Components
Embedded Components
General Input | ||
Grey Code Encoder | 3d | |
Grey Code Encoder 2D | 2d | |
IO Expander (MCP23017) | 2d | |
IO Expander (MCP23S17) | 2d | |
IO Expander (PCF8574) | 2d | |
IO Expander (PCF8575) | 2d | |
Quadrature Encoder | 3d | |
Quadrature Encoder 2D | 2d | |
Analog Input | ||
ADC (AD7680) | 2d | |
ADC (MCP356X) | 2d | |
ADC QUAD + DAC (PCF8591) | 2d | |
ADC Template | 2d | |
ADC Template 2D | 2d | |
Joystick (Sparkfun Quiic) | 3d | |
Joystick (Sparkfun Quiic) 2D | 2d | |
Potentiometer | 2d | |
Potentiometer (Slider) | 2d | |
Switch | ||
Rotary Switch | 3d | |
Switch (Microswitch) | 3d | |
Switch Push Button | 2d | |
Switch Rotary 0 - 1 | 2d | |
Switch Rotary 0 - 15 | 2d | |
Switch Slide | 2d | |
Switch User Images | 2d | |
Switches | ||
Switch Array (Push) | 3d | |
Switch Array (Push) 2D | 2d | |
Switch Array (Slide) | 3d | |
Switch Array (Slide) 2D | 2d | |
Keypad | ||
Keypad | 2d | |
Keypad (Cursor 3x3) | 2d | |
Keypad (Hex 4x4) | 2d |
Buffer | ||
Circular Buffer (16-bit) | 2d | |
Circular Buffer (8-bit) | 2d | |
Circular Buffer (Float) | 2d | |
EEPROM | ||
EEPROM | 2d | |
EEPROM (DS28E07) | 2d | |
Flash EEPROM | 2d | |
IButton (DS1990) | 2d | |
Serial EEPROM (24C01 - 24C16) | 2d | |
Serial EEPROM (24C32) | 2d | |
Serial EEPROM (24LC512) | 2d | |
Serial EEPROM (93C46) | 2d | |
Serial Flash (W25) | 2d | |
File | ||
CSV Read/Write | 2d | |
Embed File | 2d | |
File (ESP32 SDMode) | 2d | |
File (RPI) | 2d | |
File (SD/SDHC Card) | 2d | |
Real Time Clock | ||
Real Time Clock (ESP32) | 2d | |
Real Time Clock (Internal, DS1307, DS3231, DS3232) | 2d | |
Real Time Clock (MCP7940N) | 2d | |
Utility | ||
Advanced String Functions | 2d | |
Auto Version Identifier | 2d | |
Lookup tables | 2d | |
String Initialiser | 2d | |
String Translator | 2d |
Calculation | ||
Base 64 | 2d | |
Linear Feedback Shift Register | 2d | |
Map Function | 2d | |
Median 16-bit | 2d | |
Median 32-bit | 2d | |
Median Float | 2d | |
Standard Deviation | 2d | |
Type Conversions | 2d | |
Timing | ||
PIC32 Core Timer | 2d | |
STM32 Timer | 2d | |
Timed Interval | 2d | |
Timer | 2d |
DSP Inputs | ||
Data Queue to Bits | 2d | |
Input ADC | 2d | |
Input CSV | 2d | |
Input Digital | 2d | |
Input Digital Pin | 2d | |
Quadrature Generator | 2d | |
Waveform Generator | 2d | |
DSP Outputs | ||
Bits to Data Queue | 2d | |
Level | 2d | |
Output CSV | 2d | |
Output DAC | 2d | |
Output Digital | 2d | |
Output Digital Pin | 2d | |
Output PWM | 2d | |
Output Port | 2d | |
DSP Operators | ||
Adder | 2d | |
Averager | 2d | |
Deinterlace | 2d | |
Delay | 2d | |
Fast Fourier Transform (FFT) | 2d | |
Filter | 2d | |
Interlace | 2d | |
Kalman Filter | 2d | |
Math | 2d | |
Median | 2d | |
Multiplex | 2d | |
Offset | 2d | |
On/Off Control | 2d | |
PID Control | 2d | |
Rectifier | 2d | |
Scale | 2d | |
Simulated Control Load | 2d |
E-blocks 2 | ||
Actuators | 2d | |
Bluetooth | 2d | |
CAN_Bus_BL0140 | 2d | |
Colour GLCD (BL0157) | 2d | |
Combo | 2d | |
E-block 2 Helper | 2d | |
GLCD Monochrome | 2d | |
GSM (BL0131) | 2d | |
