Recent Changes - Search:
<^< Adding the LED array | Course index | Simulation >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops ## Set up the Equipment ## Counting Sheep Badly ## Set up the Flowchart ## Create the Variables ## Set up the Calculation ## Loop Properties ## Set up the Input ## Set up the Output ## Adding the LED array ##
Adding the Switches ## Simulation ## The Solution - Adding a Delay * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Adding the Switches
<^< Adding the LED array | Course Index | Simulation >^>(:nl:)
You will use a single push switch.
# Click once on the Inputs and select 'Push Round Panel' icon. Add or drag it onto the System Panel.
# Ensure the 'Connection' property under the 'Connections' section on the Properties Panel is connected to '$PORTA.0'
# Click and drag the 'Text' button from the System Panel toolbar and place it next to the switch. Click on the 'Text' property in the Properties pane and replace the text with "Light beam interruption" in the text box. Manipulate the element using the 'Scale' section on the Properties Panel and move it to a suitable position next to the button.
You should now have a project that looks something like this:
(:nl:)(:table style="clear:both":)
Page last modified on July 22, 2013, at 10:07 AM
