Recent Changes - Search:
<^< Counting Sheep Badly | Course index | Create the Variables >^>
Flowcode Step By Step * Introduction to Flowcode * Basic Flowcode Functions * Digital Outputs * Digital Inputs * Basic Loops ## Set up the Equipment ## Counting Sheep Badly ##
Set up the Flowchart ## Create the Variables ## Set up the Calculation ## Loop Properties ## Set up the Input ## Set up the Output ## Adding the LED array ## Adding the Switches ## Simulation ## The Solution - Adding a Delay * The LCD Display * Binary Numbers * Decisions * Goto (Connection Point) * 7-Segment Displays * Software Macro * Strings and Memory * A Simple Hi-Fi
PICmicro Projects * Introduction to PICmicro Projects * Construction Methods * Choosing a Power Source * Adding Inputs * Input Conditioning * Adding Outputs * Adding Drivers
Labs * Introduction and Lesson Plan * 1. Output * 2. Delay * 3. Connection Point * 4. Calculations * 5. Loop * 6. Input * 7. Decision * 8. LCD * 9. Keypad * 10. Analogue + EEPROM * 11. Software Macro * 12. External Interrupt * 13. Timer Interrupt
<^< Counting Sheep Badly | Course Index | Create the Variables >^>(:nl:)
Launch Flowcode and start a new flowchart. Create the flowchart you can see below. This flowchart contains a 'Loop' icon and a 'Calculation' icon which you have not used before.
(:nl:)(:table style="clear:both":)
Page last modified on May 01, 2013, at 01:23 PM
