Flowcode Help Overview
Getting Started
- Activating Flowcode - Activating your Flowcode license
 - Opening Flowcode - Launching the Flowcode application
 - Finding Your Way Around Flowcode - Finding your way around
 - Creating Flowcharts - Creating your first Flowcode flowchart and see the options available
 - Selecting a Target Chip - Selecting the target microcontroller device
 - Configuring the Chip - Configuring your device
 - Opening an Existing Flowchart - Opening an existing .FCFX Flowcode project file
 - Selecting a Template - Opening a template project file
 - Saving a Flowchart - Saving your program
 - Creating Templates - Creating your own templates
 - Closing Flowcode - Closing Flowcode
Using the Flowchart
- Icon Properties - Flowchart icons and their functionality
 - Adding an Icon to a Flowchart - Adding flowchart icons to your program
 - Editing Icon Properties - Editing the properties of a flowchart icon
 - Adding Comments to a Flowchart - Commenting your flowchart
 - Selecting Icons - Selecting icons on the flowchart
 - Flowchart Editing Functions - Functions to make editing your flowchart easier
 - Code Folding - Compressing known working code to increase screen real estate
 - Icon Grouping - Combining multiple icons together into a single group icon
 - C Code Simulation - Simulating C code in your program
 - C Code to Flowchart Conversion - Converting a section of C code into Flowchart icons
 - Code Paradigms - Coding Paradigms - Flowchart, Blocks, Pseudocode, C Code
 - Tab Tear Off - Multi Monitor Support - How to manage tabs on multi-monitor systems
Macros
- Creating a New Macro - Creating a new flowchart macro or subroutine
 - Editing and Deleting Macros - Editing a macro and removing a macro from your program
 - Using the Project Explorer - Features of the project explorer designed to help simplify programming
 - Exporting a Macro - Exporting a macro from within Flowcode
 - Importing a Macro - Importing a macro into Flowcode
Functions
- Mathematical Functions - Built in routines designed to help with mathematical operations such as Sin() and Float
 - String Manipulation Functions - Built in routines designed to help with string manipulation
 - Undo and Redo - Undo and Redo operations and shortcuts
 - Disabling Icons - Disabling flowchart icons to comment out sections of code
 - Icon Annotations - Icon annotations
 - Find and Replace - Ability to search within your flowcode project to replace specific text with alternate text
Variables
- Creating Variables - How to create a variable
 - Variable Types - Variable types and their meanings
 - Editing Variables - How to edit a variable
 - Variable Manager - The Flowcode variable manager interface
 - Finite State Machines - Programming tutorial on using state machines
Panels
- Panels Where And Why - What the panels do and how they help you design your system
 - Choosing your Simulation Panel - Information about choosing the correct panel
 - Dashboard Panel - More in depth information on the dashboard panel
 - System Panel - More in depth information on the system panel
 - Zooming the View - Zooming in and out on panels
 - Camera Control - Controlling the camera looking at the panel
 - Object Position - Object positioning on the panels
 - Local and World Space - Local vs World space regarding coordinates
 - Object Scale - Objects and their scale
 - Object Rotation - Rotating objects
 - Working With Primitives - Using primitive objects inside Flowcode
 - Working With Meshes - Using meshes inside Flowcode
Tools and Views
- Tools and Views - Various tools and views available inside Flowcode
 - Oscilloscope - How to use the oscilloscope window to monitor repeating waveforms and pin activity
 - Console - How to use the data console window in your programs
 - Data Recorder - How to use the data recorder window in your programs
 - Icon Lists Pane - The icon lists pane
 - Project Options - Detailed help on the Project Options window
 - Global Options - Detailed help on the Global Options window
 - Chip View - The chip view window
 - Analog Window - The analogue inputs window
 - Properties Panel - The properties panel
 - Simulation Debugger - The simulation debugger window
 - Component Debugger - The component debugger window
 - Supplementary Code - Supplementary code and its usage
 - Saving Images in Flowcode - Creating images of your flowchart source
 - Auto Documentation - Auto documentation features to speed up development
 - Window Layouts - The window layouts manager
 - E-blocks2 Auto ID - E-blocks 2 Auto ID
Components
- Components - Information about what a component is and how they work inside the Flowcode environment.
 - Common Components - Information on some of the more commonly used components
 - Selecting Component Macros - Information on how to use component macros
 - Component Help Files - How to get access to component help via Flowcode
 - Component Properties - Information on how to use component properties
 - Component Tree - Information regarding the component tree hierarchy
 - Replacing a Component - Replacing one component with another
 - CAL Components - Overview of code abstraction layer components
 - Using the Data Injector - Data injectors and communications components
 - Component Directories - Information on creating your own components directories
 - Editing Key Mappings - Assigning keyboard presses to functionality during simulation
 - Remappable Peripheral Pins - Assigning pins to peripherals on devices with re-mappable functionality.
Component Creation
- New Component Features - Additional component creation features added in Flowcode 8
 - Creating a Property - How to create a property
 - IO Properties - How to create and use IO properties
 - Component Configuration - Overview of the component creation panel managers
 - Customising A Component - Creating a new customised version of a component
 - Assigning Code to an Existing Component - Complementing or overriding an existing components functionality
 - Base Components - The base components and their function
 - Using CAL Components - Creating a component using CAL functionality (I2C / SPI / UART etc)
 - Using A Base Component - Creating a new component using a base component
 - Exercises - Worked exercises including creating components
 - Example - Number Conversions - Creating a helper component to help convert between number systems Decimal, Hexadecimal and Binary
 - Example - Creating a two-wheeled robot - Creating a 2 wheeled robot from scratch (simulation & downloadable)
- Starting Flowchart Simulation - Information on how to use the flowchart simulation
 - Simulating Icons Step-by-Step - Stepping through icons
 - Breakpoints - Using breakpoints
 - Bookmarks - Using bookmarks
 - Changing the Speed of a Simulation - Changing the run speed of the simulator
 - Simulation-Only Code - Code designed to work only via the simulator
 - Different Code For Sim and Download - Detecting if code is for download or simulation
 - Simulation Events - Event macros used to provide more functionality to both simulation and compiled code
 - DLL Support - Changing the nature of a macro to instead call a external DLL function (simulation only)
 - Data Scope Test - Information on how to use the Flowcode data scope window.
 - Code Profiling - Introduction to Code Profiling, and how to use it
Chip Specifics
- Compiling a Flowchart to a Chip - Information on how to compile a flowchart into machine code
 - Internal Oscillator - Specifics on using an internal oscillator
 - Phase Locked Loop (PLL) - Specifics on using a PLL frequency multiplier
 - Custom Interrupts - Custom interrupts for your hardware
 - Debugging Hardware and Software - Tips on how to debug hardware and software
 - Ghost Technology - Information on Ghost, (usage of ICD and ICT, and general settings)
 - Supporting Third Party Programming Tools - Using 3rd party programmers such as PICkit and Arduino
 - Viewing Code Output - Viewing the code generated by Flowcode
 - Managing Compiler Options - Overview of the compiler options settings
 - FCD Data Collection - Chip definition files and how to collect data from them
SCADA
- Matrix SCADA - What is SCADA and how is it used
 - SCADA Examples - A number of prebuilt example projects demonstrating how the Matrix SCADA mode can be used
 - Matrix SCADA Deployment - How to deploy a SCADA project ready for sharing
Support
- Dynamic Updates - Getting updates and using older versions
 - Reporting a Bug - How to report a bug in Flowcode
 - Licensed Compiler - Compiler specifics and license agreement
 - Technical Support - Information on how to get further support
