Recent Changes - Search:
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
ChangeLog
(:Summary: PmWiki group header. Includes styles and trail.:) (:comment please leave the multiple style definitions concatenated as a single line. Linebreaks do appear in the output when the wiki is configured with linebreaks enabled -- thanks!:) (:comment included in PmWiki localisation headers and footers :)
(:nl:)(:Summary: Log of changes made to PmWiki by Release:)See the cookbook recent changes page for additional updates and activity by other developers, or join the PmWiki mailing lists to discuss feature development with us.
(:Prerelease:Changes made to the subversion pre-release (ZIP) of PmWiki::)
Version 2.2.131 (2020-08-30)
* Update documentation.
Version 2.2.130 (2020-07-04)
Version 2.2.129 (2020-05-21)
* Mute some PHP notices. * Copy "simpletable" styles from the "pmwiki-responsive" skin into the old "pmwiki" skin. * Update documentation.
Version 2.2.128 (2020-04-26)
* Strip some trailing spaces and convert some tabs to spaces. * Add comments next to preg_replace() and create_function() where old addons may cause PHP deprecation notices. * Mute some PHP notices. * Print the invalid pagename in the error message. * Update documentation.
Version 2.2.127 (2020-03-23)
* Mute some PHP "undefined variable" notices. * Responsive skin set #wikiedit textarea max-height: 60vh (after discussion+tests at PmWiki:Skins-Talk). * Prefix PmTOC classes "pmtoc-show" and "pmtoc-hide" to avoid processing by other frameworks (reported by Finar). * Add Skins:SkinChange to the core, enabled by either of the variables $EnableAutoSkinList and/or $PageSkinList. * Add FileSizeCompact() and DiffTimeCompact() (can be used by recipes). * Add $FmtV["$upresult"] can be intercepted by recipes. * Update documentation.
Version 2.2.126 (2020-02-01)
* Mute some "Undefined" notices. * Fix caches.php to write an updated .htaccess format. * Fix bug with $PmTOC['MinNumber'] = -1 reported by SteP. * Update documentation.
Version 2.2.124, 2.2.125 (2020-01-27)
* Hide .PmTOCdiv if empty. * Add $SetCookieFunction. * Add $ToggleNextSelector, see Cookbook:ToggleNext. * Update documentation.
Version 2.2.123 (2019-12-31)
* Allow for escaped [=link address=] to have any special characters, including quotes, parentheses and pipes. * Fix PmXMail when the link contains a quote, and to work from headers, footers and sidebars. * Add form attribute "formnovalidate" (suggested by Robert Riebisch). * Allow table of contents to work better with Cookbook:SectionEdit (reported by Johan Bengtsson). * Mute a number of PHP notices for undefined variables. * Add that "URL" means in browser in sample-config.php (PITS:01448). * Add Cookbook:RecipeCheck in diag.php. * Refactor functions that handle $EnableRCDiffBytes to show the deltas in the page histories. * Remove $EnableRelativePageVars from sample-config.php (confusing, PITS:01145). * Add upload extensions @@webp@@ image format and @@opus@@ audio codec. * Update documentation.
Version 2.2.122 (2019-11-19)
Version 2.2.121 was released by mistake and contained some experimental code that was meant to be tested first. * ObfuscateLinkIMap: Fix bug with special or international characters in custom subject fields, reported by FidelioEspoir. * Add $DefaultUnsetPageTextVars, $DefaultEmptyPageTextVars. * Mute "Uninitialized string offset messages" for error_reporting(E_ALL), reported by DFaure. * Fix PmTOC, when NumberedHeadings is enabled, to number headings even when the TOC would not be created. * Add {$$EachCount} pagelist template pseudovariable, containing the count for the current "each" loop. * Add $InputAttrs @@role@@ and @@aria-*@@ form attributes, allow aria-\\w* attributes for the (:searchbox:) field. * Update documentation.
Version 2.2.120 (2019-10-13)
* Add @@(:input datalist:)@@ form element. * Add (:details summary="...":)...(:detailsend:) block markup. * Fix bugs with guiedit.php/guiedit.js reported by FidelioEspoir. * PmTOC: add max-height and overflow-auto to the block. * Update documentation.
