Components
Revision as of 14:11, 7 September 2018 by BenR (talk | contribs) (→Peripheral CAL)
Inputs
Inputs: Analog
Image ADC Template Base ADC component with no graphical interface.
Inputs: General
Image Encoder Rotary Encoder component implements a rotary encoder connected to two pins
Image Touch Pads (EB088) This board provides five touch areas for use with capacitive sensing.
Inputs: Keypads
Image Keypad (Generic) Generic component to create a raster scanned custom keypad or button matrix.
Inputs: Switches
Image Switch Array Template A base component for creating an evenly spaced array of switches.
Image Switch Template Base single pin switch with no graphical interface
Outputs
Outputs: General
Image Buzzer Drives a simple fixed frequency buzzer in hardware and simulates the sound of a buzzer in simulation.
Image DAC Output CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips.
Image PWM Pulse Width Modulation, a versitile way of generating a digital pulse using mark / space modulation.
Image Piezo Sounder Drives a simple variable frequency piezo sounder in hardware and simulates the sound in simulation.
Image Speech Speech component allowing Phoneme based speech for use on an embedded platform.
Outputs: LEDs
Image LED (Generic, RGB) An LED with red, green and blue elements that can be mixed together to produce
Image LED Array Template Create an evenly spaced array of LED indicators.
Image LED Charlieplex Create an evenly spaced array of LED indicators using a reduced amount of I/O pins.
Image LED Cube LED Cube component for driving 3D arrays of LEDs.
Image LED Matrix (HT16K33) LED Matrix component designed to work using a HT16K33 LED driver IC.
Image LED Matrix (Parallel) LED Matrix component designed to work using multiple data pins and a single clock pin.
Image LED Matrix (Serial) LED Matrix component designed to work using a single data and clock pin.
Image LED MultiColour Bi (5mm, PCB) An industry standard 5mm diameter bi-colour LED.
Image LED MultiColour Tri (5mm, PCB) An industry standard 5mm diameter tri-colour LED.
Image LED Template Base for creating LEDs and other on/off visual indicators.
Image NeoPixel LED APA102C A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream.
Image NeoPixel LED WS2801 A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream.
Image NeoPixel LED WS2811 WS2812 APA106 A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream.
Displays
Displays: Alphanumeric
Image LCD (Adafruit, OLED) Adafruit OLED LCD display
Image LCD (Generic) Generic configurable alphanumeric LCD display component based on the standard
Image LCD 4x20 (Adafruit, OLED) Adafruit OLED LCD display 4 x 20 characters
Displays: Graphical
Image Bitmap Drawer FAT A component to simplify the process of drawing bitmap images to a graphical display.
Image Bitmap Drawer ROM A component to simplify the process of drawing bitmap images to a graphical display.
Image GLCD Base Base graphical LCD with simulation only interface to allow graphics to be drawn in simulation.
Image GLCD Textfield A component to simplify the process of drawing text to a graphical display.
Image Touch Screen (XPT2046) Low level routines for controlling or interacting with the XPT2046 touch screen controller IC found
Displays: Segment
Image 7Segment (Quad TM1637) Quad seven segment display using an two pin communications bus to reduce the number of control pins.
Image 7Segment (Quad) 14mm seven segment display.
Image 7Segment (Single) Seven segment display modelled after a standard 14mm high unit.
Image Starburst Display Starburst 14 or 16 segment display modelled after a standard 14mm high unit.
Sensors
Sensors
Image Accel Gyro 6_Axis (MPU-6050) MPU-6050 Combined 6-Axis Accelerometer and Gyroscope sensors.
Image Accel Gyro Mag 9_Axis (LSM9DS1) LSM9DS1 Combined 9-Axis Accelerometer, Gyroscope and Magnetometer sensors.
Image Accel Gyro Mag 9_Axis (MPU9250) MPU9250 Combined 9-Axis Accelerometer, Gyroscope and Magnetometer sensors.
Image Accel Mag 6_Axis (LSM303D) LSM303D Combined 6-Axis Accelerometer and Magnetometer sensors
Image Accel Mag 6_Axis (LSM303DLHC) LSM303DLHC Combined 6-Axis Accelerometer and Magnetometer sensors
Image Accelerometer 3_Axis (LIS3LV02DQ) LIS3LV02DQ Accelerometer sensor with options for I2C or SPI communications.
Image Barometer (BME280) A small PCB surface mount barometric pressure sensor with a I2C bus interface.
Image Barometer (MS5637) A small PCB surface mount barometric pressure sensor with a I2C bus interface.
Image Collision Detector Template Polls a chosen panel object to see if it has collided with another object.
