Recent Changes - Search:
<^< E-blocks Boards | Course index | Sensor Interface (EB003) >^>
E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards ##
E-blocks Documentation and Numbering ## Sensor Interface (EB003) ## LED Board (EB004) ## LCD Board (EB005) ## Multiprogrammer (EB006) ## Switch Board (EB007) ## Quad 7-segment Display (EB008) ## Keyboard (EB014) ## Prototype Board (EB016) ## Patch Board (EB017)
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
<^< E-blocks Boards | Course Index | Sensor Interface (EB003) >^>(:nl:)
E-blocks designs are in a constant process of development. Because of this you need to be aware of how the E-blocks product codes operate and where to go to find the correct information.
A typical part number for an E-block is: 'EBAAA-BB-C'. For example 'EB006-00-6'. Here:
'AAA' refers to the part number: '006' is the code for the Multiprogrammer, '003' is the code for the Sensor board.
BB refers to the item related to that part number. '00' is the code for the built and tested board, '30' is the code for the technical datasheet.
'C' refers to the version number. '1' is version 1, '6' is version 6.
At the time of writing the Multiprogrammer is currently on version 8. This means that the part number for the board is EB006-00-8 and the part number for the datasheet is EB006-30-8. The part numbers are displayed on your circuit board. If you are looking for technical datasheets on E-blocks please make sure you have the correct part number.
(:nl:)(:table style="clear:both":)
Page last modified on September 19, 2011, at 01:25 PM