Version 2.2.119 (2019-10-03)
* Update for PHP 7.4 "string offset with curly braces is deprecated". * Add @@required="required"@@ attributes to input author/uploader fields when $EnableUploadAuthorRequired or $EnablePostAuthorRequired are set. * Add @@required="required"@@ attributes to the "upload file" element (to prevent posting the form without an attached file). * Add ObfuscateLinkIMap() based on Cookbook:DeObMail, default disabled. * GuiEdit: Add FixUrl button based on Cookbook:FixURL default disabled, add $EnableGuiEditFixUrl; * EditForm: Add features from Cookbook:NotSavedWarning, default disabled, add $EnableNotSavedWarning. * EditForm: Add scroll position to edit text area will be remembered on save-and-edit and preview. * EditForm: Add $EnableEditAutoText and features from Cookbook:EditHelp. * Add $PmTOC, (:toc:), (:notoc:), based on a simplified variant of Cookbook:AutoTOC. * Fix bug with pagelist while preview, reported by Finar. * Add $EnableSortable, basic sortable tables based on public domain code from Jonas Earendel. * Add $EnableRCDiffBytes based on Cookbook:DeltaBytesRecentChanges. * Add $EnableSimpleTableRowspan replicating features of Cookbook:RowspanInSimpleTables. * Add $WikiPageCSSFmt enables CSS in a wiki page, based on Cookbook:LocalCSS. * Add $EnableHighlight code highlight feature compatible with "highlight.js". * Attachlist @@ext=@@ and @@names=@@ arguments now accept patterns and negatives like @@ext=jpg,png@@, @@ext=-pdf@@, or @@names=-th*---*.jpg@@. * Attachlist: allow both ext= and names= to cohabitate. * MarkupExpr: remove unused declaration. * EditAutoText: use event.ctrlKey and event.shiftKey instead of 2 functions. * Redirect: add 3rd argument $redirecturl which can be provided directly * Add $AddLinkCSS['othergroup'] and $AddLinkCSS['samedomain'] can contain link CSS classes. * Update documentation.
Version 2.2.118 (2019-08-28)
* Add $EnablePreviewChanges and PreviewDiff() based on Cookbook:PreviewChanges. * Update documentation.
Version 2.2.117 (2019-07-28)
* Add $EnableUploadAuthorRequired default to $EnablePostAuthorRequired, add Author field in upload form. * Implement partial content indirect downloads (suggested by Christopher Cox, required for embedded video on iOS). * Add allowed upload video extensions 'm4v' and '3gp'. * Fix lowercase "Content-Disposition" header for downloads. * Update documentation.
Version 2.2.116 (2019-06-19)
* Add $PageListVarFoldFn, defaults to $StrFoldFunction, for international case-insensitive matches of page (text) variables. * Update documentation.
Version 2.2.115 (2019-05-13)
* Responsive skin: Simplify CSS for custom backgrounds, remove repetition. * Update documentation.
Version 2.2.114 (2019-04-02)
* Fix bug with input select lists where an already defined id= attribute may get overwritten. * Vardoc: Move the id= attribute from a standalone anchor to the definition term element (allows ":target" styling). * Vardoc: Localize table header and link text (suggested by Michael F. Wolff). * Add $SkinTemplateIncludeLevel, IncludeTemplate skin directive. * Add input "tel" type, and attribute "pattern". Fix classnames of new input types. * Update documentation.
Version 2.2.113 (2019-03-01)
* Add input button element. * Add $EnableInputDataAttr. * Update documentation.
Version 2.2.112 (2019-01-09)
* Fix switch break for PHP 7.3, reported by Hans-Jürgen Godau. * Update documentation.
Version 2.2.111 (2018-12-08)
* Add @@$Id$@@ subversion keyword to pmwiki.php, requested by Peter Gragert. * Fix responsive skin search form max-width in desktop mode, reported by Moni Kellermann. * Add $DenyHtaccessContent variable. Update protective .htaccess files. * Add tz= and locale= arguments to {(ftime )} MarkupExpression (PHP5+). * Update documentation.
Version 2.2.110 (2018-11-05)
* Fix {(substr )} markup expression with non-number arguments could cause warnings, reported by Simon. * Add $PageListSortCmpFunction, default to current 'strcasecmp'. * Add global $MarkupMarkupLevel which changes when the processing is inside (:markup:) blocks. * Fix inconsistent white space with inline @@[@escaped code@]@@, reported by Dannybpng. * Update documentation.
Version 2.2.109 (2018-07-09)
* Update pmcrypt() to exclude negative -@groups from hash checking. * Add $EnableMarkupDiag to backtrace all markup calls, suggested by ChuckG. * Fix Path InterMap broken in 2.2.108, reported by ChuckG. * Update documentation.
Version 2.2.108 (2018-07-05)
* Add $PCCFOverrideFunction. * $AuthUserPageFmt can now be an array of page names. * Add $PageCacheFileFmt default to "%s/%s,cache" (like before), allowing custom cache filenames. * Form checkbox labels now have the same tooltip title as the checkbox. * Add %reversed% WikiStyle. * RefCount: add label to checkbox, class to table. * Vardoc: fix markup call, reported by Hans-Jürgen Godau. * pmcrypt() return false when salt appears to be some old PmWiki attribute. * Default InterMap PmWiki URLs have now the HTTPS protocol (suggested by Simon). * Update documentation.
Version 2.2.107 (2018-02-02)
* Fix Forms and Pagelists warnings in PHP 7.2, reported by DFaure. ** Fix order=title broken with the previous commit, reported by ChuckG. * Add $MailFunction. * Add ".rtl *" styles. * Update documentation.
Version 2.2.106 (2017-12-01)
* Add pmsetcookie(), $EnableCookieSecure, $EnableCookieHTTPOnly (PITS:01425). * Refactor PageListSort() to make it work for PHP 7.2 without requiring create_function(). ** Fix ordering broken with the previous commit, reported by ChuckG. * Fix `wikiword markup, reported by Steve Glover. * Update documentation.
