Components
Embedded Components
| Switch | ||
| Rotary Switch | 3d | |
| Switch (Microswitch) | 3d | |
| Switch Push Button | 2d | |
| Switch Rotary 0 - 1 | 2d | |
| Switch Rotary 0 - 15 | 2d | |
| Image | Switch Slide | 2d |
| Image | Switch User Images | 2d |
| Switches | ||
| Switch Array (Push) | 3d | |
| Image | Switch Array (Push) | 2d |
| Switch Array (Slide) | 3d | |
| Image | Switch Array (Slide) | 2d |
| Keypad | ||
| Keypad | 2d | |
| Keypad (Cursor 3x3) | 2d | |
| Keypad (Hex 4x4) | 2d | |
| Keypad (Numeric 3x4) | 2d | |
| Analog Input | ||
| ADC (AD7680) | 2d | |
| ADC (MCP356X) | 2d | |
| ADC QUAD + DAC (PCF8591) | 2d | |
| ADC Template | 3d | |
| Joystick (Sparkfun Quiic) | 3d | |
| Image | Joystick (Sparkfun Quiic) | 2d |
| Image | Potentiometer | 2d |
| General Input | ||
| Grey Code Encoder | 3d | |
| Image | Grey Code Encoder | 2d |
| Quadrature Encoder | 3d | |
| General Output | ||
| PWM (Internal) | 2d | |
| Relay (Grove 103020005) | 2d | |
| Analog Output | ||
| DAC (AD5662) | 2d | |
| DAC (Internal) | 2d | |
| Image | DAC (MCP4725) | 2d |
| DAC (MCP47x6) | 2d | |
| DAC (MCP48x1) | 2d | |
| DAC (MCP49x1) | 2d | |
| DAC Dual (MCP48x2) | 2d | |
| DAC Dual (MCP49x2) | 2d | |
| DAC Quad (MCP4728) | 2d | |
| Digital Potentiometer (MCP41XX / MCP42XX) | 2d | |
| Digital Potentiometer (MCP44XX) | 2d | |
| Digital Potentiometer (MCP45XX / MCP46XX) | 2d | |
| Digital Potentiometer (X9Cx0x) | 2d | |
| Audio Output | ||
| Buzzer | 2d | |
| Image | DFPlayer (MP3 / WAV) | 2d |
| Piezo Sounder | 2d | |
| Speech (Phoneme) | 2d | |
| LED | ||
| Image | LED Mono | 2d |
| LED MultiColour Bi (5mm, PCB) | 3d | |
| LED MultiColour Tri (5mm, PCB) | 3d | |
| LEDs | ||
| Chainable RGB LED v2.0 (Grove 104020048) | 2d | |
| Image | LED Array | 2d |
| LED Matrix (Parallel) | 3d | |
| LED Matrix (Serial) | 3d | |
| RGB LED APA102C | 3d | |
| Image | RGB LED SK6812 RGBW | 3d |
| RGB LED WS2801 | 3d | |
| RGB LED WS2811 / WS2812 / APA106 | 3d | |
| Mechatronics | ||
| Coupling | 3d | |
| Image | DC Motor | 2d |
| Gearbox | 3d | |
| Linear Actuator | 3d | |
| Image | Servo Motor | 2d |
| Servo Motor Controller | 2d | |
| Solenoid DC | 2d | |
| Image | Stepper Motor | 2d |
| Kalman Filter | 2d | |
| DSP Inputs | ||
| Input ADC | 2d | |
| Input CSV | 2d | |
| Input Digital | 2d | |
| Input Digital Pin | 2d | |
| Waveform Generator | 2d | |
| DSP Outputs | ||
| Level | 2d | |
| Output CSV | 2d | |
| Output DAC | 2d | |
| Output Digital | 2d | |
| Output Digital Pin | 2d | |
| Output PWM | 2d | |
| DSP Operators | ||
| Deinterlace | 3d | |
| Delay | 2d | |
| Fast Fourier Transform (FFT) | 2d | |
| Filter | 2d | |
| Interlace | 3d | |
| Math | 2d | |
| Median | 2d | |
| Multiplex | 2d | |
| Offset | 2d | |
| On/Off Control | 2d | |
| PID Control | 2d | |
| Rectifier | 2d | |
| Scale | 2d | |
| Simulated Control Load | 2d | |
| Development | ||
| Released |
| AllCode | ||
| MIAC: PC Peripheral | ||
| API Slave Devices | ||
| API (ESP32) | 2d | |
| Test Injectors | ||
| Test Equipment | ||
| Third Party | ||
| Indicators | ||
| Circular Gauge for v10 | 2d | |
| Console Writer | 2d | |
| Logo Indicator | 3d | |
| Numeric Display | 3d | |
| Image | On / Off Indicator | 2d |
| Controls | ||
| Circular Knob for v10 | 2d | |
| Image | Joystick | 2d |
| Joystick | 3d | |
| Image | RadioButton | 2d |
| Charts | ||
| Image | Area Chart (for v10) | 2d |
| Image | Bar Chart (for v10) | 2d |
| Image | Column Chart (for v10) | 2d |
| Image | XY Chart (for v10) | 2d |
| SCADA Tools | ||
| Runtime Tools | ||
| COM Port | 2d | |
| Console Debugger | 2d | |
| Console User Input | 2d | |
| Data Recorder Setup | 2d | |
