Components
Jump to navigationJump to searchEmbedded Components
Switch | ||
Rotary Switch | 3d |
Switch (Microswitch) | 3d |
Switch Push Button | 2d |
Switch Rotary 0 - 1 | 2d |
Image | Switch Rotary 0 - 15 | 2d |
Image | Switch Slide | 2d |
Image | Switch User Images | 2d |
Switches | ||
Switch Array (Push) | 3d |
Image | Switch Array (Push) | 2d |
Switch Array (Slide) | 3d |
Image | Switch Array (Slide) | 2d |
Keypad | ||
Keypad | 2d |
Keypad (Cursor 3x3) | 2d |
Keypad (Hex 4x4) | 2d |
Keypad (Numeric 3x4) | 2d |
Analog Input | ||
ADC (AD7680) | 2d |
ADC (MCP356X) | 2d |
ADC QUAD + DAC (PCF8591) | 2d |
ADC Template | 3d |
Joystick (Sparkfun Quiic) | 3d |
Image | Joystick (Sparkfun Quiic) | 2d |
Image | Potentiometer | 2d |
General Input | ||
Grey Code Encoder | 3d |
Image | Grey Code Encoder | 2d |
Quadrature Encoder | 3d |
General Output | ||
PWM (Internal) | 2d |
Relay (Grove 103020005) | 2d |
Analog Output | ||
DAC (AD5662) | 2d |
DAC (Internal) | 2d |
Image | DAC (MCP4725) | 2d |
DAC (MCP47x6) | 2d |
DAC (MCP48x1) | 2d |
DAC (MCP49x1) | 2d |
DAC Dual (MCP48x2) | 2d |
DAC Dual (MCP49x2) | 2d |
DAC Quad (MCP4728) | 2d |
Digital Potentiometer (MCP41XX / MCP42XX) | 2d |
Digital Potentiometer (MCP44XX) | 2d |
Digital Potentiometer (MCP45XX / MCP46XX) | 2d |
Digital Potentiometer (X9Cx0x) | 2d |
Audio Output | ||
Buzzer | 2d |
Image | DFPlayer (MP3 / WAV) | 2d |
Piezo Sounder | 2d |
Speech (Phoneme) | 2d |
LED | ||
Image | LED Mono | 2d |
LED MultiColour Bi (5mm, PCB) | 3d |
LED MultiColour Tri (5mm, PCB) | 3d |
LEDs | ||
Chainable RGB LED v2.0 (Grove 104020048) | 2d |
Image | LED Array | 2d |
LED Matrix (Parallel) | 3d |
LED Matrix (Serial) | 3d |
RGB LED APA102C | 3d |
Image | RGB LED SK6812 RGBW | 3d |
RGB LED WS2801 | 3d |
RGB LED WS2811 / WS2812 / APA106 | 3d |
Mechatronics | ||
Coupling | 3d |
Image | DC Motor | 2d |
Gearbox | 3d |
Linear Actuator | 3d |
Image | Servo Motor | 2d |
Servo Motor Controller | 2d |
Solenoid DC | 2d |
Image | Stepper Motor | 2d |
Kalman Filter | 2d |
DSP Inputs | ||
Input ADC | 2d |
Input CSV | 2d |
Input Digital | 2d |
Input Digital Pin | 2d |
Waveform Generator | 2d |
DSP Outputs | ||
Level | 2d |
Output CSV | 2d |
Output DAC | 2d |
Output Digital | 2d |
Output Digital Pin | 2d |
Output PWM | 2d |
DSP Operators | ||
Deinterlace | 3d |
Delay | 2d |
Fast Fourier Transform (FFT) | 2d |
Filter | 2d |
Interlace | 3d |
Math | 2d |
Median | 2d |
Multiplex | 2d |
Offset | 2d |
On/Off Control | 2d |
PID Control | 2d |
Rectifier | 2d |
Scale | 2d |
Simulated Control Load | 2d |
Development | ||
Released |
AllCode | ||
MIAC: PC Peripheral | ||
API Slave Devices | ||
API (ESP32) | 2d |
Test Injectors | ||
Test Equipment | ||
Third Party |
Indicators | ||
Circular Gauge for v10 | 2d |
Console Writer | 2d |
Logo Indicator | 3d |
Numeric Display | 3d |
Image | On / Off Indicator | 2d |
Controls | ||
Circular Knob for v10 | 2d |
Image | Joystick | 2d |
Joystick | 3d |
Image | RadioButton | 2d |
Charts | ||
Image | Area Chart (for v10) | 2d |
Image | Bar Chart (for v10) | 2d |
Image | Column Chart (for v10) | 2d |
Image | XY Chart (for v10) | 2d |
SCADA Tools | ||
Runtime Tools | ||
COM Port | 2d |
Console Debugger | 2d |
Console User Input | 2d |