Version 2.2.105 (2017-11-07)
* Refactor @@HandleUpload()@@ - add @@UploadSetVars($pagename)@@ to allow custom upload add-ons to set variables. * Fix bug with PQA() that caused invalid HTML with attributes glued together.
Version 2.2.104 (2017-10-11)
* Fix bug with WikiTrails introduced with 2.2.103 (PITS:01422).
Version 2.2.103 (2017-10-01)
* Add pagelist list=grouphomes and fmt=#grouphomes. * Update all scripts for PHP 7.2 (bugtrack). * Make responsive skin also compatible with PmWiki versions 2.2.55 or earlier. * Add *.vtt (web subtitles) as allowed upload extension. * Fix Charset headers for xlpage-iso-*.php * Refactor PageStore class to remove create_function() calls. * Add "title" attribute to input form elements. * Re-add the definition of the $rrep variable in Markup expressions, reported by ChuckG. * Add $AuthLDAPReferrals to set LDAP_OPT_REFERRALS if needed, reported by Kirk Zurell. * Fix missing $pagename for WikiWord links. * Update documentation.
Version 2.2.102 (2017-08-05)
* Revert fix for PITS:01300, the markup engine breaks when a text variable content is longer than 2699 characters. * Add a text box in SiteAdmin.AuthList to allow filtering of the results.
Version 2.2.101 (2017-07-30)
* Rename function PageStore to __construct, to prevent PHP 7 strict or deprecated notices.
Version 2.2.100 (2017-07-30)
* Workaround around Subversion incompatibility with @@$Author:...$@@ string not intended as SVN keyword. * Responsive skin: add spacing above the #wikitext block, similar to the default skin. * Update documentation.
Version 2.2.99 (2017-06-26)
* Fix Preview didn't show changes due to $ROSPatterns (PITS:01408). * Remove markup rules for previewing author signature not needed anymore. * Fix bug and warning appearing in PHP 4 installations. * Update Wikipedia intermap entry (secure https). * Fix bug with [[<<]] styles "clear:both". * {-Fix incomplete definition of page text variable halts the rendering (PITS:01300).-} * Fix $Version didn't work as a vardoc link. * Update documentation.
Version 2.2.98 (2017-05-31)
* Fix WikiStyles where "pct" was incorrectly dropped from some classnames (PITS:01404). * Hide warning about missing intermap file. * Add pmwiki-responsive skin, based on modified Skins:2016. * Responsive skin: Hide icon if PageActions empty. Fix "close" icon didn't appear for the PageActions block. Unrestrict menu height. Switching from portrait view with menu open to landscape: page should not be greyed out (PITS:01406). Landscape view: fix overflow for search form in Epiphany (likely Safari and other AppleWebKit-based browsers). Move the <main> tag up to allow scrolling of the whole #wikibody. Large preformatted blocks will also scroll in the mobile view. Set limit for desktop layout to 50em~800px. Scrollable tables via cosmetic JavaScript. * Both skins: Set default text color (PITS:01406). * Fix Deprecated notice for Site.AuthUser password attributes. * Vardoc links now use MakeLink() to allow a custom LinkPage function, fix bug reported by ChuckG. * $InclCount now counts per browsed page (for multi-page processing recipes). * Make $markupid variable available to markup replacement functions. * Refactor function ReplaceOnSave to allow easier calling from recipes (PITS:01407). * Enable *.mkv as allowed video extension. * Fix bug with attachlist markup. * Fix alternative bold/italics markup in sample-config.php (PITS:01400). * Fix lost space in markup tables, replace markup tables <code> with <pre> and add style "pre-wrap" (reported by ChuckG). * Update documentation.
Version 2.2.97 (2017-04-07)
* Fix bug concerning $ScriptUrl when $EnablePathInfo is set, introduced in 2.2.96, reported by 3 users. * Update documentation.
Version 2.2.96 (2017-04-05)
* Fix severe PHP code injection vulnerability, reported by Gabriel Margiani. ** Filter $pagename to exclude certain characters. ** Add $pagename_unfiltered in case a recipe requires it. * Update documentation.
Version 2.2.95 (2017-02-28)
Version 2.2.94 (2017-01-31)
* Strip both .html and .htm extensions (Cookbook:HtmlUrls-Talk). * Clear $PageExistsCache[$pagename] when a page is created or deleted (PITS:01401). * Update documentation.
Version 2.2.93 (2016-12-31)
Version 2.2.92 (2016-11-30)
* Skip checking for $AllowPassword if empty or false. * Enable FmtPageName() to expand PageVariables with asterisks. * Update documentation.
Version 2.2.91 (2016-09-30)
Version 2.2.90 (2016-08-31)
* Add action parameter to upload form URL. * Add @@imgonly@@ and @@imgcaption@@ CSS classes (PITS:01390). * Fix plus-links with suffix [[Page|+]]s (PITS:01392). * Update documentation.