Image Colour Sensor (TCS3200) This board provides the ability to detect colours using the TCS3200 sensor.
Image Gyroscope 3_Axis (L3G4200D) Interface to the L3G4200D three axis digital gyroscope.
Image Gyroscope 3_Axis I2C (L3GD20) Interface to the L3GD20 three axis digital gyroscope.
Image Gyroscope 3_Axis SPI (L3GD20) Allows access to a three axis digital gyroscope via an SPI interface.
Image Humidity (SHT21) Humidity and temperature sensor using an SHT21 IC connected via I2C.
Image Photo Reflector Uses InfraRed light to detect if an external object is near to the sensor.
Image Photo Transistor Uses InfraRed light to detect if an external object is near to the sensor.
Image Proximity Analog Template Polls a chosen panel object to test it's distance from this component.
Image Proximity Switch Template Polls a chosen panel object to test it's distance from this component.
Image Temp Humidity (DHT11 ) The DHT11 temperature and humidity sensor is a popular sensor allowing the ambient temperature and relative humidity to be monitored digitally.
Image Temp Humidity (DHT22 ) The DHT22 temperature and humidity sensor is a popular sensor allowing the ambient temperature and relative humidity to be monitored digitally.
Image Temp Humidity (HTS221) A temperature and relative humidity sensor allowing the ambient temperature and relative humidity to be monitored digitally.
Image Thermistor A generic thermistor component that can be used to simulate and create code for any
Image Thermistor Template Base component for creating thermistors.
Grove
Image 7Segment Quad (104030003) Quad seven segment display using an two pin communications bus to reduce the number of control pins.
Image Accel Gyro 6_Axis LSM6DS3 (105020012) Combined 6-Axis Accelerometer and Gyroscope sensors.
Image Barometer BMP280 (101020192) Barometric pressure sensor with a I2C bus interface.
Image Chainable RGB LED v2.0 (104020048) Grove-Chainable RGB LED V2.
Image Grove Water Sensor (101020018) The water sensor uses a 1M ohm pull-up resistor.
Image I2C Color Sensor (101020341) Based on the color sensor TCS34725FN with digital output I2C.
Image Infrared Reflective Sensor (101020174) (101020174) Uses InfraRed light to detect if an external object is near to the sensor.
Image LED Bar v2.0 (104020006) LED Bar is comprised of a 10 segment LED gauge bar and an MY9221 LED controlling chip.
Image Light Sensor (101020132) The Light sensor module is a simple analogue photo transistor.Used to detect the intensity of the indoor light.
Image PIR Motion BISS0001 (101020020) PIR motion sensor component for digital output sensors.
Image Relay (103020005) The Relay is a digital normally open switch capable of switching much higher voltages and curren...
Image Rotary Angle Sensor (101020017) The Rotary Angle sensor is based on a simple analogue potentiometer.
Image Sound Sensor (101020023) The Sound sensor module is a simple microphone.
Image Temp Humidity DHT22 (101020019) The DHT22 temperature and humidity sensor is a popular sensor allowing the ambient
Image Temp Humidity SHT31 (101020212) Humidity and temperature sensor using an SHT31 IC connected via I2C.On screen GUI allows temperature and humidity values to be simulated, and will show allI2C communication in a console window.
Image Temperature Sensor (101020015) Temperature Sensor uses a thermistor to measure ambient temperature.
Image Ultrasonic Ranger (101020010) The ultrasonic sensor is a non-contact distance measurement module.
E-blocks
E-blocks 1
Image Accelerometer (EB068) LIS3LV02DQ Accelerometer sensor with options for I2C or SPI communications.
Image Combo Board (EB083) A simulated version of the EB083 Combo board including LEDs, Switches, LCD, 7-Segs
Image SPI Master (EB013) Low level routines for controlling or interacting with an SPI interface.
Image TCPIP (EB023 v1) TCP/IP component designed to work with the WIZ3100 range of modules from Wiznet.
Image TCPIP (EB023 v2) TCP/IP component designed to work with the WIZ810MJ module from Wiznet,
Image Webserver (EB023 v1) Webserver component designed to work with the NM7010A module from Wiznet,
Image Webserver (EB023 v2) Webserver component designed to work with the WIZ810MJ module from Wiznet,
E-blocks 2
Image Bluetooth (BL0170) Low level routines for controlling a Microchip RN4677 Bluetooth Module.
Image Combo (BL0114) A component to drive the BL0114 Combo board including LEDs, Switches, LCD, 7-Segs
Image GLCD (BL0139) Graphical display component designed to work with the ST7567 type monochrome displays.