| Event Log | 2d | |
| Message Box | 2d | |
| Panel Console Viewer | 2d | |
| Serial Monitor | 2d | |
| Simulation External Input | 2d | |
| Timed Event Trigger | 2d | |
| Matrix Tools | ||
| Device Helper | 2d | |
| FCD helper | 2d | |
| IntOsc Helper | 2d | |
| Is Sim | 2d | |
| Scenarios | ||
| 3D Printer | 3d | |
| Airplane Landing Gear | 3d | |
| CNC Machine | 3d | |
| Car Seat | 3d | |
| Daytona Racetrack | 3d | |
| Maze Generator | 3d | |
| Pedestrian Crossing | 3d | |
| Sheep Pen | 3d | |
| Traffic Light 1-Way | 3d | |
| Traffic Light 2-Way | 3d | |
| Primitives (2d) | ||
| Image | BaseChart | 2d |
| Image | Button | 2d |
| Image | Canvas | 2d |
| Image | ComboBox | 2d |
| Image | ComplexShape | 2d |
| Image | Connection | 2d |
| Image | EditBox | 2d |
| Image | Gauge | 2d |
| Image | Grid | 2d |
| Image | Image | 2d |
| Image | Line | 2d |
| Image | NumericIndicator | 2d |
| Image | Shape | 2d |
| Image | Switch | 2d |
| Image | Text | 2d |
| Primitives (3d) | ||
| Image | Label | 3d |
| Image | Shape | 3d |
| Image | Textbox | 3d |
| 2D Shapes | ||
| Ellipse | 2d | |
| Label | 2d | |
| Line | 2d | |
| Rectangle | 2d | |
| Rounded rectangle | 2d | |
| Textbox | 2d | |
| 3D Shapes | ||
| Bowl | 3d | |
| Cone | 3d | |
| Cuboid | 3d | |
| Cylinder | 3d | |
| Diamond | 3d | |
| Hemisphere | 3d | |
| Honeycomb | 3d | |
| Prism | 3d | |
| Pyramid | 3d | |
| Sphere | 3d | |
| Tube | 3d | |
App Developer Components
| WAV Library File | 2d |
| Joystick | 3d | |
| Switches | ||
| Numeric | ||
| Dialogue | ||
| Base 64 | 2d | |
| CSV Read/Write | 2d | |
| Circular Buffer (16-bit) | 2d | |
| Circular Buffer (8-bit) | 2d | |
| Circular Buffer (Float) | 2d | |
| EEPROM (DS28E07) | 2d | |
| Embed File | 2d | |
| Event Log | 2d | |
| File Access | 2d | |
| Lookup tables | both | |
| Map Function | 2d | |
| Median 16-bit | 2d | |
| Median 32-bit | 2d | |
| Median Float | 2d | |
| String Translator | 2d | |
| Type Conversions | 2d |
| DSP Inputs | ||
| Input CSV | 2d | |
| DSP Outputs | ||
| Level | 2d | |
| Output CSV | 2d | |
| DSP Operators | ||
| Delay | 2d | |
| Filter | 2d | |
| Interlace | 3d | |
| Math | 2d | |
| Median | 2d | |
| Multiplex | 2d | |
| Offset | 2d | |
| Rectifier | 2d | |
| Scale | 2d | |
| Comms: USB | ||
| Comms: Networking | ||
| Network Communications | 2d | |
| Webserver (GENERIC - Flash / File) | 2d | |
| Comms: Interface | ||
| CAN (Internal, MCP2515) | 2d | |
| COM Port | 2d | |
| I2C Master | 2d | |
| Image | LIN Master | 2d |
| One Wire (DS2482) | 2d | |
| SPI Master | 2d | |
| Comms: System | ||
| MULTIUART | 2d | |
| Modbus TCP Master | 2d | |
| Modbus TCP Slave | 2d | |
| Comms: IoT/Cloud | ||
| BBC News | 2d | |
| BBC Weather Forecast | 2d | |
| BBC Weather Observation | 2d | |
| IoT Made Easy | 2d | |
| MQTT Client | 2d | |
| Wireless | ||
| RFID (MFRC522) | 2d | |
| E-blocks 2 | ||
| E-blocks 1 | ||
| EBM Modules | ||
| Humidity | 2d | |
| MIAC Module | ||
| Arduino Shield | ||
| Raspberry Pi Hat | ||
| Misc Circuit | ||
| Robotics | ||
| Development | ||
| Released |
| AllCode | ||
| Control | 2d | |
| Electrical Machines | both | |
| Formula AllCode API | 2d | |
| Test Equipment | ||
| Third Party | ||
| FTDI (FTD2XX) | 2d | |
| K8055D | 3d | |
| Image | Grid | 2d |
| Image | Line | 2d |
| Image | Text | 2d |
| 2D Shapes | ||
| Ellipse | 2d | |
| Label | 2d | |
| Line | 2d | |
| Rectangle | 2d | |
| Textbox | 2d | |
| 3D Shapes | ||
| Bowl | 3d | |
| Cone | 3d | |
| Cuboid | 3d | |
| Cylinder | 3d | |
| Diamond | 3d | |
| Hemisphere | 3d | |
| Honeycomb | 3d | |
| Prism | 3d | |
| Pyramid | 3d | |
| Sphere | 3d | |
| Tube | 3d | |
