Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards ## E-blocks Documentation and Numbering ## Sensor Interface (EB003) ## LED Board (EB004) ## LCD Board (EB005) ## Multiprogrammer (EB006) ## Switch Board (EB007) ## Quad 7-segment Display (EB008) ## Keyboard (EB014) ## Prototype Board (EB016) ## Patch Board (EB017) Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login LED Board EB004<^< Sensor Interface (EB003) | Course Index | LCD Board (EB005) >^>(:nl:) EB004 LED BoardMore information can be found here. ![]() EB004 LED Board Block Diagram![]() * Click EB004-30-2 for the datasheet. * The male D-type connector fits into the Female connector of one of the ports of an upstream board. * LED D0 and its series resistor R0 will be connected to pin 1 of the Male D-type connector * The series resistor is here to control the current that will flow from PICmicro to the LED. ** A LED usually has an Imax of 20mA ** The PICmicro has an Imax of 25mA (sink or source) ** The LED has a Forward Voltage drop of 1.7V ** In this case the 560 Ohm resistor will limit the current at: *** (5V-1.7V)/560 Ohm= 5.9mA *** This is well under the current limits of both PICmicro and LED * The Female connector is here to connect several boards in parallel. Be ware of the total current limit of the PICmicro if you do so. (:nl:)(:table style="clear:both":)
Page last modified on January 30, 2012, at 02:52 PM
