Components
Revision as of 10:55, 16 November 2022 by BenR (talk | contribs)
Embedded Components
Segment
Image 4-Digit Display (Grove 104030003) 2d
Image 4-Digit Display (Grove 104030003) 3d
Image 7Segment (74HC595) 2d
Image 7Segment (74HC595) 3d
Image 7Segment (Hex TM1637) 3d
Image 7Segment (Hex TM1637) 2d
Image 7Segment (Quad TM1637) 3d
Image 7Segment (Quad TM1637) 2d
Image 7Segment (Quad) 2d
Image 7Segment (Quad) 3d
Image 7Segment (Single) 3d
Image 7Segment (Single) 2d
Image Starburst Display 3d
Image Starburst Display 2d
Alphanumeric
Image LCD (Adafruit, 16x2) 2d
Image LCD (Adafruit, 20x4) 2d
Image LCD (Electronic Assembly) 2d
Image LCD (Generic, 16x2) 2d
Image LCD (Generic, 20x4) 2d
Image LCD (Generic, Configurable) 2d
Image LCD (Grove - I2C) 2d
Image LCD (Grove - UART) 2d
Image LCD (ST7032i) 2d
Image LCD Base 2d
Image LCD Base 2d
Image LCD I2C (Backpack) 2d
Image LCD I2C (LCM1602) 2d
Image LCD SPI (MiniClick) 2d
Image LCD control 2d
Graphical Color
Image GLCD (4D Goldelox) 2d
Image GLCD (4D Picaso v1) 2d
Image GLCD (4D Picaso v2) 2d
Image GLCD (ILI9163C) 2d
Image GLCD (ILI9341 SPI) 2d
Image GLCD (ILI9341) 2d
Image GLCD (ILI9488 SPI) 2d
Image GLCD (ILI9488) 2d
Image GLCD (LS020) 2d
Image GLCD (SSD1289) 2d
Image GLCD (SSD1331) 2d
Image GLCD (SSD1351 SPI) 2d
Image GLCD (SSD1351) 2d
Image GLCD (SSD1963) Parallel 2d
Image GLCD (ST7789V) 2d
Image GLCD (STM32F429ZI) 2d
Image GLCD (STM32F469NI) 2d
Image GLCD (STM32F746NG) 2d
Image Nextion Display 2d
Image Raspberry Pi HDMI 2d
Graphical Monochrome
Image GLCD (Grove OLED) 2d
Image GLCD (KS0108) 2d
Image GLCD (PDC8544) 2d
Image GLCD (SH1106) I2C 2d
Image GLCD (SH1106) SPI 2d
Image GLCD (SSD1305) 2d
Image GLCD (SSD1305) Buffered 2d
Image GLCD (SSD1306) 2d
Image GLCD (SSD1306) Buffered 2d
Image GLCD (SSD1306) I2C 2d
Image GLCD (SSD1306) I2C LK both
Image GLCD (SSD1306) SPI both
Image GLCD (SSD1306) SPI Free both
Image GLCD (SSD1322) Buffered 2d
Image GLCD (SSD1322) Parallel 2d
Image GLCD (SSD1327) I2C 2d
Image GLCD (SSD1327) SPI 2d
Image GLCD (ST7036) I2C 2d
Image GLCD (ST7565R) Parallel 2d
Image GLCD (ST7565R) SPI 2d
Image GLCD (ST7567) SPI 2d
Image GLCD (ST7567) SPI NOBUFF 2d
Image GLCD (ST7920) Parallel 2d
Image GLCD (T6963C) 2d
Image GLCD (TLS8201) 2d
Image GLCD (UC1701) 2d
Image GLCD Free (ST7567) SPI both
Image GLCD eINK (IL3829) 2d
Graphical Library
Image Display Manager 2d
Image GLCD Base 2d
Image GLCD Bitmap Drawer FAT 2d
Image GLCD Bitmap Drawer ROM 2d
Image GLCD Graph Creator 2d
Image GLCD Graph Creator XY 2d
Image GLCD Textfield 2d
Image ResistiveTouch 2d
Image gLCD Font Library 2d
Image Collision Detector Template 3d
Image Proximity Analog Template both
Image Proximity Switch Template 3d
Image Thermistor Template both
Movement & Orientation
Movement Orientation
Image Accel / Gyro / Mag 9-Axis (LSM9DS1) 2d
Image Accel / Gyro / Mag 9-Axis (MPU9250) 2d
Image Accel / Gyro 6-Axis (Grove 105020012) 2d
Image Accel / Gyro 6-Axis (MPU-6050) 2d
Image Accel / Gyro 6-Axis (MPU-6886) 2d
