Components
Jump to navigationJump to searchEmbedded
| Switch | ||
| Image | Switch Slide | 2d |
| Switch Rotary 0 - 1 | 2d | |
| Switch (Microswitch) | 3d | |
| Rotary Switch | 3d | |
| Switch Template | 3d | |
| Image | Switch User Images | 2d |
| Switch Push Button | 2d | |
| Image | Switch Rotary 0 - 15 | 2d |
| Switches | ||
| Switch Array (Push) | 3d | |
| Switch Array (Slide) | 3d | |
| Image | Switch Array (Slide) | 2d |
| Switch Array Template | both | |
| Image | Switch Array (Push) | 2d |
| Keypad | ||
| Keypad (Cursor 3x3) | 2d | |
| Keypad (Hex 4x4) | 2d | |
| Keypad | 2d | |
| Keypad (Numeric 3x4) | 2d | |
| Keypad (Generic) | 2d | |
| Analog Input | ||
| Image | Potentiometer | 2d |
| ADC (MCP356X) | 2d | |
| Joystick (Sparkfun Quiic) | 3d | |
| ADC Template | 3d | |
| ADC (AD7680) | 2d | |
| Image | Joystick (Sparkfun Quiic) | 2d |
| Image | ADC Template | 2d |
| ADC QUAD + DAC (PCF8591) | 2d | |
| General Input | ||
| Grey Code Encoder | 3d | |
| Quadrature Encoder | 3d | |
| Wii Nunchuk | 2d | |
| Image | Grey Code Encoder | 2d |
| Image | DSPBuffer | 2d |
| Deinterlace | 3d | |
| Output Digital Pin | 2d | |
| Output Digital | 2d | |
| Image | DSPBufferRef | 2d |
| Interlace | 3d | |
| Filter | 2d | |
| Input ADC | 2d | |
| On/Off Control | 2d | |
| Output DAC | 2d | |
| Output CSV | 2d | |
| Output PWM | 2d | |
| Input CSV | 2d | |
| Math | 2d | |
| Kalman Filter | 2d | |
| Offset | 2d | |
| Input Digital Pin | 2d | |
| Simulated Control Load | 2d | |
| Rectifier | 2d | |
| Multiplex | 2d | |
| Input Digital | 2d | |
| Waveform Generator | 2d | |
| Delay | 2d | |
| Level | 2d | |
| PID Control | 2d | |
| Scale | 2d | |
| Fast Fourier Transform (FFT) | 2d | |
| Median | 2d |
| Development | ||
| Image | Base2dChart | 2d |
| Image | Base2dStatic | 2d |
| Image | Base2dGauge | 2d |
| Image | Base2dObject | 2d |
| Released | ||
| AllCode | ||
| MIAC: PC Peripheral | ||
| API Slave Devices | ||
| API (Arduino Uno) | 2d | |
| API (ECIO40P) | 2d | |
| API (BL0032) | 2d | |
| API (Arduino Mega) | 2d | |
| API (ECIO28P) | 2d | |
| API (ESP32) | 2d | |
| API (RPI) | 2d | |
| API (Interface Board) | 2d | |
| Test Injectors | ||
| Injector (COM) | 2d | |
| Injector (Human Interface) | 2d | |
| Injector (File) | 2d | |
| Injector (AT) | 2d | |
| Injector (API Digital Output) | 2d | |
| Injector (API Analog Input) | 2d | |
| Injector (Flowcode vNet) | 2d | |
| Injector (API Digital Input) | 2d | |
| Test Equipment | ||
| Third Party | ||
| Primitives (2d) | ||
| Image | BaseChart | 2d |
| Image | Button | 2d |
| Image | Canvas | 2d |
| Image | ComboBox | 2d |
| Image | ComplexShape | 2d |
| Image | Connection | 2d |
| Image | EditBox | 2d |
| Image | Gauge | 2d |
| Image | Grid | 2d |
| Image | Image | 2d |
| Image | Line | 2d |
| Image | NumericIndicator | 2d |
| Image | Shape | 2d |
| Image | Switch | 2d |
| Image | Text | 2d |
| Primitives (3d) | ||
| Image | Shape | 3d |
| Image | Label | 3d |
| Image | Textbox | 3d |
| 2D Shapes | ||
| Textbox | 2d | |
| Line | 2d | |
| Rounded rectangle | 2d | |
| Ellipse | 2d | |
| Label | 2d | |
| Rectangle | 2d | |
| Image | Bevel | 2d |
| 3D Shapes | ||
| Cone | 3d | |
| Honeycomb | 3d | |
| Cuboid | 3d | |
| Tube | 3d | |
| Prism | 3d | |
| Pyramid | 3d | |
| Diamond | 3d | |
| Sphere | 3d | |
| Hemisphere | 3d | |
| Bowl | 3d | |
| Cylinder | 3d | |
