Components
Jump to navigationJump to searchEmbedded Components
| Switch | ||
| Image | Switch Slide | 2d |
| Switch Rotary 0 - 1 | 2d | |
| Switch (Microswitch) | 3d | |
| Rotary Switch | 3d | |
| Switch Template | 3d | |
| Image | Switch User Images | 2d |
| Switch Push Button | 2d | |
| Image | Switch Rotary 0 - 15 | 2d |
| Switches | ||
| Switch Array (Push) | 3d | |
| Switch Array (Slide) | 3d | |
| Image | Switch Array (Slide) | 2d |
| Switch Array Template | both | |
| Image | Switch Array (Push) | 2d |
| Keypad | ||
| Keypad (Cursor 3x3) | 2d | |
| Keypad (Hex 4x4) | 2d | |
| Keypad | 2d | |
| Keypad (Numeric 3x4) | 2d | |
| Keypad (Generic) | 2d | |
| Analog Input | ||
| Image | Potentiometer | 2d |
| ADC (MCP356X) | 2d | |
| Joystick (Sparkfun Quiic) | 3d | |
| ADC Template | 3d | |
| ADC (AD7680) | 2d | |
| Image | Joystick (Sparkfun Quiic) | 2d |
| Image | ADC Template | 2d |
| ADC QUAD + DAC (PCF8591) | 2d | |
| General Input | ||
| Grey Code Encoder | 3d | |
| Quadrature Encoder | 3d | |
| Wii Nunchuk | 2d | |
| Image | Grey Code Encoder | 2d |
| Image | DSPBuffer | 2d |
| Deinterlace | 3d | |
| Output Digital Pin | 2d | |
| Output Digital | 2d | |
| Image | DSPBufferRef | 2d |
| Interlace | 3d | |
| Filter | 2d | |
| Input ADC | 2d | |
| On/Off Control | 2d | |
| Output DAC | 2d | |
| Output CSV | 2d | |
| Output PWM | 2d | |
| Input CSV | 2d | |
| Math | 2d | |
| Kalman Filter | 2d | |
| Offset | 2d | |
| Input Digital Pin | 2d | |
| Simulated Control Load | 2d | |
| Rectifier | 2d | |
| Multiplex | 2d | |
| Input Digital | 2d | |
| Waveform Generator | 2d | |
| Delay | 2d | |
| Level | 2d | |
| PID Control | 2d | |
| Scale | 2d | |
| Fast Fourier Transform (FFT) | 2d | |
| Median | 2d |
| Development | ||
| Image | Base2dChart | 2d |
| Image | Base2dStatic | 2d |
| Image | Base2dGauge | 2d |
| Image | Base2dObject | 2d |
| Released | ||
| AllCode | ||
| MIAC: PC Peripheral | ||
| API Slave Devices | ||
| API (Arduino Uno) | 2d | |
| API (ECIO40P) | 2d | |
| API (BL0032) | 2d | |
| API (Arduino Mega) | 2d | |
| API (ECIO28P) | 2d | |
| API (ESP32) | 2d | |
| API (RPI) | 2d | |
| API (Interface Board) | 2d | |
| Test Injectors | ||
| Injector (COM) | 2d | |
| Injector (Human Interface) | 2d | |
| Injector (File) | 2d | |
| Injector (AT) | 2d | |
| Injector (API Digital Output) | 2d | |
| Injector (API Analog Input) | 2d | |
| Injector (Flowcode vNet) | 2d | |
| Injector (API Digital Input) | 2d | |
| Test Equipment | ||
| Third Party | ||
| Primitives (2d) | ||
| Image | BaseChart | 2d |
| Image | Button | 2d |
| Image | Canvas | 2d |
| Image | ComboBox | 2d |
| Image | ComplexShape | 2d |
| Image | Connection | 2d |
| Image | EditBox | 2d |
| Image | Gauge | 2d |
| Image | Grid | 2d |
| Image | Image | 2d |
| Image | Line | 2d |
| Image | NumericIndicator | 2d |
| Image | Shape | 2d |
| Image | Switch | 2d |
| Image | Text | 2d |
| Primitives (3d) | ||
| Image | Shape | 3d |
| Image | Label | 3d |
| Image | Textbox | 3d |
| 2D Shapes | ||
| Textbox | 2d | |
| Line | 2d | |
| Rounded rectangle | 2d | |
| Ellipse | 2d | |
| Label | 2d | |
| Rectangle | 2d | |
| Image | Bevel | 2d |
| 3D Shapes | ||
| Cone | 3d | |
| Honeycomb | 3d | |
| Cuboid | 3d | |
| Tube | 3d | |
| Prism | 3d | |
| Pyramid | 3d | |
| Diamond | 3d | |
| Sphere | 3d | |
| Hemisphere | 3d | |
| Bowl | 3d | |
| Cylinder | 3d | |
App Developer Components
| Image | Joystick | 2d |
| Joystick | 3d | |
| Simulation Switch Template | both | |
| Console User Input | 2d | |
| Switch | 2d | |
| Image | Number Pad | 2d |
| Input Message Box | 2d | |
| Image | RadioButton | 2d |
| Mouse | 2d | |
| Circular Knob for v10 | 2d | |
| Image | LED Array | 2d |
| LinearSlider | 2d | |
