Recent Changes - Search:
<^< Set up the Output | Course index | Adding the Switches >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops ## Set up the Equipment ## Counting Sheep Badly ## Set up the Flowchart ## Create the Variables ## Set up the Calculation ## Loop Properties ## Set up the Input ## Set up the Output ##
Adding the LED array ## Adding the Switches ## Simulation ## The Solution - Adding a Delay * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Adding the LED Array
<^< Set up the Output | Course Index | Adding the Switches >^>(:nl:)
# Click once on the Outputs and select 'LED Array' icon. Place the LED Array where you want it on the panel by moving the cursor over the LED Array and then clicking and dragging the selection box into position.
# Change the value of the 'Count' property to '8' - this adds the maximum amount of LED elements to the array.
# Click 'Connections' property in the Properties Pane option. Select 'PORTB' from the drop-down menu, this connects the LED's to the pins on Port B.
# You can also change the colour of the LED Array using the 'Colors' section, when the 'Same Color' property is set to 'Yes' you can change the colour of the whole LED Array with ease, you can also set the colours individually or even change each LED to display a different colour when the 'Same Color' property is set to 'No'. (:nl:)(:table style="clear:both":)
Page last modified on July 22, 2013, at 09:37 AM