Version 2.2.89 (2016-07-30)
* Add identifiers to Site.EditForm elements to enable easier styling. * Add $SimpleTableDefaultClassName, default unset (PITS:00638). * Add temporary $new['=html'] entry, in SaveAttributes(). * Fix superfluous line breaks in SiteAdmin.AuthList. * Add optional placeholder attribute in (:searchbox:). * Add $SearchBoxInputType, default 'text'. * Set $HTMLStylesFmt via SDVA() in vardoc.php, urlapprove.php, and xlpage-utf-8.php. * Fix vardoc.php to recognize and link variables $pagename, $Author, $Skin, and to sort case insensitively. * Update documentation.
Version 2.2.88 (2016-06-29)
* Fix invalid HTML output of WikiTrail links (PITS:01388). * Add 4th argument $double_encode to PHSC() for safe replacement of htmlspecialchars(). * Add page variable {$SiteAdminGroup} (PITS:00951). * Update documentation.
Version 2.2.87 (2016-05-31)
* Add $HTMLTagAttr, to allow inclusion of lang, manifest and other attributes. * Add $EnableRevUserAgent, $FmtV['$DiffUserAgent']. * Fix relative link in Site.UploadQuickReference. * Update documentation.
Version 2.2.86 (2016-04-28)
* Fix PageStore() for PHP 7. * Fix $DefaultPasswords for PHP 7. * Update documentation.
Version 2.2.85 (2016-03-31)
* Add svg(z) and SVG(Z) as embeddable image extensions (PITS:00197, PITS:00435). * Add *.svgz as allowed upload extension. * Update documentation.
Version 2.2.84 (2016-02-21)
* Update/fix URL in UPGRADES.txt (PITS:01378). * Fix indent and outdent CSS for RTL languages (PITS:01379). * Add $EnableLinkPlusTitlespaced (PITS:01140). * Update documentation.
Version 2.2.83 (2015-12-31)
Version 2.2.82 (2015-11-30)
* Enable stripmagic() to process arrays recursively. * Update documentation.
Version 2.2.81 (2015-10-31)
* Fix single line PageTextVariable definition (reported by HansB). * Add .ltr and .rtl CSS classes for UTF-8. * Update documentation.
Version 2.2.80 (2015-09-30)
* Modify (:searchbox:) to use type="search" input. * Update documentation.
Version 2.2.79 (2015-08-27)
* Modify guiedit.js::insMarkup() to accept a custom function name processing the text, and a custom id for the text area. * Add CSS basic colors 'fuchsia','olive','lime','teal','aqua','orange' and 'grey' as WikiStyles (PITS:01373). * Add $EnableROSEscape, default 0 (PmWiki:TextFormattingRules-Talk). * Remove 'target' attribute in input forms (breaks PmForm). * Add HTML5 input types email, url, number, date, search. * Add attribution in script comments. * Update documentation.
Version 2.2.78 (2015-07-21)
* Update $RobotPattern with current user agents. * Accept 'target' attribute in input forms. * Update documentation.
Version 2.2.77 (2015-06-19)
* Add generic function MakeNames() to process MakePageNames(). * Extend (:if attachments:) to specify file and page names (PITS:01087). * Optimize PageStore::recode() to cache utf8_decode and utf8_encode callbacks. * Add {$WikiTitle} page variable. * Update documentation.
Version 2.2.76 (2015-05-31)
* Recover posted arrays (indexed or associative, not multidimensional) when a password is required (PITS:00835, PITS:01110). * Add label argument to checkbox and radio inputs (PITS:01367). * Enable PHSC() to process arrays recursively. * Enable processing of arrays as input values (PITS:01032). * Add CSS classes to standalone image div and caption (PITS:00489, PITS:00497). * Update documentation.
Version 2.2.75 (2015-04-26)
* Fix uploads to respect $EnableReadOnly. * Escape HTML special characters when printing failed callback creation. * Add pmcrypt() for PHP 5.6 compatibility. * Add markup for HTML5 semantic tags article, section, nav, header, footer, aside, address. * Update documentation.
Version 2.2.74 (2015-03-28)
* Allow translation of the "OK" string in forms (PITS:01363). * Update documentation.
Version 2.2.73 (2015-02-28)
Version 2.2.72 (2015-01-27)
* Enable markup debug messages even when debug_backtrace() is not available. * Add $AbortFunction. * Restore ability to set a custom $MarkupWordwrapFunction, add $MarkupWrapTag (related to earlier fix for PITS:01360). * Update documentation.
Version 2.2.71 (2014-12-29)
* Add $DraftActionsPattern. * Enable "input default source" parameter to contain multiple pages. * Enable "pagelist request" parameter to contain a list of (dis)allowed parameters. * Enable Markup() backtrace for ?action=ruleset. * Fix strict warning for blacklisted uploads (PITS:01359). * Fix wrong hard wrap in (:markup:) code examples (PITS:01360). * Update documentation.
Version 2.2.70 (2014-11-08)
Version 2.2.69 (2014-10-13)
* Fix DRange() for ISO-8601 dates +/- X days. * Fix wording in Site.UploadQuickReference. * Update documentation.
