Recent Changes - Search:
<^< Adding LED's | Course index | Slowing it Down >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs ## Set up the Equipment ## Set up the Flowchart ## Adding LED's ##
High Speed Simulation ## Slowing it Down ## New Output ## Binary Numbers ## Converting Numbers ## Outputting Numbers ## A Short Test ## Working in Hex ## Downloading the Program * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
<^< Adding LED's | Course Index | Slowing it Down >^>(:nl:)
So what you have you done so far?
* You inserted an Output box in the flowchart. * You set it up to deliver a value of 1 to Port B. * You connected eight LED's to the eight bits of Port B.
Congratulations: you have completed your first program. Now let's see what happens when you run a simulation of this program.
Click on the 'Run' icon, the blue arrow on the main toolbar. ->The Run icon looks like this:
->If you blinked, you missed it! ->The result is that the first LED lights, and there is a message saying that the simulation is completed.
What does it mean? The program outputted the number 1 and displayed it on the LED's. But you did not really see what happened. (:nl:)(:table style="clear:both":)
Page last modified on April 30, 2013, at 09:14 AM