IO Expander | 2d | |
Keypad (BL0138) | 2d | |
LCD | 2d | |
LED | 2d | |
Micro SD Card | 2d | |
RFID (BL0197) | 2d | |
Relay (BL0183) | 2d | |
Servo Motor Controller | 2d | |
Sound Sensor (Grove 101020023) | 2d | |
Switch | 2d | |
SysBlocks | 2d | |
TCP/IP | 2d | |
WIFI | 2d | |
Zigbee | 2d | |
E-blocks 2 Sensors | ||
Accel / Gyro 6-Axis (Grove 105020012) | 2d | |
Barometer (BMP280 / Grove 101020192) | 2d | |
Colour Sensor (Grove 101020341) | 3d | |
Infrared Reflective Sensor (Grove 101020174) | 3d | |
PIR Motion (Grove 101020020) | 2d | |
Temp / Humidity (Grove 101020212) | 2d | |
Ultrasonic Ranger (Grove 101020010) | 2d | |
Water Sensor (Grove 101020018) | 2d | |
Raspberry Pi Hat | ||
Sense Hat | 3d | |
Misc Circuit | ||
GameCode | 3d | |
LED Cube | 3d | |
RGB Xmas Tree | 3d | |
Robotics | ||
Formula AllCode | 3d | |
Formula Flowcode | 3d | |
MIAC Module | ||
MIAC (Arduino-Compatible) | 3d | |
MIAC (dsPIC) | 3d | |
MIAC NXT / ECU | 2d |
API Slave Devices | ||
API (Arduino Mega) | 2d | |
API (Arduino Uno) | 2d | |
API (BL0032) | 2d | |
API (ECIO28P) | 2d | |
API (ECIO40P) | 2d | |
API (ESP32) | 2d | |
API (Interface Board) | 2d | |
API (RPI) | 2d | |
Test Injectors | ||
Injector (API Analog Input) | 2d | |
Injector (API Digital Input) | 2d | |
Injector (API Digital Output) | 2d | |
Injector (AT) | 2d | |
Injector (COM) | 2d | |
Injector (File) | 2d | |
Injector (Flowcode vNet) | 2d | |
Injector (Human Interface) | 2d |
Scenarios | ||
3D Printer | 3d | |
Airplane Landing Gear | 3d | |
CNC Machine | 3d | |
Car Seat | 3d | |
Daytona Racetrack | 3d | |
Maze Generator | 3d | |
Oven Simulation | 2d | |
Pedestrian Crossing | 3d | |
Pedestrian Crossing | 2d | |
Traffic Light | 2d | |
Traffic Light 1-Way | 3d | |
Traffic Light 2-Way | 3d |
Matrix Tools | ||
Device Helper | 2d | |
FCD helper | 2d | |
IntOsc Helper | 2d | |
Is Sim | 2d | |
Indicators | ||
Circular Gauge | 2d | |
Console Writer | 2d | |
LinearGauge | 2d | |
Logo Indicator | 3d | |
Numeric Display | 3d | |
On / Off Indicator | 2d | |
Speech (RealSpeak) | 2d | |
Controls | ||
Circular Knob | 2d | |
Joystick | 3d | |
Joystick 2D | 2d | |
LinearSlider | 2d | |
Number Pad | 2d | |
RadioButton | 2d | |
Charts | ||
Area Chart | 2d | |
Bar Chart | 2d | |
Bubble Chart | 2d | |
Column Chart | 2d | |
Line Chart | 2d | |
Pie Chart | 2d | |
Polar Chart | 2d | |
Radar Chart | 2d | |
Ternary Chart | 2d | |
XY Chart | 2d | |
Runtime Tools | ||
COM Port | 2d | |
Console Debugger | 2d | |
Console User Input | 2d | |
Data Recorder Setup | 2d | |
Event Log | 2d | |
Input Message Box | 2d | |
Keyboard | 2d | |
Mouse | 2d | |
Panel Console Viewer | 2d | |
Property Manager | 2d | |
Serial Monitor | 2d | |
Simulation External Input | 2d | |
Time Stamp | 2d | |
Timed Event Trigger | 2d | |
Tone Generator | 2d | |
XML JSON Parser | 2d |
Primitives (2d) | ||
Base Chart | 2d | |
Button | 2d | |
Canvas | 2d | |
ComboBox | 2d | |
Complex Shape | 2d | |
Connection | 2d | |
EditBox | 2d | |
Gauge | 2d | |
Grid | 2d | |
Image | 2d | |
Line | 2d | |
Numeric Indicator | 2d | |
