Recent Changes - Search:
<^< Adding the Switches | Course index | The Solution - Adding a Delay >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops ## Set up the Equipment ## Counting Sheep Badly ## Set up the Flowchart ## Create the Variables ## Set up the Calculation ## Loop Properties ## Set up the Input ## Set up the Output ## Adding the LED array ## Adding the Switches ##
Simulation ## The Solution - Adding a Delay * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
<^< Adding the Switches | Course Index | The Solution - Adding a Delay >^>(:nl:)
# Now run the simulation by clicking on the Run button.
# The 'Simulation debugger' window appears - close this window as it is not needed.
# Move the cursor over the switch and give the briefest mouse click you can.
What happens depends on how quickly you click, and how fast your PC works! We want just the B0 LED to light on the array, to show a total of 1 sheep. The program runs at high speed, however, and so keeps cycling through the 'Input' and 'Calculation' steps. As a result, before you have time to release the push switch, the total has incremented (increased by one) several times - continue to the next page to find out why.
(:nl:)(:table style="clear:both":)
Page last modified on June 14, 2013, at 02:53 PM
