Components
Jump to navigationJump to searchEmbedded
Switch | ||
Image | Switch Slide | 2d |
Switch Rotary 0 - 1 | 2d |
Switch (Microswitch) | 3d |
Rotary Switch | 3d |
Switch Template | 3d |
Image | Switch User Images | 2d |
Switch Push Button | 2d |
Image | Switch Rotary 0 - 15 | 2d |
Switches | ||
Switch Array (Push) | 3d |
Switch Array (Slide) | 3d |
Image | Switch Array (Slide) | 2d |
Switch Array Template | both |
Image | Switch Array (Push) | 2d |
Keypad | ||
Keypad (Cursor 3x3) | 2d |
Keypad (Hex 4x4) | 2d |
Keypad | 2d |
Keypad (Numeric 3x4) | 2d |
Keypad (Generic) | 2d |
Analog Input | ||
Image | Potentiometer | 2d |
ADC (MCP356X) | 2d |
Joystick (Sparkfun Quiic) | 3d |
ADC Template | 3d |
ADC (AD7680) | 2d |
Image | Joystick (Sparkfun Quiic) | 2d |
Image | ADC Template | 2d |
ADC QUAD + DAC (PCF8591) | 2d |
General Input | ||
Grey Code Encoder | 3d |
Quadrature Encoder | 3d |
Wii Nunchuk | 2d |
Image | Grey Code Encoder | 2d |
Image | DSPBuffer | 2d |
Deinterlace | 3d |
Output Digital Pin | 2d |
Output Digital | 2d |
Image | DSPBufferRef | 2d |
Interlace | 3d |
Filter | 2d |
Input ADC | 2d |
On/Off Control | 2d |
Output DAC | 2d |
Output CSV | 2d |
Output PWM | 2d |
Input CSV | 2d |
Math | 2d |
Kalman Filter | 2d |
Offset | 2d |
Input Digital Pin | 2d |
Simulated Control Load | 2d |
Rectifier | 2d |
Multiplex | 2d |
Input Digital | 2d |
Waveform Generator | 2d |
Delay | 2d |
Level | 2d |
PID Control | 2d |
Scale | 2d |
Fast Fourier Transform (FFT) | 2d |
Median | 2d |
Development | ||
Image | Base2dChart | 2d |
Image | Base2dStatic | 2d |
Image | Base2dGauge | 2d |
Image | Base2dObject | 2d |
Released |
AllCode | ||
MIAC: PC Peripheral | ||
API Slave Devices | ||
API (Arduino Uno) | 2d |
API (ECIO40P) | 2d |
API (BL0032) | 2d |
API (Arduino Mega) | 2d |
API (ECIO28P) | 2d |
API (ESP32) | 2d |
API (RPI) | 2d |
API (Interface Board) | 2d |
Test Injectors | ||
Injector (COM) | 2d |
Injector (Human Interface) | 2d |
Injector (File) | 2d |
Injector (AT) | 2d |
Injector (API Digital Output) | 2d |
Injector (API Analog Input) | 2d |
Injector (Flowcode vNet) | 2d |
Injector (API Digital Input) | 2d |
Test Equipment | ||
Third Party |
Primitives (2d) | ||
Image | BaseChart | 2d |
Image | Button | 2d |
Image | Canvas | 2d |
Image | ComboBox | 2d |
Image | ComplexShape | 2d |
Image | Connection | 2d |
Image | EditBox | 2d |
Image | Gauge | 2d |
Image | Grid | 2d |
Image | Image | 2d |
Image | Line | 2d |
Image | NumericIndicator | 2d |
Image | Shape | 2d |
Image | Switch | 2d |
Image | Text | 2d |
Primitives (3d) | ||
Image | Shape | 3d |
Image | Label | 3d |
Image | Textbox | 3d |
2D Shapes | ||
Textbox | 2d |
Line | 2d |
Rounded rectangle | 2d |
Ellipse | 2d |
Label | 2d |
Rectangle | 2d |
Image | Bevel | 2d |
3D Shapes | ||
Cone | 3d |
Honeycomb | 3d |
Cuboid | 3d |
Tube | 3d |
Prism | 3d |
Pyramid | 3d |
Diamond | 3d |
Sphere | 3d |
Hemisphere | 3d |
Bowl | 3d |
Cylinder | 3d |
