Introduction to Microcontroller Programming * Course Index * Introduction * About the Author * About this Course * Feedback * Course Navigation * Quick Course Navigation * How to use this Course * Acronyms Used and Course Conventions About PICmicro Chips * What is a PICmicro? * Microcontrollers * Digital versus Analogue * Inputs and Outputs * Memory * Programming * 16F1937 Architecture Clocking Your PICmicro Devices * Introduction * The Clock Circuit * Clock Settings * Clock Confusion E-Blocks * Introduction to E-blocks * Using E-blocks * E-blocks Boards Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs ## LED's ## Using LED's ## 7seg Displays ## LCD Displays ## Using LCD Displays ## Buzzers / Sounders ## Motors ## Stepper Motors ## Solenoids * Adding Drivers Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt |
(:Summary:Contains the 'action' links (like Browse, Edit, History, etc.), placed at the top of the page, see site page actions:) (:comment This page can be somewhat complex to figure out the first time you see it. Its contents are documented at PmWiki.SitePageActions if you need help. :) * Print (:comment (:if group Site,SiteAdmin,Cookbook,Profiles,PmWiki*:) (:comment delete if and ifend to enable backlinks:) * %item rel=nofollow class=backlinks accesskey='$[ak_backlinks]'% [[{*$Name}?action=search&q=link={*$FullName} | $[Backlinks] ]] (:ifend:) :) * Login LED's<^< Adding Outputs | Course Index | Using LED's >^>(:nl:) LED's (Light Emitting Diodes) are tiny crystals of a semiconductor, which give off light when an electric current passes through. They are very efficient devices, as almost no heat is generated in the process, leading to much longer battery life. ![]() 'Standard' LED's are low current devices, which produce relatively low levels of illumination, and are used as indicators rather than light sources. You can use a standard LED: as a 'power-on' indicator to show that a system is currently connected to a power supply; as an 'armed' indicator to show that some function of the system is active; as a sequence indicator, to show which stage of a sequence of operations is currently under way; as a simple test instrument to show whether an output of the system under development is at a high or low voltage, (logic 1 or logic 0,) during the testing stage. LED's are available in a wide range of formats, from pin-point sized single LED's, to arrays of ultra-bright LED's, used in message display panels, and traffic lights. ![]() (:nl:)(:table style="clear:both":)
Page last modified on August 26, 2011, at 09:56 AM