Image LCD (BL0169) LCD component to drive the E-blocks 2 BL0169 LCD board.
Image LED (BL0167) LED component to drive the E-blocks 2 BL0167 LED board.
Image Servo Motor (BL0162) Servo motor component to drive the E-blocks 2 BL0162 Servo Motors board.
Image WIFI (BL0136) Wireless LAN component designed to work with the ESP-12S module.
EBM Modules
Image Accel Mag 6_Axis (EBM015) EBM015 Combined 6-Axis Accelerometer and Magnetometer sensors
Image Colour Sensor (EBM018) This board provides the ability to detect colours using the TCS3200 sensor.
Image Dual Potentiometer _ Trimmer (EBM006) This board provides two rotary potentiometers.
Image GLCD (EBM001) Graphical display component designed to work with the EBM001 modules and EB084 E-blocks.
Image Gyroscope (EBM009) Interface to the L3G4200D three axis digital gyroscope.
Image Hall Effect (EBM011) The board has a Hall Effect sensor (SL353) that gives a digital output in the presence of a magnetic field (in the region
Image Humidity (EBM016) Humidity and temperature sensor using an SHT21 IC connected via I2C - as used by the
Image Infrared (EBM020) The Infrared sensor board contains both an IR transmitter and receiver.
Image Potentiometer (EBM002) This board consists of a standard shaft rotary potentiometer that provides a linear voltage
Image Rotary Encoder (EBM007) Provides a rotary encoder with dual digital outputs that provide rotation and direction information.
Image Thermistor (EBM003) A generic thermistor component that can be used to simulate and create code for any
Image Thermocouple TypeK (EBM008) A component matchin the Matrix EBM008 thermocouple board.
Image Touch Pads (EBM013) This board provides two touch areas for use with capacitive sensing.
Image Touch Slider (EBM014) This board provides two touch slide areas for use with capacitive sensing.
Image Ultrasonic (EBM019) This board has both an ultrasonic transmitter and receiver.
Comms
Comms: Interface
Image CAN (Internal, MCP2515) Low level routines for controling the CAN interface either using an external MCP2515 IC and a SPI bus connection
Image FTDI (FTD2XX) Simulation only interface to allow communications with a FTDI USB 232 IC connected to the system.
Image I2C Master Generic Two Wire I2C Communications Interface
Image I2C Slave Generic Two Wire I2C Communications Interface
Image One Wire Low level routines for controlling or interacting with a standard one wire interface.
Image SPI Master Low level routines for controlling or interacting with an SPI interface.
Image UART (RS232) Low level routines for controlling or interacting with a standard asyncronous serial interface.
Comms: Networking
Image Base 64 Component to allow base 64 encoding and decoding.
Image Network Communications A component designed to simplify the process of TCP/IP communications.
Image TCP Template Base TCP/IP component with simulation only interface to allow TCP/IP style network communications in simulation.
Image TCPIP (ENC28J60) A set of routines used to control a ENC28J60 TCP/IP Module.
Image TCPIP (NM7010A) TCP/IP component designed to work with the WIZ3100 range of modules from Wiznet.
Image TCPIP (Raspberry Pi) TCP/IP sockets component for use with Raspberry Pi.
Image TCPIP (WIZ810MJ) TCP/IP component designed to work with the WIZ810MJ module from Wiznet,
Image Webserver (NM7010A) (NM7010A) Webserver component designed to work with the NM7010A module from Wiznet,
Image Webserver (WIZ810MJ) Webserver component designed to work with the WIZ810MJ module from Wiznet,
Comms: System
Image DALI Master A serial based communications protocol designed for controlling lighting, specifically digitally
Image DALI Slave A serial based communications protocol designed for controlling lighting, specifically digitally
Image DMX_512 Master A serial based communications protocol designed for controlling theatrical equipment such
Image DMX_512 Slave A serial based communications protocol designed for controlling theatrical equipment such
Image IO Expander (MCP23017) Provides 16 digital input/output pins arranged into two 8-bit ports using a I2C bus connection.
Image IO Expander (MCP23S17) Provides 16 digital input/output pins arranged into two 8-bit ports using a SPI bus connection.
Image IO Expander (PCF8574) Provides 8 digital input/output pins arranged into an 8-bit port using a I2C bus connection.
Image IO Expander (PCF8575) Provides 16 digital input/output pins arranged into 8-bit ports using a I2C bus connection.
Image Modbus TCP Master Modbus component for talking to Modbus compatible hardware via Ethernet or WIFI.
Image Modbus TCP Slave Modbus component for creating Modbus compatible slave hardware via Ethernet or WIFI.
