Flowcode Help Overview
<sidebar>Sidebar: Flowcode Help Overview</sidebar>
Version 6
| Title | Description |
| New_in_Version_6 | Introduction to new features in Flowcode 6 and other useful information |
| Chips | List of supported microcontroller devices in Flowcode 6 |
| Migrating_to_V6 | Help and advise moving to v6 from an older version |
Getting Started
| Activating_Flowcode | Activating your Flowcode license |
| Opening_Flowcode | Launching the Flowcode application |
| Creating_Flowcharts | Creating your first Flowcode flowchart and see the options available |
| Selecting_a_Target_Chip | Selecting the target microcontroller device |
| Configuring_the_Chip | Configuring your device |
| Opening_an_Existing_Flowchart | Opening an existing .FCFX Flowcode project file |
| Selecting_a_Template | Opening a template project file |
| Saving_a_Flowchart | Saving your program |
| Creating_Templates | Creating your own templates |
| Closing_Flowcode | Closing Flowcode |
Flowcharts
| Icon_Properties | Flowchart icons and their functionality |
| Adding_an_Icon_to_a_Flowchart | Adding flowchart icons to your program |
| Editing_Icon_Properties | Editing the properties of a flowchart icon |
| Adding_Comments_to_a_Flowchart | Commenting your flowchart |
| Selecting_Icons | Selecting icons on the flowchart |
| Flowchart_Editing_Functions | Functions to make editing your flowchart easier |
| Printing_Flowcharts | Printing out a flowchart |
Macros
| Creating_a_New_Macro | Creating a new flowchart macro or subroutine |
| Editing_and_Deleting_Macros | Editing a macro and removing a macro from your program |
| Using_the_Project_Explorer | Features of the project explorer designed to help simplify programming |
| Exporting_a_Macro | Exporting a macro from within Flowcode |
| Importing_a_Macro | Importing a macro into Flowcode |
| DLL_Support | Changing the nature of a macro to instead call a external DLL function |
Functions
| Mathematical_Functions | Built in routines designed to help with mathematical operations such as Sin() and Float |
| String_Manipulation_Functions | Built in routines designed to help with string manipulation |
| Undo_and_Redo | Undo and Redo operations and shortcuts |
| Disabling_Icons | Disabling flowchart icons to comment out sections of code |
| Icon_Annotations | Icon annotations |
| Find_and_Replace | Ability to search within your flowcode project to replace specific text with alternate text |
Variables
| Creating_Variables | How to create a variable |
| Variable_Types | Variable types and their meanings |
| Editing_Variables | How to edit a variable |
| Variable_Manager | The Flowcode variable manager interface |
| Handles | Handle variables and their function within the system |
| Typecasting | Variable type casting, applications and usage |
Panels
| Panels_Where_And_Why | What the panels do and how they help you design your system |
| Dashboard_Panel | More in depth information on the dashboard panel |
| System_Panel | More in depth information on the system panel |
| Zooming_the_View | Zooming in and out on panels |
| Camera_Control | Controlling the camera looking at the panel |
| Object_Position | Object positioning on the panels |
| Local_and_World_Space | Local vs World space regarding coordinates |
| Object_Scale | Objects and their scale |
| Object_Rotation | Rotating objects |
| Working_With_Meshes | Using meshes inside Flowcode |
Tools and Views
| Tools_and_Views | Various tools and views available inside Flowcode |
| Using_the_Data_Console | How to use the data console window in your programs |
| Using_the_Data_Scope | How to use the data scope window in your programs |
| Using_the_Icon_Lists_Pane | The icon lists pane |
| Project_Options | Detailed help on the Project Options window |
| Global_Options | Detailed help on the Global Options window |
| Web_Access_Panel | The web access panel |
| Chip_View | The chip view window |
| Analog_Window | The analogue inputs window |
| Properties_Panel | The properties panel |
| Simulation_Debugger | The simulation debugger window |
| Component_Debugger | The component debugger window |
| Supplementary_Code | Supplementary code and its usage |
| Saving_Images_in_Flowcode | Creating images of your flowchart source |
| Auto_Documentation | Auto documentation features to speed up development |
| Window_Layouts | The window layouts manager |
Components
| Common_Components | Information on some of the more commonly used components |
| What_Is_a_Switch? | Detailed information regarding the switch components |
| What_Is_an_LED? | Detailed information regarding the LED components |
| What_Is_an_LCD? | Detailed information regarding the LCD components |
| What_Is_a_7_Segment_Display? | Detailed information regarding the 7Seg components |
| What_Is_a_Keypad? | Detailed information regarding the keypad components |
| Selecting_Component_Macros | Information on how to use component macros |
| Component_Help_Files | How to get access to component help via Flowcode |
| Components | Component help overview |
| Component_Properties | Information on how to use component properties |
| Component_Tree | Information regarding the component tree hierarchy |
| Replacing_a_Component | Replacing one component with another |
| CAL_Components | Overview of code abstraction layer components |
| DSP | Overview of digital signal processing components |
| Using_the_Data_Injector | Data injectors and communications components |
| Component_Directories | Information on creating your own components directories |
| Editing_Key_Mappings | Assigning keyboard presses to functionality during simulation |
Component Creation
| Creating_a_Property | How to create a property |
| Panel_Managers | Overview of the component creation panel managers |
| Assigning_Code_to_an_Existing_Component | Complementing or overriding an existing components functionality |
| Base_Components | The base components and their function |
| Using_A_Base_Component | Creating a new component using a base |
| Starting_Flowchart_Simulation | Information on how to use the flowchart simulation |
| Simulating_Icons_Step_by_Step | Stepping through icons |
| Breakpoints | Using breakpoints |
| Changing_the_Speed_of_a_Simulation | Changing the run speed of the simulator |
| Simulation_Only_Code | Code designed to work only via the simulator |
| Simulation_Events | Event macros used to provide more functionality to both simulation and compiled code |
Chip Specifics
| Compiling_a_Flowchart_to_a_Chip | Information on how to compile a flowchart into machine code |
| Internal_Oscillator | Specifics on using an internal oscillator |
| Phase_Locked_Loop_(PLL) | Specifics on using a PLL frequency multiplier |
| Custom_Interrupts | Custom interrupts for your hardware |
| Debugging_Hardware_and_Software | Tips on how to debug hardware and software |
| In_Circuit_Debugging | Overview of the in circuit debugging (ICD) interface |
| In_Circuit_Test | Overview of the in circuit test (ICT) interface |
| Supporting_Third_Party_Programming_Tools | Using 3rd party programmers such as PICkit and Arduino |
| Viewing_Code_Output | Viewing the code generated by Flowcode |
| Managing_Compiler_Options | Overview of the compiler options settings |
| FCD_Data_Collection | Chip definition files and how to collect data from them |
Support
| Frequently_Asked_Questions | Frequently asked questions |
| Reporting_a_Bug | How to report a bug in Flowcode |
| Licensed_Compiler | Compiler specifics and license agreement |
| Technical_Support | Information on how to get further support |
