Recent Changes - Search:
<^< Set up the Flowchart | Course index | Set up the Calculation >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops ## Set up the Equipment ## Counting Sheep Badly ## Set up the Flowchart ##
Create the Variables ## Set up the Calculation ## Loop Properties ## Set up the Input ## Set up the Output ## Adding the LED array ## Adding the Switches ## Simulation ## The Solution - Adding a Delay * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
<^< Set up the Flowchart | Course Index | Set up the Calculation >^>(:nl:)
# Click 'View' on the menu bar, and then ensure 'Project Explorer' is checked (View > Project Explorer). Then click on the 'Globals' button at the top of the Project Explorer panel:
# We are going to create two variables, one called 'SHEEP' and the other called 'TOTAL'. The 'SHEEP' variable will show whether a sheep is present or not. The variable 'TOTAL' will store the total number of sheep recorded so far.
# Hover over 'Variables' in the project explorer panel then click on the that appears, then click 'Add new'. You now see the 'Create a New Variable' dialogue box. Type in the name "SHEEP" and then click on OK. You can leave the variable type as 'Byte' as there will not be that many sheep. Create a variable in the same way and name it "TOTAL".
(:nl:)(:table style="clear:both":)
Page last modified on May 02, 2013, at 03:59 PM
