Components
Jump to navigationJump to searchEmbedded Components
Switch | ||
Rotary Switch | 3d |
Switch (Microswitch) | 3d |
Switch Push Button | 2d |
Switch Rotary 0 - 1 | 2d |
Image | Switch Rotary 0 - 15 | 2d |
Image | Switch Slide | 2d |
Image | Switch User Images | 2d |
Switches | ||
Switch Array (Push) | 3d |
Image | Switch Array (Push) | 2d |
Switch Array (Slide) | 3d |
Image | Switch Array (Slide) | 2d |
Keypad | ||
Keypad | 2d |
Keypad (Cursor 3x3) | 2d |
Keypad (Hex 4x4) | 2d |
Keypad (Numeric 3x4) | 2d |
Analog Input | ||
ADC (AD7680) | 2d |
ADC (MCP356X) | 2d |
ADC QUAD + DAC (PCF8591) | 2d |
ADC Template | 3d |
Joystick (Sparkfun Quiic) | 3d |
Image | Joystick (Sparkfun Quiic) | 2d |
Image | Potentiometer | 2d |
General Input | ||
Grey Code Encoder | 3d |
Image | Grey Code Encoder | 2d |
Quadrature Encoder | 3d |
Wii Nunchuk | 2d |
Deinterlace | 3d |
Delay | 2d |
Fast Fourier Transform (FFT) | 2d |
Filter | 2d |
Input ADC | 2d |
Input CSV | 2d |
Input Digital | 2d |
Input Digital Pin | 2d |
Interlace | 3d |
Level | 2d |
Math | 2d |
Median | 2d |
Multiplex | 2d |
Offset | 2d |
On/Off Control | 2d |
Output CSV | 2d |
Output DAC | 2d |
Output Digital | 2d |
Output Digital Pin | 2d |
Output PWM | 2d |
PID Control | 2d |
Rectifier | 2d |
Scale | 2d |
Simulated Control Load | 2d |
Waveform Generator | 2d |
DSP Inputs | ||
DSP Outputs | ||
DSP Operators | ||
Kalman Filter | 2d |
Development | ||
Released |
AllCode | ||
MIAC: PC Peripheral | ||
API Slave Devices | ||
API (Arduino Mega) | 2d |
API (Arduino Uno) | 2d |
API (BL0032) | 2d |
API (ECIO28P) | 2d |
API (ECIO40P) | 2d |
API (ESP32) | 2d |
API (Interface Board) | 2d |
API (RPI) | 2d |
Test Injectors | ||
Injector (API Analog Input) | 2d |
Injector (API Digital Input) | 2d |
Injector (API Digital Output) | 2d |
Injector (AT) | 2d |
Injector (COM) | 2d |
Injector (File) | 2d |
Injector (Flowcode vNet) | 2d |
Injector (Human Interface) | 2d |
Test Equipment | ||
Third Party |
Primitives (2d) | ||
Image | BaseChart | 2d |
Image | Button | 2d |
Image | Canvas | 2d |
Image | ComboBox | 2d |
Image | ComplexShape | 2d |
Image | Connection | 2d |
Image | EditBox | 2d |
Image | Gauge | 2d |
Image | Grid | 2d |
Image | Image | 2d |
Image | Line | 2d |
Image | NumericIndicator | 2d |
Image | Shape | 2d |
Image | Switch | 2d |
Image | Text | 2d |
Primitives (3d) | ||
Image | Label | 3d |
Image | Shape | 3d |
Image | Textbox | 3d |
2D Shapes | ||
Ellipse | 2d |
Label | 2d |
Line | 2d |
Rectangle | 2d |
Rounded rectangle | 2d |
Textbox | 2d |
3D Shapes | ||
Bowl | 3d |
Cone | 3d |
Cuboid | 3d |
Cylinder | 3d |
Diamond | 3d |
Hemisphere | 3d |
Honeycomb | 3d |
Prism | 3d |
Pyramid | 3d |
Sphere | 3d |
Tube | 3d |
App Developer Components
Circular Knob for v10 | 2d |
Console User Input | 2d |
Input Message Box | 2d |
Image | Joystick | 2d |
Joystick | 3d |
Keyboard | 2d |
Image | LED Array | 2d |
LinearSlider for v10 | 2d |
Mouse | 2d |
Image | Number Pad | 2d |
Image | RadioButton | 2d |
Switches | ||
Numeric | ||
Dialogue |
Movement & Orientation | ||
Accel / Gyro / Mag 9-Axis | 2d |
Accel / Gyro 6-Axis | 2d |
Image | Accel / Gyro 6-Axis | 2d |
Accel / Gyro 6-Axis (Grove 105020012) | 2d |
Accel / Mag 6-Axis | 2d |