Version 2.2.68 (2014-09-01)
* Add Skins: InterMap prefix. * Add signature to Site.EditQuickReference (PITS:01350). * Allow $PostConfig entries to be launched after per-page customization, before other stdconfig.php inclusions if values<50. * Add WikiStyles clear, min and max width and height (PITS:00860), fix %p class=...% with more than one space. * Update documentation.
Version 2.2.67 (2014-08-02)
* Fix InputDefault/PageTextVariables inconsistency (PITS:01337). * Update documentation.
Version 2.2.66 (2014-07-02)
* Fix Author in Notifcations when deleting pages (PITS:01112). * Exclude "_" to be considered as a function name in various $*Patterns. * Update documentation.
Version 2.2.65 (2014-06-07)
* Fix {$$PseudoVars} containing {*$PageVars} in PageList Templates. * Fix wording in scripts/.htaccess (PITS:01345). * Fix fixperms() if directory owner is root (PITS:01346). * Update documentation.
Version 2.2.64 (2014-05-08)
* Add {(mod)} markup expression. * Add tel: and geo: URI schemes?. * Add $SysMergePassthru to allow Merge() to use passthru() instead of popen(). * Update documentation.
Version 2.2.63 (2014-04-05)
* Allow form elements to have a dash in the attribute names. * Strip magic slashes for pagelist/search request vars. * Allow input attributes readonly, placeholder and autocomplete for HTML5 sites. * Update documentation.
Version 2.2.62 (2014-02-28)
* Add $CallbackFnTemplates["return"]. * Add 4th argument to Markup_e() - $template. * Add $EnableTableAutoValignTop. * Update documentation.
Version 2.2.61 (2014-01-31)
* Add $TableCellAlignFmt. * Remove unused snippet in prefs.php (reported by Oliver Betz). * Remove unused calls to PSS() (reported by John Rankin). * Update documentation.
Version 2.2.60 (2014-01-12)
* Revert to previous pmwiki.css file.
Version 2.2.59 (2014-01-11)
* Fix checking multiple posted fields in blocklist.php (reported by Randy Brown). * Allow Markup_e() to accept a callback as well as code. * Fix "+" shortcut for internal anchor links. * Disable HTML cache if count($_GET)>1 not >2 (PITS:01278). * Fix query string if a "?" is encoded to uppercase "%3F". * Replace CSS font sizes from points (fixed) to percents (relative) for the default skin. * Fix nested conditionals containing $pagename (reported by Benjamin Grassineau). * Update documentation.
Version 2.2.58 (2013-12-25)
* Allow $LinkUpload to be usable in (:attachlist:). * Enable customizations of (:input auth_form:). * Remove unused variable $Block in FormatTableRow(), reported by Klonk. * Fix $EnableBlocklistImmediate to check all posted fields for blocked terms. * Add $GLOBALS['MarkupToHTML'] to pass parameters such as $pagename to markup calls. * Update documentation.
Version 2.2.57 (2013-11-03)
* Encode international character used for detection of a recode function. * Enable $IMapLinkFmt['Attach:'] to be used in (:attachlist:) links. * Add $MakePageNameSplitPattern. * Update documentation.
Version 2.2.56 (2013-09-30)
* Work in progress to remove the core dependency of the deprecated "eval" feature of the preg_replace() function (PITS:01319). * Add functions PCCF(), PPRE(), PPRA(), Markup_e(), migrating all core calls to these functions. * Fix detection of proper PageStore->recodefn. * Update documentation.
Version 2.2.55 (2013-09-16)
* Add $EnableDraftAtomicDiff (PITS:01007). * Update documentation.
Version 2.2.54 (2013-08-13)
* Fix broken page history for draft pages, reported by ChuckG. * Update documentation.
Version 2.2.53 (2013-07-08)
* Show a message when the post has been blocked because of too many unapproved links. * Update documentation.
Version 2.2.52 (2013-06-08)
* Add docx, pptx, xlsx upload extentions. * Hide E_DEPRECATED warnings for PHP 5.5. * Update documentation.
Version 2.2.51 (2013-05-08)
* Update url to MoinMoin's blocklist. * Comment-out blacklist.chongqed.org as the domain appears to have expired. * Fix possible XSS vulnerability in prefs.php, discovered today. * Fix access keys to be a single character. * Fix $AuthorPage if there is a group named the same as the author (PITS:01259). * Update documentation.
Version 2.2.50 (2013-04-08)
Version 2.2.49 (2013-03-09)
* Add $UploadBlacklist array. * Update documentation.
Version 2.2.48 (2013-02-11)
* Fix bug introduced yesterday with some links, reported by Michael Weiner (PITS:01308).
Version 2.2.47 (2013-02-10)
* Enable tooltip titles for links to anchors on the same page. * Update documentation.
Version 2.2.46 (2013-01-07)
* Add third parameter to fixperms() explicitly setting the permissions. * Add $UploadPermAdd and $UploadPermSet variables. * Update documentation.
