Recent Changes - Search:
<^< Set up the Input | Course index | Adding the LED array >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops ## Set up the Equipment ## Counting Sheep Badly ## Set up the Flowchart ## Create the Variables ## Set up the Calculation ## Loop Properties ## Set up the Input ##
Set up the Output ## Adding the LED array ## Adding the Switches ## Simulation ## The Solution - Adding a Delay * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
Set up the Output
<^< Set up the Input | Course Index | Adding the LED array >^>(:nl:)
# Double-click on the Output icon to open the Output Properties dialogue box.
# Click on the button next to the variable box.
# Double-click on the word 'TOTAL' to insert it into the variable box.
# Back in the Output Properties box, change the port used to 'PORTB'.
# Click on OK to close the Output Properties box.
# The flowchart should now look like this:
(:nl:)(:table style="clear:both":)
Page last modified on May 02, 2013, at 09:39 AM