Image | Accelerometer 3-Axis | 2d |
Gyroscope 3-Axis | 2d |
Gyroscope 3-Axis I2C (L3GD20) | 2d |
Gyroscope 3-Axis SPI (L3GD20) | 2d |
Magnetometer 3-Axis | 2d |
Wii Nunchuk | 2d |
Movement Orientation | ||
Environmental | ||
Image | BME688 Air Quality | 2d |
Image | Barometer | 2d |
Barometer | 2d |
Barometer (BMP280 / Grove 101020192) | 2d |
Barometer (DPS310) | 2d |
Temp / Humidity | 2d |
Temp / Humidity (Grove 101020212) | 2d |
Temperature (DS1822) | 2d |
Temperature (DS18B20) | 2d |
Temperature (DS18S20) | 2d |
Thermocouple | 2d |
Thermocouple | 2d |
Electrical | ||
Image | ACS7xx Current Sensor | 2d |
Magnetic | ||
Light | ||
Colour Sensor (Grove 101020341) | 3d |
Infrared Array AMG88xx | 2d |
Image | Range Time of Flight (VL53L0X) | 2d |
Force | ||
Image | Touch Screen (FT6X06) | 2d |
Audio |
Map Function | 2d |
Base 64 | 2d |
CSV Read/Write | 2d |
Circular Buffer (16-bit) | 2d |
Circular Buffer (8-bit) | 2d |
Circular Buffer (Float) | 2d |
EEPROM (DS28E07) | 2d |
Embed File | 2d |
Event Log | 2d |
File Access | 2d |
IButton (DS1990) | 2d |
Lookup tables | both |
Median 16-bit | 2d |
Median 32-bit | 2d |
Median Float | 2d |
Property Manager | 2d |
Standard Deviation | 2d |
String Initialiser | 2d |
String Translator | 2d |
Timed Event Trigger | 2d |
Type Conversions | 2d |
XML JSON Parser | 2d |
Deinterlace | 3d |
Delay | 2d |
Filter | 2d |
Input CSV | 2d |
Interlace | 3d |
Level | 2d |
Math | 2d |
Median | 2d |
Multiplex | 2d |
Offset | 2d |
Output CSV | 2d |
PID Control | 2d |
Rectifier | 2d |
Scale | 2d |
DSP Inputs | ||
DSP Outputs | ||
DSP Operators | ||
Comms: USB | ||
Comms: Networking | ||
Network Communications | 2d |
Webserver (GENERIC - Flash / File) | 2d |
Comms: Interface | ||
CAN (Internal, MCP2515) | 2d |
COM Port | 2d |
I2C Master | 2d |
Image | LIN Master | 2d |
One Wire (DS2482) | 2d |
SPI Master | 2d |
Comms: System | ||
IO Expander | 2d |
IO Expander | 2d |
IO Expander | 2d |
IO Expander | 2d |
MULTIUART | 2d |
Modbus Master (SCADA) | 2d |
Modbus Slave (SCADA) | 2d |
Modbus TCP Master | 2d |
Modbus TCP Slave | 2d |
Comms: IoT/Cloud | ||
BBC News | 2d |
BBC Weather Forecast | 2d |
BBC Weather Observation | 2d |
IoT Made Easy | 2d |
MQTT Client | 2d |
Wireless | ||
RFID (MFRC522) | 2d |
Image | RFID (Sparkfun Quiic / ID-12LA) | 2d |
E-blocks 2 | ||
E-blocks 1 | ||
EBM Modules | ||
Humidity | 2d |
MIAC Module | ||
Arduino Shield | ||
Raspberry Pi Hat | ||
Misc Circuit | ||
Robotics |
Development | ||
Released |
AllCode | ||
Control | 2d |
Electrical Machines | both |
Formula AllCode API | 2d |
MIAC AllCode API (dsPIC) | 2d |
Image | MIAC NXT AllCode API | 2d |
MIAC USB Slave API (PIC) | 2d |
Robot Arm AllCode API | 2d |
Robot Arm v2 | both |
API (BL0032) | 2d |
API (ESP32) | 2d |
API (RPI) | 2d |
Test Equipment | ||
PicoScope | 2d |
TTI Power Supply - PL155-P | 2d |
TTI TG5011 Signal Generator | 2d |
Third Party | ||
FTDI (FTD2XX) | 2d |
K8055D | 3d |
Image | Grid | 2d |
Image | Line | 2d |
Image | Text | 2d |
2D Shapes | ||
Ellipse | 2d |
Label | 2d |
Line | 2d |
Rectangle | 2d |
Textbox | 2d |
3D Shapes | ||
Bowl | 3d |
Cone | 3d |
Cuboid | 3d |
Cylinder | 3d |
Diamond | 3d |
Hemisphere | 3d |
Honeycomb | 3d |
Prism | 3d |
Pyramid | 3d |
Sphere | 3d |
Tube | 3d |