Version 2.2.45 (2012-12-02)
* Cleanup some PHP notices (PITS:01304). * Update documentation.
Version 2.2.44 (2012-10-21)
* Better display of whitespace in page histories. * Fix definition for PageTextVariables containing a dash (PITS:00978). * Update documentation.
Version 2.2.43 (2012-09-20)
* Allow for HTML attribute names to contain dashes, eg. data-transition, data-role etc. * Remove warning when previewing Site.EditForm. * Update documentation.
Version 2.2.42 (2012-08-20)
* Convert the line-endings in the docs/ directory to \r\n compatible with Windows. * Modify PHSC() to call htmlspecialchars() with a single-byte encoding argument. * Update documentation.
Version 2.2.41 (2012-08-12)
* Change $KeepToken to "\034\034" which is compatible with more encodings. * Update documentation.
Version 2.2.40 (2012-07-21)
* Add PHSC() helper function as a replacement of htmlspecialchars() for PHP 5.4 (PITS:01292). * Update documentation.
Version 2.2.39 (2012-06-25)
* Fix URL encoding of attachment links. * Update documentation.
Version 2.2.38 (2012-05-21)
* Fix "Wrong parameter count for utf8_decode" warning, reported by Simon. * Update documentation.
Version 2.2.37 (2012-05-01)
* Add page filename encoding functions. * Better handling of dots in [[#anchor_1.2]] sections (PITS:01285). * Expand PageVariables in PageList templates defaults (PITS:01282). * Add test for iconv() and mb_convert_encoding(), refactor recode(). * Update documentation.
Version 2.2.36 (2011-12-28)
* Add $EnableOldCharset variable and $page["=oldcharset"] entry. * Refactor PageStore->recode() to recover Windows-1252 characters. * Add exit line to xlpage-iso-8859-2.php (PITS:01275). * Fix difference in defining and removing "invisible" PTVs. * Update documentation.
Version 2.2.35 (2011-11-11)
* Fix critical PHP injection vulnerability (PITS:01271, reported by Egidio Romano). * Important change: Disable script loading from XLPage(). * Move the processing of [[link|+]] inside LinkPage() and delete markup rule from stdmarkup.php. * Modify MakeLink() to better handle link titles. * Add optional $LinkTitleFunction allowing recipes to customize the link titles. * Fix ReadTrail() to better handle links with titles. * Add title attributes for the HTML templates in the @@ $LinkPage*Fmt @@ variables. * Add upload extensions svg, xcf, ogg, flac, ogv, mp4, webm, odg, epub. * Minor optimization for the MarkupExpressions for UTF-8 strings. * Minor optimization of the rendering of page history.
Version 2.2.34 (2011-10-10)
* Add MarkupExpressions replacements for UTF-8. * Reset timestamps of Site(Admin).AuthUser to 1000000000, used in upgrades.php. * Update documentation.
Version 2.2.33 (2011-09-23)
* Fix locked states for Site and SiteAdmin GroupAttributes (reported by Brijesh Kothari). * Fix intermap.txt entries PITS: and Wikipedia: to point to their current locations. * Fix refcount.php to produce valid HTML (PITS:01266).
Version 2.2.32 (2011-09-18)
* Add required html xmlns attribute to the print skin template. * Add PageStore->recode() function. * Add $DefaultPageCharset array. * Optimize for speed the inline diff for page history when too many lines were added or deleted. * Update and convert to UTF-8 the documentation.
Note: Due to a manipulation error, a version 2.2.31 was created before it was ready for a release.
Version 2.2.30 (2011-08-13)
* Fix $Charset definition in iso-8859-*.php files. * Add $EnableRangeMatchUTF8, set it to 1 to enable range matches in UTF-8. * Update documentation.
Version 2.2.29 (2011-07-24)
* Fix Attach links that were broken with the Path fix in 2.2.28. * Add $IMapLocalPath array containing InterMap prefixes that should be treated as local.
Version 2.2.28 (2011-07-24)
* Fix potential XSS vulnerability in refcount.php (PITS:01262). * Fix bug in Path: links (PITS:01260). * Fix potential XSS vulnerability in custom SitePreferences (PITS:01263). * Update documentation.
Version 2.2.27 (2011-06-19)
* Add block WikiStyle %justify% (PITS:01253). * Remove unused <vspace> after a redirection (PITS:01255). * Add ?nodiff=1 parameter for page history to disable diff rendering and show only restore links. * Update documentation.
Version 2.2.26 (2011-05-21)
* Fix ReadTrail(), redundant replacing of hashes, already done in MakePageName(). * Update documentation.
Version 2.2.25 (2011-03-22)
Version 2.2.24 (2011-02-15)
* Add {$$PageTrailDepth} pseudovariable for PageList templates. * Fix PageVar(), add $authpage array for an authenticated page data, removed $EnablePageVarAuth. * Update documentation.
Version 2.2.23 (2011-01-25)
* Default $EnablePageVarAuth to 0 until the resolution of PITS:01242.