Image Accel / Mag 6-Axis (LSM303D) 2d
Image Accel / Mag 6-Axis (LSM303DLHC) 2d
Image Accelerometer 3-Axis (LIS3LV02DQ) 2d
Image Accelerometer 3-Axis (MMA8452Q) 2d
Image Gyroscope 3-Axis (L3G4200D) 2d
Image Gyroscope 3-Axis I2C (L3GD20) 2d
Image Gyroscope 3-Axis SPI (L3GD20) 2d
Image Magnetometer (SM324) 2d
Image Magnetometer 3-Axis (HMC5883L) 2d
Image Magnetometer 3-Axis (QMC5883L) 2d
Image Wii Nunchuk 2d
Environmental
Image Air Quality (BME688) 2d
Image Analogue Temp Sensors 2d
Image Barometer 2d
Image Barometer (BME280) 2d
Image Barometer (BMP180) 2d
Image Barometer (BMP280 / Grove 101020192) 2d
Image Barometer (DPS310) 2d
Image Pulse Oximeter (Max30100) 2d
Image Temp / Humidity 2d
Image Temp / Humidity (DHT11) 2d
Image Temp / Humidity (DHT22) 2d
Image Temp / Humidity (Grove 101020019) 2d
Image Temp / Humidity (Grove 101020212) 2d
Image Temperature 2d
Image Temperature (DS1822) 2d
Image Temperature (DS18B20) 2d
Image Temperature (DS18S20) 2d
Image Temperature Infrared 2d
Image Temperature Sensor (Grove 101020015) 2d
Image Thermistor 2d
Image Thermocouple 2d
Image Water Sensor (Grove 101020018) 2d
Electrical
Image ACS7xx Current Sensor 2d
Image LTSR Current Transducer 2d
Magnetic
Image Hall Effect Analog 2d
Image Hall Effect Digital 3d
Image Reed Switch 3d
Light
Image Ambient Light 2d
Image Beam Breaker 3d
Image Colour Sensor 3d
Image Colour Sensor (Grove 101020341) 3d
Image Infrared Array AMG88xx 2d
Image Infrared Reflective Sensor (Grove 101020174) 3d
Image Light Sensor (Grove 101020132) 2d
Image PIR Motion (Grove 101020020) 2d
Image Photo Reflector 3d
Image Photo Reflector 2d
Image Photo Transistor 3d
Image Photo Transistor 2d
Image Range Time of Flight (VL53L0X) 2d
Force
Image Load Cell 2d
Image Touch Screen (FT6X06) 2d
Image Touch Screen (XPT2046) 2d
Audio
Image Heelight Sensor (Grove 101020312) 2d
Image Sound Sensor (Grove 101020023) 2d
Image Ultrasonic 2d
Image Ultrasonic Ranger (Grove 101020010) 2d
Comms: USB
Image USB HID 2d
Image USB MIDI 2d
Image USB Serial 2d
Image USB Slave 2d
Comms: Networking
Image Hydro Encryption 2d
Image Network Communications 2d
Image Network Communications Dummy both
Image TCP Template 2d
Image TCP/IP 2d
Image TCP/IP 2d
Image TCP/IP 2d
Image TCP/IP 2d
Image TCP/IP 2d
Image TCP/IP DUMMY both
Image TCP/IP Dummy both
Image WLAN 2d
Image WLAN 2d
Image WLAN (EB069, WIZ610wi) 3d
Image WLAN ESP32 2d
Image WLAN ESP32 (Dummy) both
Image Webserver 2d
Image Webserver 2d
Image Webserver (GENERIC - Flash / File) 2d
Image Webserver (NM7010A) 2d
Comms: Interface
Image CAN (Internal, MCP2515) 2d
Image I2C Master 2d
Image I2C Slave 2d
Image I2S Master/Slave ESP32 2d
Image LIN Master 2d
Image LIN Slave 2d
Image One Wire 2d
Image One Wire (DS2482) 2d
Image SPI Master 2d
Image SPI Slave 2d
Image UART (RS232) 2d
Image UART Software (Timer) 2d
Comms: System
Image DALI Master 2d
Image DALI Slave 2d
Image DMX-512 Master 2d
Image DMX-512 Slave 2d
Image I2C Multiplexer (TCA9548A) 2d
Image IO Expander 2d
Image MIDI 2d
Image MULTIUART 2d