| Keyboard | 2d | |
| Switches | ||
| Numeric | ||
| Dialogue | ||
| Image | XY Chart (for v10) | 2d |
| Image | Data Sheet B | 2d |
| Image | Ternary Chart | 2d |
| Image | Line Chart | 2d |
| Image | Bubble Chart | 2d |
| Image | Bar Chart (for v10) | 2d |
| Image | Polar Chart | 2d |
| Image | Pie Chart | 2d |
| Image | Data Sheet | 2d |
| Image | Area Chart (for v10) | 2d |
| Image | Radar Chart | 2d |
| Image | Column Chart (for v10) | 2d |
| Movement & Orientation | ||
| Magnetometer 3-Axis | 2d | |
| Accel / Gyro / Mag 9-Axis | 2d | |
| Image | Accelerometer 3-Axis | 2d |
| Gyroscope 3-Axis | 2d | |
| Gyroscope 3-Axis SPI (L3GD20) | 2d | |
| Accelerometer 3-Axis | 2d | |
| Accel / Gyro 6-Axis | 2d | |
| Gyroscope 3-Axis I2C (L3GD20) | 2d | |
| Accel / Gyro 6-Axis (Grove 105020012) | 2d | |
| Accel / Mag 6-Axis | 2d | |
| Image | Accel / Gyro 6-Axis | 2d |
| Environmental | ||
| Image | Barometer | 2d |
| Temp / Humidity | 2d | |
| Thermocouple | 2d | |
| Temperature (DS18B20) | 2d | |
| Barometer | 2d | |
| Temperature (DS18S20) | 2d | |
| Barometer (BMP280 / Grove 101020192) | 2d | |
| Image | BME688 Air Quality | 2d |
| Barometer (DPS310) | 2d | |
| Temperature (DS1822) | 2d | |
| Temp / Humidity (Grove 101020212) | 2d | |
| Electrical | ||
| Image | ACS7xx Current Sensor | 2d |
| Magnetic | ||
| Light | ||
| Image | Range Time of Flight (VL53L0X) | 2d |
| Colour Sensor (Grove 101020341) | 3d | |
| Infrared Array AMG88xx | 2d | |
| Force | ||
| Image | Touch Screen (FT6X06) | 2d |
| Audio | ||
| General Sensor | ||
| Click | ||
| Grove | ||
| Circular Buffer (16-bit) | 2d | |
| Event Log | 2d | |
| String Translator | 2d | |
| Embed File | 2d | |
| Type Conversions | 2d | |
| IButton (DS1990) | 2d | |
| CSV Read/Write | 2d | |
| Property Manager | 2d | |
| Base 64 | 2d | |
| String Initialiser | 2d | |
| Median 16-bit | 2d | |
| Median Float | 2d | |
| Circular Buffer (8-bit) | 2d | |
| Map Function | 2d | |
| EEPROM (DS28E07) | 2d | |
| Lookup tables | both | |
| Circular Buffer (Float) | 2d | |
| Timed Event Trigger | 2d | |
| Median 32-bit | 2d | |
| XML JSON Parser | 2d |
| Interlace | 3d | |
| Filter | 2d | |
| Output CSV | 2d | |
| Input CSV | 2d | |
| Math | 2d | |
| Offset | 2d | |
| Rectifier | 2d | |
| Multiplex | 2d | |
| Delay | 2d | |
| Level | 2d | |
| Scale | 2d | |
| Median | 2d |
| Comms: USB | ||
| Comms: Networking | ||
| TCP Template | 2d | |
| Network Communications | 2d | |
| Webserver (GENERIC - Flash / File) | 2d | |
| Comms: Interface | ||
| I2C Master | 2d | |
| One Wire (DS2482) | 2d | |
| Image | LIN Master | 2d |
| SPI Master | 2d | |
| COM Port | 2d | |
| CAN (Internal, MCP2515) | 2d | |
| Comms: System | ||
| Modbus TCP Master | 2d | |
| Modbus TCP Slave | 2d | |
| IO Expander | 2d | |
| MULTIUART | 2d | |
| Comms: IoT/Cloud | ||
| IoT Made Easy | 2d | |
| MQTT Client | 2d | |
| BBC News | 2d | |
| BBC Weather Observation | 2d | |
| BBC Weather Forecast | 2d | |
| Wireless | ||
| Image | RFID (Sparkfun Quiic / ID-12LA) | 2d |
| RFID (MFRC522) | 2d | |
| E-blocks 2 | ||
| E-blocks 1 | ||
| EBM Modules | ||
| Humidity | 2d | |
| MIAC Module | ||
| Arduino Shield | ||
| Raspberry Pi Hat | ||
| Misc Circuit | ||
| Robotics | ||
| Development | ||
| Released | ||
| AllCode | ||
| API (RPI) | 2d | |
| Test Equipment | ||
| Third Party | ||
| Image | Grid | 2d |
| Image | Line | 2d |
| Image | Text | 2d |
| 2D Shapes | ||
| Textbox | 2d | |
| Line | 2d | |
| Ellipse | 2d | |
| Label | 2d | |
| Rectangle | 2d | |
| 3D Shapes | ||
| Cone | 3d | |
| Honeycomb | 3d | |
| Cuboid | 3d | |
| Tube | 3d | |
| Prism | 3d | |
| Pyramid | 3d | |
| Diamond | 3d | |
| Sphere | 3d | |
| Hemisphere | 3d | |
| Bowl | 3d | |
| Cylinder | 3d | |