Shape | 2d | |
Switch | 2d | |
Text | 2d | |
Primitives (3d) | ||
3D Panel Measurement Tool | 3d | |
Label | 3d | |
Shape | 3d | |
Text box | 3d |
App Developer Components
Digital Control | ||
Keyboard | 2d | |
Number Pad | 2d | |
Analog Control | ||
Joystick | 3d | |
Mouse | 2d | |
Dialogue Control | ||
Digital Indicator | ||
7Segment (Single) | 2d | |
LED Array | 2d | |
LED Mono | 2d | |
LED Mono Custom | 2d | |
LED Mono User Images | 2d | |
Simulation 7 Seg | 2d | |
Analog Indicator | ||
Dialogue Indicator | ||
Audio Indicator | ||
WAV Library File | 2d |
Area Chart | 2d |
Bar Chart | 2d |
Bubble Chart | 2d |
Column Chart | 2d |
Line Chart | 2d |
Pie Chart | 2d |
Polar Chart | 2d |
Radar Chart | 2d |
XY Chart | 2d |
Buffer | ||
File | ||
Embed File | 2d | |
Event Log | 2d | |
File Access | 2d | |
XML JSON Parser | 2d | |
Utility | ||
Calculation | ||
Base 64 | 2d | |
Timing | ||
Time Stamp | 2d | |
DSP Inputs | ||
Input CSV | 2d | |
DSP Outputs | ||
Level | 2d | |
Output CSV | 2d | |
DSP Operators | ||
Adder | 2d | |
Averager | 2d | |
Delay | 2d | |
Filter | 2d | |
Interlace | 2d | |
Math | 2d | |
Median | 2d | |
Multiplex | 2d | |
Offset | 2d | |
Rectifier | 2d | |
Scale | 2d | |
Comms: Interface | ||
COM Port | 2d | |
LIN Master | 2d | |
Comms: System | ||
J1939 Automotive Node | 2d | |
Modbus Master (SCADA) | 2d | |
Modbus Slave (SCADA) | 2d | |
Modbus TCP Master | 2d | |
Modbus TCP Slave | 2d | |
OBD2 ECU (Server) | 2d | |
Comms: IoT/Cloud | ||
BBC News | 2d | |
BBC Weather Forecast | 2d | |
BBC Weather Observation | 2d | |
IoT Made Easy | 2d | |
JSON Decoder | 2d | |
JSON Encoder | 2d | |
MQTT Client | 2d | |
Comms: Networking | ||
Network Communications | 2d | |
Webserver (GENERIC - Flash / File) | 2d |
AllCode | ||
Control | 2d | |
Electrical Machines | 2d | |
Formula AllCode API | 2d | |
MIAC AllCode API (dsPIC) | 2d | |
MIAC NXT AllCode API | 2d | |
MIAC USB Slave API (PIC) | 2d | |
Robot Arm v2 | both | |
API (RPI) | 2d | |
Test Equipment | ||
PicoScope | 2d | |
TTI Power Supply - PL155-P | 2d | |
TTI TG5011 Signal Generator | 2d | |
Third Party | ||
FTDI (FTD2XX) | 2d |
Base Chart | 2d | |
Button | 2d | |
Canvas | 2d | |
ComboBox | 2d | |
Connection | 2d | |
EditBox | 2d | |
Gauge | 2d | |
Grid | 2d | |
Image | 2d | |
Line | 2d | |
Shape | 2d | |
Switch | 2d | |
Text | 2d | |
Label | 3d | |
Shape | 3d | |
Text box | 3d |
Web Developer Components
Control | ||
Button | 2d | |
Check Box | 2d | |
Choose Colour | 2d | |
Choose File | 2d | |
Combo Box | 2d | |
Input Text | 2d | |
Radio Button | 2d | |
Slider | 2d | |
Switch | 2d |
Area Chart | 2d |
Bar Chart | 2d |
Column Chart | 2d |
Line Chart | 2d |
Pie Chart | 2d |
Comms | ||
HTTP Fetch | 2d | |
HTTP Params | 2d | |
SerialPort | 2d | |
Data | ||
Array Helper | 2d | |
Object Helper | 2d | |
Popup Message | 2d | |
Storage | 2d | |
Timer | 2d |
Primitives | ||
Base Chart | 2d | |
Canvas | 2d | |
Image | 2d | |
Line | 2d | |
Shape | 2d | |
Text | 2d | |
Web Primitives | ||
Image | 2d | |
Label | 2d | |
Shape | 2d | |
Text Block | 2d |