Image Visi (4DSystems) A way of interacting with the VISI interface designed by 4D systems.
Comms: USB
Image USB HID Component to create and communicate using a standard HID type USB class.
Image USB MIDI Component to create and communicate using a standard MIDI connection.
Image USB Serial Component to create and communicate using a standard CDC type COM port.
Image USB Slave Component to create and communicate using a generic USB communications profile.
Injectors
Image Data Injector Template A base data injector used as a placeholder in components which reference the data injector interface.
Wireless
Image Bluetooth (EB024, Generic AT) Low level routines for controlling a standard AT Bluetooth interface.
Image Bluetooth (HC05 HC06) Low level routines for controlling or interacting with a HC05 or HC06 Bluetooth module.
Image Bluetooth (RN4677) Low level routines for controlling a Microchip RN4677 Bluetooth Module.
Image Bluetooth v2 (EB024, Generic AT) Low level routines for controlling a standard AT Bluetooth interface.
Image GPS (EB056, Generic NMEA) Component designed to process incoming NMEA style GPS data and convert into meaningful
Image GSM (EB066, Generic AT) Low level routines for controlling a standard AT GSM / GPRS interface
Image IrDA (EB012, MCP1250, MCP2120) Low level routines for controlling a standard IrDA interface.
Image RC5 (EB060, Generic 36KHz) Low level routines for controlling a standard RC5 IR interface.
Image RF 2.4GHz (nRF24L01) A simple RF communications module based on the 2.
Image RF ISM (EB063, MRF49XA) A simple RF-ISM communications module based on the Microchip Alpha MRF49XA device.
Image RFID (EB052, RWD_MICODE) Low level routines for controlling a RF Solutions RFID interface
Image RFID (MFRC522) Functions designed to work with the MFRC522 contactless reader IC.
Image SRF (WirelessThings) (SRF) The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module.
Image WLAN (ESP-12S) Wireless LAN component designed to work with the ESP-12S module.
Image WLAN (EB069, ESP8266) (ESP8266) Wireless LAN component designed to work with the ESP8266 module.
Image WLAN (EB069, WIZ610wi) Wireless LAN component designed to work with the WIZ610wi module from Wiznet.
Image Zigbee (EB051, XBEE) (XBEE) Zigbee component designed to work with the XBEE range of modules from Digi.
Storage
Image Auto Version Identifier Basic component designed to provide the program with the date and time of the build.
Image Circular Buffer Circular buffer component allowing easy and efficient first in first out (FIFO) style data byte storage.
Image EEPROM A means of reading data from and writing data to the EEPROM memory onboard the microcontroller.
Image Embed File A component to simplify the process of embedding files into ROM.
Image FAT (SD, SDHC) FAT component allowing access to read and write files on a SD, SDHC or MMC card.
Image Lookup tables A lookup-table component allowing an easy way to place arrays of static data into ROM memory.
Image RTC (MCP7940N) Serial (I2C) Real Time Clock component for MCP7940N device.
Image Real Time Clock (RTC) A Real Time Clock component allowing things like clocks and timers to easily be created.
Image Serial EEPROM (24C32) Serial (I2C) EEPROM component for 24C32
Image String Translator A simple component to allow multiple language support by substituting different strings depending
Image Timer Allows you to measure the passage of time via the use of a hardware timer peripheral.
Image WAV Library FAT Contains component macros to allow playback and recording of WAV files via an SD card.
Mechatronics
Image AllCode Robot Arm Matrix 5-axis Robot Arm with Gripper.
Image Formula AllCode (RB4420) A component to allow all the features of the Formula AllCode robot to be investigated.
Image Formula AllCode API A simulation only component to allow the Formula AllCode robot to be controlled via it's
Image Formula Flowcode A component to allow all the features of the Formula Flowcode robot to be investigated.
Image Motor Template Base component for constructing continuous motion - e.
Image Servo Controller Can control up to eight standard PWM driven servo's.
Image Servo Motor Template Base component for creating custom servo motor simulations.
Image Solenoid Template Base component for constructing solenoids.
Image Stepper Motor Template Enables the creation of a stepper motor component by specifying objects for its appearance.
Shield
Raspberry Pi
Image Sense Hat A component to drive various features on the Raspberry Pi Sense Hat. Supported Features: 8x8 RGB LED / 5-Way Joystick.
MIAC
MIAC Module
Image MIAC (PIC) MIAC - Matrix Industrial Automotive Controller
MIAC: Addon Modules
Image MIAC (PIC) CAN Slave MIAC Slave for MIAC System.
Image MIAC Industrial MIAC Industrial Addon component for MIAC System.