Version 2.2.22 (2011-01-16)
* Add $EnableXLPageScriptLoad to XLPage() to prevent editors from changing the encoding. * PageVariables now respect authentications (PITS:01213). * Add $EnablePageVarAuth. * Update documentation.
Version 2.2.21 (2010-12-14)
* Fix potential XSS vulnerability, reported by DFaure. * Fix invalid HTML for simple table captions, reported by JL. * Fix WikiStyles could work not properly if a value was empty like accesskey="".
Version 2.2.20 (2010-12-14)
* Fix Pagelist {$$variable} didn't work in template none (PITS:01212). * Fix interface access keys in browse mode (PITS:01188). * Add PmL10n: intermap prefix for the Localization/ group on pmwiki.org (PITS:01180). * Fix AuthUser excluding members didn't work (PITS:01201). * Update documentation.
Version 2.2.19 (2010-11-10)
Version 2.2.18 (2010-09-04)
* Fix $SaveAttrPatterns to skip nested conditionals (reported by RandyB). * Fix RecentChanges when an edit summary contains the dollar sign (PITS:01217). * Fix RDF feed number of elements (PITS:01198). * Update documentation.
Version 2.2.17 (2010-06-20)
* Add tabindex as a valid form attribute (PITS:01190). * Collapse adjacent insertions in DiffRenderSource (PITS:01192). * Fix HandleDownload to flush() output before exit (PITS:01199). * Fix HandleDownload to respect $EnableIMSCaching (PITS:01191). * Add $PostConfig functions and scripts, loaded after stdconfig.php (PITS:01132). * Add $AuthUserPat variable for the regexp pattern in AuthUserId() (PITS:01202). * Pass $authlist as last parameter to $AuthUserFunctions (PITS:01197). * Fix "exists" conditional to work with old link markup. * Update documentation.
Version 2.2.16 (2010-05-10)
* Allow "exists" conditional to accept wildcards (PITS:01184) * Fix GUI button %center% which didn't work correctly. * Fix incorrectly parsed quote in PQA(), possible script injection (discovered by Hanno Boeck).
Version 2.2.15 (2010-03-27)
* Add @@ (Auth|Edit)Form @@ to auto-translated titles. * Fix (:if auth LEVEL:) to respect $HandleAuth (PITS:01164). * Skip loading of the second half of draft.php if $action!="edit". * Fix bug with (:template none:) introduced in 2.2.14, reported by Holger. * Fix HandleDownload() to use binary file-read.
Version 2.2.14 (2010-02-27)
* Fix inline styles in WikiTrails (PITS:01121). * Add a negation parameter to pagelist first/last templates (PITS:01127). * Refactor FPLTemplateFormat(), move repeated code blocks into FPLExpandItemVars(). * Add $EnableUndefinedTemplateVars allowing to hide or show undefined template/include {$$variables} (PITS:01152). * Add "title" attribute to external links (PITS:00657). * Add FmtPageTitle() to allow automatic i18n titles for RecentChanges and other technical pages (PITS:01157). * Update documentation.
Version 2.2.13 (2010-02-21)
* Replace deprecated in PHP 5.3 function split() with explode(). * Add $WordDiffFunction default to PHPDiff(). * Use existing border colors as highlighting background. * Refactor/optimize DiffRenderSource(), merge with DiffRenderInline(). * Change default history to show word-level highlighting. * Fix bug with $DiffKeepNum which kept less revisions than it should. * Fix RetrieveAuthPage() call from HandleDiff(). * Update documentation.
Version 2.2.12 (2010-02-17)
* Allow a custom $DiffHTMLFunction to skip the line rendering if it returns false. * Add $EnableDiffInline, simple word-level diffs (PITS:00571). * Update documentation.
Version 2.2.11 (2010-02-14)
* Break PrintDiff() into customizable functions (PITS:01106). * Add anchors to individual diffs (PITS:00796). * Remove unused $RecipeInfo definition in markupexpr.php (reported by P.Bowers). * Add (:head:) and (:headnr:) table directives (PITS:00535). * Fix $GroupPattern and $NamePattern in xlpage-utf-8.php. * Update documentation.
Version 2.2.9, 2.2.10 (2010-01-17)
* Fix i18n string in PasswdVar(), reported by SteP. * Fix sample-config.php with correct information about $EnableWSPre (PITS:01145). * Fix range searches for wikis in UTF-8 (reported by Maxim). * Fix global variable $StringFolding in scripts/xlpage-utf-8.php. * Fix markup for italics in creole.php. * Fix previews for PTVs, PageList templates and included sections (PITS:01098). * Add $DiffKeepNum - number of revisions kept, even if older than $DiffKeepDays. * Add Yandex to robots.php. * Change default $EnableRelativePageVars to 1 (PITS:01145). * Add fifth parameter to SetProperty() : keep existing property. * Add $EnablePageTitlePriority (PITS:00266, PITS:00779). * Update documentation.
Version 2.2.8 (2009-12-07)
* Fix apostrophes in Author field (PITS:01155). * Fix Condition "exists" for PHP 5.3 (PITS:01156). * Update documentation.