Data Recorder Setup | 2d |
Event Log | 2d |
Message Box | 2d |
Panel Console Viewer | 2d |
Serial Monitor | 2d |
Simulation External Input | 2d |
Timed Event Trigger | 2d |
Matrix Tools | ||
Device Helper | 2d |
FCD helper | 2d |
IntOsc Helper | 2d |
Is Sim | 2d |
Scenarios | ||
3D Printer | 3d |
Airplane Landing Gear | 3d |
CNC Machine | 3d |
Car Seat | 3d |
Daytona Racetrack | 3d |
Maze Generator | 3d |
Pedestrian Crossing | 3d |
Sheep Pen | 3d |
Traffic Light 1-Way | 3d |
Traffic Light 2-Way | 3d |
Primitives (2d) | ||
Image | BaseChart | 2d |
Image | Button | 2d |
Image | Canvas | 2d |
Image | ComboBox | 2d |
Image | ComplexShape | 2d |
Image | Connection | 2d |
Image | EditBox | 2d |
Image | Gauge | 2d |
Image | Grid | 2d |
Image | Image | 2d |
Image | Line | 2d |
Image | NumericIndicator | 2d |
Image | Shape | 2d |
Image | Switch | 2d |
Image | Text | 2d |
Primitives (3d) | ||
Image | Label | 3d |
Image | Shape | 3d |
Image | Textbox | 3d |
2D Shapes | ||
Ellipse | 2d |
Label | 2d |
Line | 2d |
Rectangle | 2d |
Rounded rectangle | 2d |
Textbox | 2d |
3D Shapes | ||
Bowl | 3d |
Cone | 3d |
Cuboid | 3d |
Cylinder | 3d |
Diamond | 3d |
Hemisphere | 3d |
Honeycomb | 3d |
Prism | 3d |
Pyramid | 3d |
Sphere | 3d |
Tube | 3d |
App Developer Components
Message Box | 2d |
WAV Library File | 2d |
Joystick | 3d |
Switches | ||
Numeric | ||
Dialogue |
Base 64 | 2d |
CSV Read/Write | 2d |
Circular Buffer (16-bit) | 2d |
Circular Buffer (8-bit) | 2d |
Circular Buffer (Float) | 2d |
EEPROM (DS28E07) | 2d |
Embed File | 2d |
Event Log | 2d |
File Access | 2d |
Lookup tables | both |
Map Function | 2d |
Median 16-bit | 2d |
Median 32-bit | 2d |
Median Float | 2d |
String Translator | 2d |
Type Conversions | 2d |
DSP Inputs | ||
Input CSV | 2d |
DSP Outputs | ||
Level | 2d |
Output CSV | 2d |
DSP Operators | ||
Deinterlace | 3d |
Delay | 2d |
Filter | 2d |
Interlace | 3d |
Math | 2d |
Median | 2d |
Multiplex | 2d |
Offset | 2d |
PID Control | 2d |
Rectifier | 2d |
Scale | 2d |
Comms: USB | ||
Comms: Networking | ||
Network Communications | 2d |
Webserver (GENERIC - Flash / File) | 2d |
Comms: Interface | ||
CAN (Internal, MCP2515) | 2d |
COM Port | 2d |
I2C Master | 2d |
Image | LIN Master | 2d |
One Wire (DS2482) | 2d |
SPI Master | 2d |
Comms: System | ||
MULTIUART | 2d |
Modbus TCP Master | 2d |
Modbus TCP Slave | 2d |
Comms: IoT/Cloud | ||
BBC News | 2d |
BBC Weather Forecast | 2d |
BBC Weather Observation | 2d |
IoT Made Easy | 2d |
MQTT Client | 2d |
Wireless | ||
RFID (MFRC522) | 2d |
E-blocks 2 | ||
E-blocks 1 | ||
EBM Modules | ||
Humidity | 2d |
MIAC Module | ||
Arduino Shield | ||
Raspberry Pi Hat | ||
Misc Circuit | ||
Robotics |
Development | ||
Released |
AllCode | ||
Control | 2d |
Electrical Machines | both |
Formula AllCode API | 2d |
API (ESP32) | 2d |
Test Equipment | ||
Third Party | ||
FTDI (FTD2XX) | 2d |
K8055D | 3d |
Image | Grid | 2d |
Image | Line | 2d |
Image | Text | 2d |
2D Shapes | ||
Ellipse | 2d |
Label | 2d |
Line | 2d |
Rectangle | 2d |
Textbox | 2d |
3D Shapes | ||
Bowl | 3d |
Cone | 3d |
Cuboid | 3d |
Cylinder | 3d |
Diamond | 3d |
Hemisphere | 3d |
Honeycomb | 3d |
Prism | 3d |
Pyramid | 3d |
Sphere | 3d |
Tube | 3d |