Image MIAC Zigbee Coordinator MIAC Zigbee Coordinator Addon component for MIAC System.
Image MIAC Zigbee Router MIAC Zigbee Router Addon component for MIAC System.
MIAC: PC Peripheral
Image MIAC (PIC) USB Slave Allows Matrix's MIAC PLC to be used as a PC peripheral controlled by Flowcode via a USB
Image MIAC AllCode MIAC AllCode.
DSP
Image Control Allows for several types of control operations to be performed on a buffer.
Image DSP System DSP System main buffer manager responsible for allocating memory, taking care of buffer indexes ...
Image Fast Fourier Transform (FFT) Provides a way of converting a buffer full of time domain data into frequency domain data.
Image Filter Filter component to allow basic filtering to be performed
Image Frequency Generator A frequency generator component designed to plug into the DSP system component and allow several...
Image Input Allows the values from a buffer to be assigned.
Image Output Allows the values from a buffer to be read.
Image Scale Allows the values in a single buffer to be scaled uniformly.
Image Sum Component to combine together two DSP buffers into one an index at a time.
Animation
Image Animator Basic animation and physics simulation for a single object.
Image Motion Helper Helper for building components which require simulation of constant motion.
Image Formula Flowcode Racetrack (HP458) A simple race course for the Formula Flowcode buggy.
Image Maze Generator (HP458) Creates a simulation only randomised maze out of standard micromouse maze walls and pillars.
Image Meter Square Square analogue panel meter.
Image Simulation External Input A simulation only component designed to allow a single digital pin to be toggled at a set frequency.
Image Simulation LED 3mm A single LED 3mm for sim only
Image Simulation LED SMD A simple LED suitable for simulation that does not require a pin connection
Image Simulation Switch Template A base for building switches that do not download to chip.
Scenarios
Image Car Seat An electric car seat chassis with a series of motors and sensors.
Image Pedestrian Crossing A set of pedestrian crossing lights complete with manual light control, a simple state machine and an
Image Sheep Pen A simple sheep pen simulation with two gates and two sensors.
Image Traffic Light 1_Way A set of one way traffic lights complete with manual light control, a simple state machine and an
Image Traffic Light 2_Way A set of two way traffic lights complete with manual light control, a simple state machine and an
Tools
3rd Party Equipment/Tools
Image K8055D Support for the Velleman K8055 USB input/output board.
Image TTi Power Supply _ PL155_P (TTi PL155-P PSU) TTi PL155-P Power Supply Unit Component.
Matrix Tools
Image Console Debugger (Raspberry Pi) Component to allow printing debug messages to the Raspberry Pi Console.
Image Device Helper A purely cosmetic component for viewing the details specific to your current selected target microcontroller.
Image E_block Helper A purely cosmetic component to help simplify E-block connections without having to keep referring to the datasheets.
Image FCD helper A helper control to query the current FCD file
Image IntOsc Helper A component to help configure the speed of the internal oscillator.
Image Scope monitor A component to allow data from analogue and digital pins to be displayed on the scope window.
Modelling Components
Image Clone Matrix Takes a single object and produces a three dimensional array of evenly spaced clones.
Peripheral CAL
Image ADC (CAL) Low level component for dealing with hardware abstracted analogue to digital conversions (ADC).
Image CAN (CAL) Low level component for dealing with hardware abstracted internal CAN functionality.
Image EEPROM (CAL) Low level component for dealing with hardware abstracted EEPROM functionality.
Image HBRIDGE (CAL) Low level component for dealing with hardware abstracted H-Bridge functionality.
Image I2C (CAL) Low level component for dealing with hardware abstracted I2C functionality.
Image PWM (CAL) Low level component for dealing with hardware abstracted Pulse Width Modulation (PWM) functionality.
Image SPI (CAL) Low level component for dealing with hardware abstracted SPI functionality.
Image UART (CAL) Low level component for dealing with hardware abstracted Serial UART functionality.
Shapes
2D Shapes
3D Shapes
Advanced Shapes
Image Bezel Radiused A purely cosmetic component for creating smoothly radiused bezel or frame to fit around
Image Component Label Add a label to a component by including this component as a sub-component.
Image Component Labels Automatically generates labels for all panel objects and components in a given context.
Image Panel Console Viewer An easy way to display the data from up to four console windows on the panel.
Image RxTx Flasher Simple indicator panel intended as a sub-component of communications components.
Image Scale Arc Template A base component for drawing circular dials.
Image Scale Linear Template A base component for drawing scales on horizontal or vertical strips.
Image Slider control A simple graphical interface for a vertical meter or slider control.
Image Wood Gate A simple gate that can be opened and closed via simulation macros.
