Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs ## Set up the Equipment ## Set up the Flowchart ## Adding LED's ## High Speed Simulation ## Slowing it Down ## New Output ## Binary Numbers ## Converting Numbers ## Outputting Numbers ## A Short Test ## Working in Hex ## Downloading the Program * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login Set up the Flowchart<^< Set up the Equipment | Course Index | Adding LED's >^>(:nl:) # Start a new project by selecting 'File' and then clicking 'New' in the menu which appears (File > New). You will be presented with a choice of microcontrollers that you can develop programs for. Choose '16F1937' from the list. ![]() # You will now see your flowchart appears with a 'BEGIN' and 'END' icon. All flowcharts have these icons by default. Move the cursor over the 'Output' icon, # Move the cursor over the Output box, either double-click with the left mouse button or click with the right mouse button and choose 'Properties' from the menu that appears, by clicking once on it with the left mouse button. You will now see a dialogue box like this: ![]() # Move the cursor over the 0 in the Variable or value box and click once. This will highlight the '0' value. Change this value to '1'. # Move the cursor over the ![]() # Now click on the 'OK' button to close the box. (:nl:)(:table style="clear:both":)
Page last modified on May 08, 2013, at 01:20 PM