Version 2.2.7 (2009-11-08)
* Fix GlobToPCRE() to work with !excl and -excl with PHP 5.3 (PITS:01149). * Fix HandleDownload() correctly quote the filenames (PITS:01150). * Fix SessionAuth() for PHP 5.3, the $_REQUEST array doesn't contain the $_COOKIE array (PITS:01141). * Fix default timezone for PHP 5.3 (PITS:01141). * Update documentation.
Version 2.2.6 (2009-10-04)
* Escape apostrophes for multiline textarea/hidden form fields. * Fix global unset of $MarkupRules in Markup() and DisableMarkup(), reported by D.Faure. * Fix call to BuildMarkupRules() in MarkupToHTML(), suggested by Pm. * Allow disabling of $PageListFilters and $FPLTemplateFunctions if set to -1 and thus allow replacing a core function with a custom one. * Fix DRange() returned timestamps +1min or +1day when it shouldn't (PITS:01125). * Add $MarkupWordwrapFunction to allow custom (:markup:) line width for multibyte wikis (PITS:00703). * Add $MakeUploadNamePatterns to allow custom filename normalization for uploads. * Add a fourth argument to PostRecentChanges() to allow this function to be called with a custom $RecentChangesFmt array. * Add $RecentUploadsFmt, to allow logging of new uploads to the RecentChanges pages (PITS:00088). * Fix Notify for some installations in safe_mode (PITS:00976). * Add $HTMLHeaderFmt['guiedit'] variable in guiedit.php to allow customization (PITS:01146). * Update documentation.
Version 2.2.5 (2009-08-25)
* Add *.7z as accepted upload extension (PITS:00813). * Fix global variable $HandleAttrFmt in HandleAttr (PITS:01126). * Allow brackets in input element names (PITS:01131). * Fix CSS class applied twice (PITS:01071). * Fix Not-Modified headers could prevent caching (PITS:00802). * Break FPLTemplate() into configurable sub-parts (PITS:01102). * Add (:template none:) section for PageList templates. * Fix attr-protected page could be deleted with edit permissions (PITS:00238). * Update documentation.
Version 2.2.4 (2009-07-16)
* Fix bug with page attributes, which somehow didn't make it in the 2.2.3 release. * Fix bug with HTML entities in XLPages introduced earlier today in 2.2.3 (reverted, PITS:01114).
Version 2.2.3 (2009-07-16)
* Fix action=logout could incorrectly set a session cookie (PITS:01062). * Fix page history trim in vardoc.php (PITS:01103). * Add $EnableUploadGroupAuth, use group password for downloads (PITS:01104). * Fix recursive PTV loops, added $MaxPageTextVars (PITS:00915, PITS:01099). * Fix mkdirp() messages for absolute paths (PITS:00396). * Fix sample-config.php order for urlapprove.php (PITS:01037). * Fix broken signature links on preview. * Fix crypt.php (action=crypt) could malfunction for passwords with quotes or apostrophes. * Fix @@ @_site_*@@ passwords to work in GroupAttributes (PITS:00836, PITS:00998). * Fix possible XSS vulnerabilities, reported by Michael Engelke. * Update documentation.
Version 2.2.2 (2009-06-21)
* Fix class in pages not on the breadcrumbs trail, reported by Ed W. * Fix @@tabindex@@ and @@onclick@@ to guiedit buttons. * Fix $GroupPrintHeaderFmt in print.php (PITS:01073). * Fix global vars in xlpage-utf-8.php (PITS:00980). * Fix $txt in LinkPage (reported by Eemeli Aro). * Add $EnableNotifySubjectEncode for international wikis (Cookbook:UTF-8). * Fix international message in Abort(). * Fix security bug with AuthUser, reported by Eemeli Aro. See Release notes. * Fix $ActionTitleFmt for login and upload, reported by Eemeli Aro.
Version 2.2.1 (2009-03-28)
* Fix $FPLTemplateMarkupFunction which somehow didn't get in the 2.2.0 archive. * Fix wikitrails to work cross-group (PITS:00407). * Add $EnableRedirectQuiet variable (PITS:00919). * Fix {$Title} could display global variables (reported by HansB). * Fix reloaded form submissions could lose values (reported by DaveG). * Fix preview while restoring a version from history (PITS:01081). * Fix relative links with international characters (reported by G. Hermanowicz). * Add in sample-config.php example call to xlpage-utf-8.php (PITS:01066). * Update documentation. * Fix guiedit.php to produce valid HTML.
Version 2.2.0 (2009-01-18)
* Convert beta series to official release series. * Add $FPLTemplateMarkupFunction (PITS:00984, requested by John Rankin).
Older versions
ChangeLog Archive - changes prior to version 2.2.0. (:nl:)(:Summary:Trail and talk page links:) (:comment included in PmWiki localisation headers and footers :)
<<? >>bgcolor=#ffe border-top="1px solid black" font-size=.8em<< This page may have a more recent version on pmwiki.org: PmWiki:ChangeLog, and a talk page: PmWiki:ChangeLog-Talk. >><<
Page last modified on August 30, 2020, at 07:43 PM