Image Modbus Master 2d
Image Modbus Slave 2d
Image Modbus Slave USB 2d
Image Modbus TCP Master 2d
Image Modbus TCP Slave 2d
Image Visi (4DSystems) 2d
Comms: IoT/Cloud
Image BBC News 2d
Image BBC Weather Forecast 2d
Image BBC Weather Observation 2d
Image EtherCAT Slave (EasyCAT) 2d
Image IoT Made Easy 2d
Image MQTT Client 2d
Image Reddit News Headlines both
Wireless
Image Bluetooth 2d
Image Bluetooth (EB024, Generic AT) 2d
Image Bluetooth (ESP32 SPP) 2d
Image Bluetooth (HC05 / HC06) 2d
Image Bluetooth v2 (EB024, Generic AT) 2d
Image GPS (EB056, Generic NMEA) 2d
Image GSM (EB066, Generic AT) 2d
Image IrDA (EB012, MCP1250, MCP2120) 2d
Image LoRa 2d
Image RF 2.4GHz 2d
Image RF ISM (EB063, MRF49XA) 2d
Image RFID (EB052, RWD-MICODE) 2d
Image RFID (MFRC522) 2d
Image RFID (Sparkfun Quiic / ID-12LA) 2d
Image SRF (WirelessThings) 2d
Image WLAN (EB069-00-2, RN171) both
Image WLAN Dummy (EB069, ESP8266) both
Image WLAN Dummy (EB069, WIZ610wi) both
Image Zigbee (EB051, XBEE) 2d
Indicators
Image Circular Gauge for v10 2d
Image Console Writer 2d
Image Dashboard Text 3d
Image Indicator Gauge 3d
Image Indicator Meter 3d
Image LinearGauge for v10 2d
Image Logo Indicator 3d
Image Numeric Display 3d
Image Numeric Label 3d
Image On / Off Indicator 2d
Image Simulation LED Template 2d
Image Speech (RealSpeak) 2d
Image String Label 3d
Controls
Image Circular Knob for v10 2d
Image Control Knob 3d
Image Image Switch both
Image Joystick 2d
Image Joystick 3d
Image LinearSlider for v10 2d
Image MIAC Keypad both
Image MIAC Keypad (V3) both
Image Number Pad 2d
Image RadioButton 2d
Image Simulation Switch Template both
Charts
Image Area Chart (for v10) 2d
Image Bar Chart (for v10) 2d
Image Bubble Chart (for v10) 2d
Image Column Chart (for v10) 2d
Image Data Sheet both
Image Data Sheet 2d
Image Data Sheet B 2d
Image Line Chart (for v10) 2d
Image Pie Chart (for v10) 2d
Image Polar Chart (for v10) 2d
Image Radar Chart (for v10) 2d
Image Ternary Chart (for v10) 2d
Image XY Chart (for v10) 2d
Image XY Chart new 2d
SCADA Tools
Runtime Tools
Image COM Port 2d
Image Console Debugger 2d
Image Console User Input 2d
Image Data Recorder Setup 2d
Image Event Log 2d
Image Input Message Box 2d
Image Keyboard 2d
Image Message Box 2d
Image Mouse 2d
Image Panel Console Viewer 2d
Image Panel Console Viewer 3d
Image Property Manager 2d
Image Serial Monitor 2d
Image Simulation External Input 2d
Image Timed Event Trigger 2d
Image Tone Generator 2d
Image XML JSON Parser 2d
Matrix Tools
Image Auto Version Identifier Free both
Image Device Helper 2d
Image FCD helper 2d
Image IntOsc Helper 2d
Image Is Sim 2d
Scenarios
Image 3D Printer 3d
Image Airplane Landing Gear 3d
Image CNC Machine 3d
Image Car Seat 3d
Image Daytona Racetrack 3d
Image Maze Generator 3d
Image Pedestrian Crossing 3d
Image Sheep Pen 3d
Image Traffic Light 1-Way 3d
Image Traffic Light 2-Way 3d
App Developer Components
E-blocks 2
E-blocks 1
EBM Modules
Image Humidity 2d
MIAC Module
Arduino Shield
Raspberry Pi Hat
Misc Circuit
Robotics
