Recent Changes - Search:
<^< E-blocks Documentation and Numbering | Course index | LED Board (EB004) >^>
E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards ## E-blocks Documentation and Numbering ##
Sensor Interface (EB003) ## LED Board (EB004) ## LCD Board (EB005) ## Multiprogrammer (EB006) ## Switch Board (EB007) ## Quad 7-segment Display (EB008) ## Keyboard (EB014) ## Prototype Board (EB016) ## Patch Board (EB017)
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Sensor Interface EB003
<^< E-blocks Documentation and Numbering | Course Index | LED Board (EB004) >^>(:nl:)
EB003 Sensor Interface Board
More information can be found here.
EB003 Sensor Interface Block Diagram
* Click EB003-30-2 for the datasheet. * The male D-type connector fits into the female connector of one of the ports of an upstream board. * This board is developed for learning how to 'read' analogue inputs from analogue sensors and inputs from specific digital sensors. * The PICmicro can 'read' analogue voltages between VDD and VSS * The Analogue input is always converted by the PICmicro to a 10-bit Binary Value (0 -1023) * There are 2 analogue sensors on the board itself to experiment with: ** An LDR (Light dependent resistor) on PIN 1 ** A Variable Resistor on PIN 2 * External Analogue Sensors can be connected to J4 and their output is routed to the PICmicro on PIN 4 * External Digital Sensors can be connected to J3, and their output is sent to the PICmicro on PIN 3. Some digital sensors are active and require a stimulus from the PICmicro. For these a signal from the PICmicro to the Digital Sensor is available on PIN 5 * For normal usage, leave the jumpers in the Default position. * The Patch position is used to manually override the mapping of the pins. (:nl:)(:table style="clear:both":)
Page last modified on December 22, 2011, at 09:40 AM
