all the LED's light? Go to the next page to find out. (:nl:)(:table style="clear:both":)
Page last modified on May 02, 2013, at 03:43 PM
